Oil of choice
Old Apr 15, 2002 | 08:12 PM
Zerostatic's Avatar
100% Dominicano
Oil of choice
What's everybody's oil of choice here, and what is your changing interval. I think I'm going to use Mobil 1 5W-30 and change it every 3,000-4,000 miles.
Old Apr 15, 2002 | 08:16 PM
dcsquirm88's Avatar
Mobil 1 10w-30 as often as i can offered it.
Old Apr 15, 2002 | 08:35 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Agreed!
For me, Mobil 1 10w-30, every 5,000 miles.
Old Apr 16, 2002 | 02:42 PM
NOMAD's Avatar
Midnight Marauder
mobile 1 synth with K&N filter
Old Apr 16, 2002 | 03:31 PM
Clean_CL's Avatar
Mobil 1 Synthetic and i change my oil every last sunday of the month
Old Apr 16, 2002 | 03:48 PM
Chinisimo's Avatar
Why are you changing your oil so often? Even for regular oil, it's 3 months or 3,000 miles. For Sythenic, it's double that I think. Keeping the oil clean is good for the engine but is that a lil excessive? Mobile 1 is not exactly cheap either.
Old Apr 16, 2002 | 03:50 PM
HeavyP_RENAMED's Avatar
i use redline synthetic
Old Apr 16, 2002 | 04:04 PM
Bdog's Avatar
Not Registered
Since my car sucks up a quart of oil every thousand miles I use standard Castro GTX 5w-30 in winter and 10w-30 in summer. Hopefully I will get my rings fixed soon.
Old Apr 16, 2002 | 04:05 PM
MontrealCL's Avatar
I used Mobil 1 - 5W30 (the same grade that's specified in the owner's manual). I change it twice a year. I do about 11000 miles/per year, so once in the fall, and once in the spring. I think that oil is expensive as it is, and since it's synthetic there's no need to go overboard with changing it too much. If I were to change it every 3000 miles, I'd get regular oil.
Old Apr 17, 2002 | 12:11 AM
Adam3.0cl's Avatar
I use mobile 1 synthetic 5w-30 and change it twice a year, which is only about every 1500 miles for me. It sure is nice to put miles on a company vehicle instead of your own.
Old Apr 17, 2002 | 12:16 PM
drewha174's Avatar
CL- SMOOTH
Mobil 1 Synth 5W30 with Acura filter. Change every 7500 miles.
Old Apr 17, 2002 | 05:31 PM
Clean_CL's Avatar
Cause i have a turbo and i like to change it that often so that its always good and clean...
Old Apr 18, 2002 | 07:13 PM
Zerostatic's Avatar
100% Dominicano
I just bought a case of mobil 1 5W-30 today. It was like $30.00 for 6 quarts. It seems soo expensive when I look at the regular mobil oil and those were going for 12.96 for 12 quarts. Makes me wonder if it would be better to just get reguler mobil oil and change it every 2,500 miles instead of geting mobil 1 and changing it every 4,000 miles?
Old Apr 18, 2002 | 10:02 PM
Using synthetic motor oil is more than just an issue of greater $$$ per quart; it's also about the level of protection you get for that extra money spent. I run my engines extremely hard (some say I abuse them), but what else is a car for! :P
I have yet to own an engine that lasted less than 175,000 miles when using synthetic oil. My '87 Camaro was still running strong at 230,000 miles when I got rid of it 2 years ago. Synthetic oil can handle the heat levels that destroy conventional oil. To me, the price of Mobil 1 was defitintely worth it. I've had 2 engine that should have seized due to lack of coolant, but didn't, largely in part to the synthetic oil. Those instances, themselves have already paid for a life-time of synthetic use.
I change oil about every 5,000 miles, but know that I could go over 7,000 miles.
While others may disagree with me, I'm convinced!
BTW: I get Mobil 1 from WalMart and it's about $25.00 per case of 6 quarts. Wait until its on sale, then buy several cases. I've gotten it as low as $22.00 per case.
Old Apr 18, 2002 | 11:25 PM
Ricka220's Avatar
Not Fast But Built 2 Last
oil
I use 5w 30 approved SAE oil. 3 months 3k.
Never had engine trouble with my cars.
I feel that with the stop and go driving that I do, oil cets contaminated way before it breaks down.
Old Apr 29, 2002 | 04:35 PM
gotcha's Avatar
Not this again:P
Old Apr 29, 2002 | 04:40 PM
gotcha's Avatar
btw, I use to use mobil 1 5w 30 when I was NA, with the snail, I use mobil 1 10w 30 on my 99 Si and change it every 2000 miles (and check the level on almost a daily basis)
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
