automatic to 5 speed conversion?
Old Apr 29, 2002 | 06:26 PM
H22ackord's Avatar
my lil bro just got a cl and was wondering has n e 1 converted form an automatic to 5 speed. if so wat parts to get and if any kind of problem occurred during this conversion. n e info will be greatly appreciated. thanx in advance.
Old Apr 29, 2002 | 07:16 PM
dcsquirm88's Avatar
In order to change a 4 cylinder autmatic CL to a manual you will have to buy all these parts, a maunal pedal assembly, a manual center console with a shift boot, clutch master cylinder, clutch slave cylinder, hydrolic line between the master cylinder and slave cylinder, left axel assy with the intermediate shaft, 5-speed tranny mount, shifter with cables, a clutch and a pressure plate. I'm guessing you can get all the above parts and a tranny for around $1,000. Then if you can't install the new tranny yourslef you'll have to pay for labor.
Oh you can use any '92+ prelude or accord manual tranny. The gearing on each tranny is different and depending on what you plan to do the car, each might have its pros and cons.
Pham Alvan
Mar 16, 2016 09:17 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
