help! fuse keeps blowing
Old 08-20-2004 | 08:52 PM
klepto's Avatar
so my ground came out on my amp so i had to fix some wires...now, everytime I try to put in a new 7.5amp radio fuse...it sparks and blows right when i put it in. Anyone know what could be causing this? Ive already blown like 3 fuses All my grounds seem good, is it bad if i put, say a 15 amp fuse in the 7.5amp radio spot?
Old 08-21-2004 | 12:46 AM
legendaryCL98's Avatar
'07 November = STI
i dont think it would do any harm to put a 15 in a 7.5... but wouldnt that maybe blow your amp?
Old 08-21-2004 | 01:39 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
it wont do any harm
make sure no wires are touching each other even a little
high fuse will not blow your amp, i would try a 10 first, is it the small fuses or a big fuse?
Old 08-21-2004 | 01:45 AM
klepto's Avatar
yea...i checked the trunk and the dvd player again and nothing seems to be touching...imma rip out the headunits again tomororw cause im too damn tired tonight to do it. Joe, its the small square blade fuses.
Old 08-21-2004 | 10:21 AM
Andrewmc621's Avatar
do you have a cap running to your amp? that stores power in it, and would cause you to blow fuses as you tried to put them in.....happened to me acouple times before figuring it out
Old 08-21-2004 | 10:32 AM
Slooo97CL's Avatar
i had the same issues years ago, never really resolved the problem. it went away by itself after blowing 10 fuses. It def. had something to do with either a bad ground, or the cigarette lighter, i think i plugged a 1,000,000 candle watt light into the cig lighter and got a ton of problems from that. i cant even remember, but i remember not only would the radio not work but my rear tail lights went out.
Old 08-21-2004 | 05:15 PM
klepto's Avatar
yea I do have a cap, but ive never had any probs with it, im bout to take the headunits out again and check my grounds...so how would you guy suggest I make the fuses stop blowing?
Old 06-14-2006 | 11:27 AM
asianspec's Avatar
did you ever fix this man?
Old 06-14-2006 | 04:41 PM
spiderman3098's Avatar
Make sure you havent accidentally switched your power and ground wires anywhere to thatll blow ur fuse in seconds. other advice never change the size of a fuse specially in ur cars electrical system the reason they put a .5 is because th components after the fuse cant take much more than 7.5 amps by puttin a 10 amp fuse you may destroy everything that the 7.5 fuse is protecting.
Old 06-14-2006 | 05:38 PM
klepto's Avatar
lol this thread is like 2 years old, course I fixed the prob already
Old 06-14-2006 | 05:55 PM
asianspec's Avatar
lol
Old 06-14-2006 | 06:10 PM
h2o-pr00f's Avatar
Im No Superman
i was reading it like it was recent for sec
Old 06-16-2006 | 07:07 PM
wilp99's Avatar
what was it.. the remote wire ground out huh?
Acura604
20
08-05-2017 12:55 AM
hashbrown
09-29-2015 12:13 PM
xsilverhawkx
09-28-2015 06:51 PM
ripit
09-26-2015 06:19 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: help! fuse keeps blowing
