hay guys, whats going on
#2323
I have an ACT street sitting in the garage, but no money for a flywheel yet. The engagement and everything is still good, but I don't like the pedal feel... Maybe the ACT will help... Can anyone suggest a good 11-12 lb flywheel?
Rowland, I drove a 3.0 accord that my buddy has, and it was really light...
#2324
i ran a clutchmasters stage 3 with an aluminum ?fidanza? flywheel. chattered like no other at idle, sounded like straight crap but eventually it went away. i didnt have to depress it but less than inch to get in gear
#2325
#2326
Low and Slow
I've noticed this. Sometimes I have difficulty driving other ppls cars because the gas pedal feels too flimsy. I end up smashing it down and peeling out or something like that.
#2328
The ones that are really easy to push are most likely the ones that have electronically controlled acceleration. But yeah, i've noticed ours is pretty hard to press down as opposed to other newer cars too.
#2332
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Holy road tar!
#2333
i like acura
yeah my front end needs to be re sprayed so bad. thats why i rarely take a close up shot of it with a nice camera.
but i downloaded the preview of photomatix, i have no idea what im doing. i was just messing around and i liked this so i thought id share. flame on
#2334
(Mid-Atlantic)
(Mid-Atlantic)
i wasn't flaming, just sucks to see, car looks great otherwise
#2337
What I heard was that a flywheel less than 10lb would let the car rev much quicker than is "desirable" for a DD. Not that it's bad for the car, just the fact that the quick rev's would be undesirable... I already think that the car revs pretty quick, and I don't want to decrease the time that 1st and 2nd gear last...
#2339
#2341
you decide.
#2342
in a DD i wouldn't worry about it but if you aren't going to be on the throttle all the time, why get the lightned flywheel?
#2344
basically...the whole point of a lightned flywheel is to increase how fast the revs build. for performance. so if you're extracting performance from you car regulary (track, auto-x, drag), you're risking engine wear/damage. which most tuners are aware of.
#2347
Yeah, I couldn't pass it up. Now I just need to figure out which camber kit to buy. There's a few different Ingalls kits and I have no idea which one I should get because they all say 90-97 Accord.
I'm hoping to get these soon to install before the weather gets brutal. I know it's kind of stupid with winter coming, but I CANNOT deal with my noisy pro-kit anymore. It's miserable.
#2348
'99 2.3 CL
^^ I dunno about really stiff, but I know I have a little play in mine before it does anything... The clutch is the same way... Anyone know how I could adjust the clutch so that the engagement time is less than what it is now? It seems like it takes forever for the clutch to engage as of now, and I can't stand it...
The clutch pedal freeplay can be adjusted at the master cylinder from inside the car by loosening the 10MM locknut and turning the engagement rod.
I don't think this pic is from a CL, but the setup is very similar.
It only takes a few turns of the rod to make a big difference in the way it engages. Try it out and see if it helps.
#2349
(Mid-Atlantic)
(Mid-Atlantic)
#2350
Are they the ones that don't have bushings?
This is the set I was looking at: http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
#2351
#2353
(Mid-Atlantic)
(Mid-Atlantic)
Those aren't the ones I got, the ones I got came with the bushings I think
#2355
(Mid-Atlantic)
(Mid-Atlantic)
![Fluffy](https://acurazine.com/forums/images/smilies/fluffy.gif)
#2356
So, I'm pretty sure someone just tried to brake into/steal my car out of my driveway... I was standing in the kitchen making a pizza with my dad, and my alarm starts going off. My keyfob was downstairs in my room, so the panic button didn't get pressed. Dad went out and saw a big truck driving down the street... Coincidence??? Called the police, and they said just make sure you don't have anything visible in the car (which I don't) and fortunately didn't seem to care about the illegal tint... Either way, figured it was an interesting story...
#2357
^^sucks man. my mechanic got jumped a few nights ago closing down his shop. hit him in the face with something knocked him out cold before he got to his gun. sucks how shitty people try to go about doing shitty things to other people. if you can put it in the garage or pull it into your yard. every little thing helps to make your car less desirable to a thief helps. i wont go into my security setup but it begins with a garage. you could sleep in the car if your that paranoid theyll come back....
#2358
^^ I pulled the car up pretty much against the garage door (garage is absolutely full of shit), with my little sister's escort zx2 snuggled up behind it... It's basically impossible to get outta there...
#2360
