fuel pres regulator?
fuel pressure regulators hepl alot?
Im thinking of getting one. But i am debating because i am running a little rich on the dyno with the wideband o2 sensor. So im think a vafc. WHat u guys think? what are the advanages of the fuel Pres reguator? Is only around 100 without tuning. Should i bump up the fuel?
Originally posted by ilike2cheez
any gains if i lean it out??
Do fuel pressure regulators help alot?
Yes and no. They help, but I only got 1.3 peak horsepower from 36 psi to 40 psi. I would never be able to have 500cc injectors without dialing down the pressure at idle. Dont know who said you cant lean out with a fpr, but its incorrect info.
If you're on a dyno you should be tuning for POWER not a/f ratio. If you add more fuel and it gives more power keep adding fuel. Dont shoot for 14.5 a/f 'cause every motors different.
If the debate is between the regulator and the VAFC, I would do the VAFC hands down. Much more control over a/f and gains would be throughout the rpm band.
BTW, you can add and subtract fuel with both the fpr and VAFC.
navtool.com
31
Nov 16, 2015 08:30 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
