Timing Belt
Old Dec 28, 2014 | 03:13 PM
tufa4311's Avatar
4th Gear
Timing Belt
Firstly, nothing has failed yet
The other day I was looking into if it was time the replace the timing belt and after getting the work history from the previous owner's shop I saw that the timing belt and the drive belt were both replaced 5/25/2012 at 105K miles. Mileage is currently at 134K miles. I thought cool, a $1k job I didn't need to wory about. After doing some research I learned about pulley's, tensioners, and water pumps. The work order only showed that the timing belt was replaced. After calling Acura Dallas and speaking with the service manager he confirmed that only the timing belt was replaced. I asked why they wouldn't replace the pulley's, tensioners, and water pump and he noted all the other parts of the timing belt system were inspected and they were fine thus did not need to be replaced.
After my research I'm thinking that was an ignorant, stupid decision. The work order did not show that the previous owners were advised to do it and refused, the mechanic just decided it was not required.
I have learned that even with a 100% brand new timing belt if the pulley's or tensioners fail they will rip up the timing belt anyway and your engine become
a paper weight.
Sure, the tensioners and pulley's may have been fine at 105K miles,but are they good enough to last another 100K miles until the next timing belt replacement?
1. Should these guys have replaced the entire timing belt system?
2. Should I now do this job even though the timing belt will go for another 60K miles?
Old Dec 28, 2014 | 03:14 PM
tufa4311's Avatar
4th Gear
It is a 2006 MDX.
Old Dec 28, 2014 | 05:25 PM
dzionny_dzionassi's Avatar
Leave it the way it is now.
Few months ago did timing belt, thermostat, tensioners, water pump for my old 2002 acura RL with 205000 miles (now my friends car)
All stuff factory original, first time change.
To my surprise, belt,pump, tensioners was all in good condition.
Old Dec 28, 2014 | 05:30 PM
tufa4311's Avatar
4th Gear
You went 3 years and 100K miles over the limit the replace your TB?
Old Dec 28, 2014 | 06:00 PM
Sofa King Slow's Avatar
If it were mine, I would change it all if for no other reason than peace of mind. I have an 08 MDX, 06 TL and 02 Odyssey. All J-series engines. I get the kits from Amazon for $200 +/- (belt, pump, tensioner and pulley, and idler pulley) and it takes me roughly 6 hours to do the work.
Old Dec 28, 2014 | 07:10 PM
It is not me, sold my car for my buddy, like 6 years ago.
I just did help to do TB in my garage since i have all the tools
Sofa King Slow For 200$ you are getting aftermarket shit...
Did that with mine 92 legend. Changed BOSCH water pump, went out in few weeks.
There is no way you should do that on Acura. OEM ALL THE WAY....
Old Jan 3, 2015 | 09:06 AM
WanaBeFaster's Avatar
Acura Technician
Alot of shops don't change all the parts when doing a t-belt. Tensionser should always be replaced, and usually water pump on inspection. i know everyone always says do water pump with timing belt, but i have done belts on acuras with 400k+ miles with factory pump not leaking.
Old Jan 4, 2015 | 03:49 AM
Artbuc's Avatar
So true! Unnecessary replacement of WP's makes a fortune for the stealerships. How many times have you been told to replace the WP and other related parts to save labor? However, how many times has a WP failed before the second TB is needed? Almost never! If the WP bearing is smooth and quiet and not leaking, leave it in there.
Old Aug 16, 2021 | 08:09 PM
Camelot's Avatar
3rd Gear
Hi All,
I know this is the Ridgeline forum, but the Pilot is very similar so I thought I would share this. Just finished the 100,000 mile service on my 2005 Honda Pilot EX-L 4WD with 3.5L V6 engine. The car actually has only 92,000 miles but is long past the 7 year recommended timing belt replacement interval. I learned so much from the various user forums, YouTube videos and viewer comments so I thought I would pass along some of my own experience and tips that may help some others who are contemplating this service on their car. This is not intended to be a step-by-step procedure for doing the job; that is available in many places, just do a Google search. It is just a collection of extra tips and advice based on my experience doing this job.
First, let me caution you that this procedure is not to be taken lightly and requires a fair degree of experience, mechanical skill and tools that go beyond the typical driveway maintenance tasks such as oil changes and brake jobs. Over the years, I have done 5 timing belt jobs but always on 4 cylinder engines with a single overhead cam. This was my first experience with a V6 dual cam (and probably my last since I am 77 years old). On the other hand, if you are determined, have the right tools and watch lots of videos you can probably do this. I found it incredibly satisfying to turn the key and have the engine start and run perfectly after finishing. Not to mention saving hundreds of dollars in repair cost.
The biggest problem most people face is removing the notorious Honda crankshaft bolt so I suggest starting with this task. If you can’t remove the bolt there is no point in going any further. Since most DIY people don’t have the luxury of a lift, there is very little space to get a long breaker bar with a cheater on the bolt for leverage. Removing this bolt requires several hundred lb-ft of torque! You could try the “bump starter” method or bring it to a shop to get the bolt loosened. I managed to get the bolt off relatively easily using a heavy duty impact wrench and special heavy 19mm socket:
Ingersoll Rand 2235TiMAX 1/2” Drive Air Impact Wrench
77080 19mm Harmonic Balancer Socket
Even with these tools, I had to use PB Blaster and alternated between forward and reverse on the gun before the bolt finally broke free. It took less than a minute and was well worth the $15 price of the socket that I will likely never use again. The impact wrench was a really nice Father’s Day gift from my kids. I will use that tool a lot and it replaced my 25 year old Craftsman impact wrench that had much less torque and finally stopped working. Thanks guys!
After you deal with the crank bolt, you need to remove the serpentine belt (which should be replaced along with the timing belt). This is easily done using a breaker bar on the upper tensioner pulley bolt and pushing it toward the rear of the car to relieve tension on the belt. Don’t worry about loosening the bolt since it has a left-handed thread. The mistake I made was to start with the breaker bar close to the front of the car. When I removed the belt and tried to release the tensioner, the breaker bar hit against the radiator support and I could not get the socket off the bolt. I had to move the tensioner back, put the belt back on and reposition the breaker bar. I found that the bar hit the hood before I could release the belt so I braced the hood as high as it would go with a 2x4 instead of the hood support.
Next is the issue of access. Some people recommend moving the power steering pump and others do not. Same with the pump hose. I found the easiest solution was to move the pump but first take off the pump pulley. I had not seen anyone else do this but the pump bolts are not easy to get to and it is not worth the struggle. Just stick a screwdriver through the pulley slot to brace it in place and remove the one bolt holding it on. Easy! Then remove hose connecting the pump and reservoir and cap off the openings. Put a towel under it to catch the small amount of fluid that will come out.
The 3 timing belt covers are held on with a total of 17 small bolts – 5 on each of the top front and rear covers and 7 on the bottom cover. An air ratchet is helpful in speeding up removing these bolts. Look at a diagram and count the bolts to make sure you get all of them off since some are well hidden. They are all the same size so no need to identify which bolt goes into which hole. One of the bolts (I believe near the top of the bottom cover) is next to a similar bolt that secures the timing belt tensioner. No problem if you remove the wrong bolt like I did since you will be removing the tensioner anyway.
The biggest concern I had was getting all 3 gears aligned properly. After gaining access to the old belt and getting the timing marks lined up, I used white nail polish to mark the arrows on the gears, the engine block arrows and the corresponding points on the old belt (I used different colors on the belt to identify the corresponding gears). The gear indicator marks are on the edge of the gear away from the engine block so I made a mark close to the block on each gear. Especially with the rear cam gear, viewing it an angle makes it difficult to see when the marks are in alignment. I used a small inspection mirror to confirm they were lined up. After removing the belt, I transferred the marks to the new belt and confirmed the locations by counting the number of teeth between each mark (counted each belt twice to be sure). A painstaking and time consuming process but well worth it in the end. Note that you can’t mark the belt where the crank gear alignment mark is located since the belt does not contact the gear here. So I marked the belt and gear directly opposite this point and also at the right and left 90 degree points where the belt just starts engaging with the gear.
Changing the water pump, idler pulley, tensioner pulley and tensioner was straightforward. There is a Honda Service Bulletin regarding the idler pulley:
Service Bulletin 08-045 - Chirp From the Timing Belt Area Service Bulletin Chirp From the Timing Belt Area (Supersedes , dated May 21, 2010, to revise the information marked by the black bars) - PDF Free Download
I did not have this noise but decided to add the shim anyway. Looks like a simple little piece of metal but costs at least $25 on eBay and even more from the dealer.
Putting the new belt on was tedious and I ended up doing it 4 times before I was satisfied that it was correct. The rear cam gear is the hardest since it tends to suddenly jump ¼ turn clockwise from the aligned position due to the valve spring pressure. My biggest fear was that it would jump while I had my hand there putting on the belt and would cause some nasty injury. Fortunately that did not happen to me, but be careful. Even though the service manual says to start the belt installation at the crank gear and work counterclockwise, my first inclination was to start at the rear cam gear since it was the hardest. That did not work out so I went back to the recommended sequence. I also did not remove the spark plugs since they were recently changed. It made moving the crank gear a bit more difficult since I had to wait a few seconds for the compression to release after each piston reached TDC. The rear cam gear did jump a couple of times but I was able to turn it back easily (CCW) with a breaker bar. It was like a balancing act to get it to stay in place.
The marks I made on the new timing belt really helped getting things aligned. Even when I thought all the slack had been taken out between the crank and front cam, the marks on the gear and the belt did not line up. I used a small clamp to hold the belt on the bottom of the crank gear while routing it around the idler pulley to the front cam gear. I found it helpful to move the front cam gear slightly clockwise to get the marks lined up and then moved it CCW to stretch the belt. Same procedure with the rear cam gear except that even the slightest movement would cause it to jump so I held it with the breaker bar slightly off center and then moved it back in alignment to stretch the belt.
Even without the tensioner applying pressure, I found it very difficult to get the timing belt over all the gears and pulleys. It is a very snug fit. It helped to loosen the idler bolt a few turns to allow the idler to move providing a bit more slack in the belt. The bolt is tapered so when you tighten it the belt will tighten.
All was good and seemed correctly positioned. At this point the instructions say to rotate the crank gear two rotations clockwise to ensure everything is still aligned. I was hesitant to release the tensioner grenade pin since if there is a problem, it is rather difficult to reset it. So I rotated the crank without the tensioner released. Big mistake! The belt almost immediately skipped a couple of teeth off the crank. Another contributing factor was that I had removed the belt guide plate from the crank gear and did not put it back. That plate helps to hold the belt in place on the crank gear. So I went through the whole process again. This time I released the tensioner, installed the guide plate and rotated the crank and everything stayed lined up. Success at last!
This is the timing belt and water pump kit I used. It costs a bit more than some others but has good reviews and very complete instructions:
AISIN TKH-002 Engine Timing Belt Kit with Water Pump
There is a Honda Service Bulletin regarding the replacement serpentine belt tensioner pulley:
Service Bulletin 08-082 - Drive Belt Tensioner Replacement https://bit.ly/3yAvXEd
This involves trimming one of the plastic ribs on the top front cover and needs to be done before installing it.
After putting the covers back on, I installed the crank pulley and bolt. The instructions are to torque the bolt 47 lb-ft and then another 60 degrees. I think the final torque spec is about 180 lb-ft but most people don’t have a torque wrench that goes that high. So after I did the initial 47 lb-ft torque, I marked a bolt point and corresponding spot on the next flat of the pulley. Each flat (and point) of a hex bolt is 60 degrees apart. I used the impact wrench and special socket to nudge the bolt slowly until the marks I made lined up. When torquing the crank bolt you need to hold the crank pulley so it does not move and there is a special tool for that purpose:
BETOOLL 50mm Crankshaft Crank Pulley Wrench Holder
The instructions say not to use an impact wrench to tighten the bolt but I think this is because just using an impact wrench would give an imprecise torque, either too loose or too tight. My method follows the instructions for how much to tighten and I can’t see any possible downside. It would have been very difficult to get that much leverage without a lift for the final 60 degrees using a breaker bar with a cheater. (By the way, one of the upper timing cover bolts sheared off when tightening even with a small torque wrench set to 9 lb-ft. It is a middle bolt so I’ll just leave it off. Not critical so no worries. At least it wasn’t one of the pulley bolts or water pump bolts like some people have reported.)
Finally, I installed the new serpentine belt and tensioner assembly:
Gates Premium Micro-V Serpentine Belt K060841
Continental 49349 Accu-Drive Tensioner Assembly
Just make sure the serpentine belt is correctly positioned and centered on all the pulleys.
Although it had to be removed to access the timing belt, I did not replace the right motor mount since it was still in good condition and is not difficult to do at a later time (unlike the water pump). In fact, all the belts and pulleys I removed, including the water pump, seemed to be in good condition. There was only a slight oil seepage from the timing belt tensioner. I hope all the new parts last as long. If you need to change the motor mount, try this one:
Anchor 9299 Engine Mount
(I bought and returned the ones made by DEA and Beck Arnley since they did not match the OEM mount. I did not buy the Anchor 9299 mount but the picture looks like it is an exact replacement and it is less expensive than the others.)
Also, if you need to change the spark plugs I suggest that you get this tool. It makes the job so much easier with the hidden spark plugs:
LEXIVON 5/8" Magnetic Spark Plug Socket, 3/8" Drive x 6"
Then came the the “moment of truth”. I put in the key, held my breath and turned it to the start position. The engine started right up and runs like new.
Sorry for the long post. Hope you find some helpful tips for your job. I know a video and photos would have been helpful and I really admire and appreciate those who take the time to do that. Some of the tools can be borrowed at auto parts stores. Good luck with your project.
Old Nov 6, 2021 | 04:24 PM
E92Vancouver's Avatar
a paper weight.
Your timing belt is 9 years old and needs to be replaced. Do the whole job ASAP. This is an interference engine.
Old Feb 11, 2025 | 05:53 PM
A1sailor's Avatar
Does removing the upper timing belt cover provide access to inspect belt stretch and tensioner leaks?
I have an 2018 with 62,000 miles
Old Feb 11, 2025 | 08:55 PM
Timing Belt: Testing and Inspection
Timing Belt Inspection
1.Remove the drive belt.
2.Remove the front upper cover.
3.Inspect the timing belt for cracks and oil or coolant contamination. Replace the belt if it is cracked, or contaminated with oil or coolant. Wipe off any oil or solvent that gets on the belt pulleys.
NOTE: If there is any leakage, repair them before replacing the timing belt.
If you want to view the tensioner, you would most likely have to remove the crank pulley (purple) to get the lower TB cover (red) assembly off.
Old Feb 12, 2025 | 05:05 AM
A1sailor's Avatar
Thank you zeta. Will there be slack in the timing belt with engine off or does a functioning tensioner keep the belt tight with engine off?
Does crank pully loosen turning nut clockwise?
Old Feb 12, 2025 | 06:22 AM
The tensioner should maintain tautness on the TB with the engine on or off. This is how it prevents belt 'skipping' to preserve timing.
IMHO, if you go as far as removing the crank pulley, just to check if it is leaking, them you should just go all the way and perform a TB component replacement.
Step #8 below does not mention 'reverse threads; therefore, the crank pulley bolt should be righty tighty; lefty loosey.
You will need the aid of a 'Honda crank pulley tool' (google it if not familiar) to hold the crank pulley still while removing the crank pulley bolt.
If the crank pulley has never been removed, it can be a bear to remove, be prepared if you DIY.
Timing Belt Removal
Timing Bolt Removal
1.Turn the crankshaft pulley so its white mark (A) on the crankshaft pulley lines up with the pointer (B).
NOTE: The other pointer (C) is not used.
2.Check that the No. 1 piston top dead center (TDC) mark (A) on the front camshaft pulley and the pointer (B) on the front upper cover are aligned.
NOTE: If the marks are not aligned, rotate the crankshaft 360 degrees, and recheck the camshaft pulley mark.
3.Raise the vehicle on the lift, then remove the right front wheel.
4.Remove the splash shield Splash Shield Replacement.
5.
Remove the drive belt auto-tensioner Drive Belt Auto Tensioner Replacement.
6.Lift and support the engine with a jack and a wood block under the oil pan.
7.Remove the ground cable (A), then remove the upper half of the side engine mount bracket (B).
8.Remove the crankshaft pulley.
9.Remove the front upper cover (A) and the rear upper cover (B).
10.Remove the lower cover.
11.Remove one of the battery clamp bolts from the battery tray, and grind the end of it as shown.
12.Thread the battery clamp bolt in as shown to hold the timing belt adjuster in its current position. Tighten it by hand, do not use a wrench.
13.Remove the timing belt guide plate (A).
14.Remove the lower half of the side engine mount bracket.
15.Remove the idler pulley bolt (A) and idler pulley (B), then remove the timing belt. Discard the idler pulley bolt.
Old Feb 12, 2025 | 07:41 AM
A1sailor's Avatar
Thank you zeta, this is very helpful as a newbie to this vehicle. I will do the inspection only at this point when weather warms up. I will just rotate the crankshaft to inspect the belt and tension. I have watched a few youtube's and learned about the heavy socket and the pully retention socket. The TB change will be in future once I fully understand the timing setting process.
The timing belt appears to be one of the critical maintenance items with this vehicle.
I do like that Honda allows for easy spark plug changes, and good access for transmission, transfer case and rear differential fluid changes.
I'm looking forward to learning more about maintenance and things to look out for on this vehicle. I really appreciate your input on this forum.
Old Feb 14, 2025 | 09:44 AM
A1sailor's Avatar
Zeta, I read about the VCM immobilizer after market harness, such a S-VCM or similar. Do you think these help longevity of the V6?
Any thoughts on this add on?
Old Feb 14, 2025 | 11:30 AM
I have been on this forum a long time & personally have two second generation 2003 Acura CL-S'.
One is an automatic transmission 'daily beater' (the rebuilt trans. is a ticking time bomb, lol), the other is a supercharged manual six speed transmission 'fun' car.
2003 was the last year Acura made cable actuated throttle bodies; therefore, no 'computer' control or drive by wire functionality, as is the case from 2004 with all Acura models.
With that said, if I ever purchase, in future, a modern DBW Acura model with a computer controlled 'nanny' VCM system, I would procure the best cylinder management immobilizer and employ it.
As you can observe, I keep my cars for a long time. With the cost of vehicles / maintenance these days being very high, anything discovered through due diligence research that proves to enhance longevity, with ever increasing complex 'tech' improvements, would be open to consideration.
Old Feb 14, 2025 | 11:42 AM
A1sailor's Avatar
Thanks Zeta, I just watched a Youtube of an engine tear down on a V6 Hybrid (from an early Accord with the VCM) showing the damage that could be caused by the VCM system, although the motor had 410,000 kms on it.
Seems to be lots of debate out there of the pros and cons of the VCM shutting off the valves, injector and spark on the rear 3 cylinder bank.
Link;
dapqam
Oct 19, 2023 02:44 AM
Plutopf69
Jun 27, 2021 11:36 PM
pits200
2G CL Problems & Fixes
247
Sep 15, 2020 02:35 PM
rich9
May 11, 2007 02:07 AM
RCB1701
Mar 8, 2004 05:56 PM
