Help - Broken Ignition Coil Connector
Old Jan 11, 2020 | 01:47 PM
djbarber's Avatar
While replacing the spark plugs on an '11 MDX, I broke a few of the retaining tabs on the wiring harness connectors. These are the little tabs you are supposed to press down to be able to remove the connect from the coil....the bottom portion broke off that is supposed to retain the connector onto the coil. I have a temporary fix in place (using zip ties to keep the connector retained), but want to do a "real" fix. Anyone else had this issue and what did you do to fix it? I'd like to replace the connector, but not sure what the P/N is..anyone know? Or do I have to replace the entire harness..if so, anyone know that P/N? It's not clear from some of the part diagrams I've seen which harness I would need or how it gets installed.
TIA
Dan
Old Jan 11, 2020 | 11:09 PM
AcuraAddicted's Avatar
I'm not sure if you can purchase these separately from the entire engine wiring harness (32110-RYE-A71), which is like $300 tax in for the thing, so not worth it, IMO.
Pride96
May 22, 2019 11:41 PM
Lupe Revelo
Jul 8, 2018 10:32 AM
Dumaurier Johnson
May 16, 2012 09:41 AM
MIYAKUZA
Mar 9, 2011 03:45 PM
TL-Ridaz96
1G TL (1996-1998)
Dec 11, 2009 12:53 PM
