Need help
Old May 15, 2012 | 05:22 AM
Dumaurier Johnson's Avatar
Need help
hi guys is there a write up on how to change the engine wire harness 06 tl? on a tight budget and trying to save a few bucks avoiding a mechanic shop any help will be appreciated
Old May 15, 2012 | 05:43 AM
mr2td's Avatar
6th Gear
Why do you need to change the whole harness?
Old May 15, 2012 | 05:51 AM
Turbonut's Avatar
Don't believe there is one, and even the FSM would show component locations rather than the complete harness. Don't know the situation but hopefully the OE harness is in place, so remove the plastics, engine cover, battery, and rather than remove the entire harness, you might want to start at one end, remove the connector then attach the connector from the new harness and just keep moving along. If you choose to remove the entire harness first, start removing the connectors, although most connectors are different mark each corresponding connector/component with tape/numbers and take pictures, then compare when installing the new harness.
Old May 15, 2012 | 08:29 AM
car was parked for a while and rats chewed up most of the harness i already have a replacement it looks like the wires run underneath the intake manifold is it difficult to remove?
Old May 15, 2012 | 11:50 AM
BrownBuck's Avatar
BrownBuck
rats? damn where do you live
Old May 16, 2012 | 09:41 AM
fraiolim07's Avatar
Argh, rodents
