Started on some in home porting
#282
Well fries,
I ordered another box, all T's ,AN and the barb ones ,the lines ,and a zex injector air filter and going to inject the 2nd shot threw there.
This is going to be sick.
I just got to figure out a good mounting place for both to fit and look nice.
Off the AN Y the lines I'm using are only 1 foot long each.
so they will have to be mounted close
#286
I dont know,just for the hell of it.
I got it for like $5 shipped.
2nd box came.
this is where they are going to go.
on either side of the battery box.
I'm going to take the battery out and use nuts and bolts going threw the inside of the box out.
Because that side rests against the side of the battery and I don't want to make a hole threw the battery
So far the Y is ran for both boxes.
I will have it done tomorrow.
2nd box came.
#290
They are the same size.
And all the wiring could'nt be in a better location for the T's off the hoses.
The 2nd shot is bringing the car to another level of whoop ass.
And the sweet thing I'm thinking about is when and if I do up the lower end I will be able to smack the motor with 2 big shots.
Everyone that builds a fast car wants it to be faster than everyones car.
Me,
It may seam stupid but,the only car that I want to run and beat would be a cls 6, and that's azine's f'ing fault.
And only because it's the better model and I kind of feel a little handicapped.
But,Im no longer handicapped and wish there was a modded cls 6 near so I could see if my car would : win,hang,or get smoked.
Me,
#292
Whats up with RDX owners?
Ill run you
#293
Ah a worthy competitor ?
I would run you for sure.
Well,since you have a 3.6 cls6 it would really tell me, "OR" you where our car stands.
I will be sure to scribble C-YA on my back window for you.
Only s$!@ talking.
You don't mind driving, you should come over my way and run that thing.
Only s$!@ talking.
#295
Only s$!@ talking.
Only s$!@ talking.
Now why would he want to race an even faster car after I beat him?
#296
Could be possibly a tranny faliure soon.
Lets make it while we race.
I'm not scared to blow up my trans,It is on the list.
You,would probablly scared to push your car and make up excuses when the P soaks you down.
It's all good man.
Lets do it for real.
I'll tape that shizzzz, and everyone on azine will be like :
:tooc ool:: toocool::tooco ol::t oocool:
here's civicdrivr when I blaze by and there's nothing you can do about it.
Maybe you should've kept that turbo.
It's all good man.
#297
This is just too perfect
#299
Sure. When you coming to VA? Theres a 1/4 mile track near me. I dont race on 1/8th mile tracks.
I have a feeling the mods wouldnt like any of this race talk happening
** Professional Drivers, Closed Course, Do Not Attempt!**
#300
wham bam thank you ma'am
hold up. ur gonna be spraying the 1st and 2nd shot at the same time, if ur losing? dude, i push my car, 175 at one time on stock internals is hard, far more than id be pushing. good luck.
or
is the 75shot dry primary, and 100 wet shot u spray for extra juice when u know a 75dry isnt gonna be enough. so one shot at a time
or
#301
75 is going to be the primary any time spray.
When running I will probablly use 75 in 2nd and 100 in 3rd.
I don't want to use both at the same time the motor is not ready for that yet.
I'm sure seperating 1 big shot into 2 is where it's at for any kind of longevity on a stock lower end and fuel setup not to mention no ecu upgrades yet.
#302
GO RANGERS!!!!!!!!!!!!!!!
If anyone know's.
My 2nd box I wired everything in,
black-ground
red-jumped power from other box to only have 1 master power
white is ran to tps with a push button between.
My question basically is ,
Will having the push button in between the box and the tps sensor be the correct way to do what I'm doing ?
black-ground
#304
B A N N E D
If anyone know's.
black-ground
black-ground
but i would still just attach the white wire with no switches and such, then actually switch the red wire insteaad (having the white wire switch will probably cause you issues down the line, with having to recalibrate the 2nd box periodically, as the switch contacts get a little bit of resistence, it's a very low voltage/amperage signal, which won't take much resistence to throw off the signal)
#306
I was told by another that wiring both boxes basically the same except for the second box wire a switch or a button in between the tps sensor wire on the 2nd box.
So that way the 1st box will fire off tps like before,and the 2nd will be loaded with tps power too but, you use a switch or button to make the circut on when you want the 2nd box to activate.
Again is this wrong ?
#308
yes. one power switch for the 75 and another one for the 100.if u want to take a chance. flip both of them in 3rd gear and see what happens. lol (im not responsible for what may happen)
bc i know when im in 3rd (6spd, i will spin the tires with a 125shot dry)
#309
#310
So the best way is just to run to seperate power switches then flip them on when floored when I want to engauge either ?
got another question for you racja.....
A friend of mine told me he ran a 125 shot on his 1st gen cl with nothing but plugs and told me to do the same.
I told him I did not want to kill my car because I read in the zex instrution booklet that if anything is ported on the motor I will need more fuel or my car would see detonation problems before someone that don't have any porting.
True or false ?
True or false ?
#312
B A N N E D
True or false ?
True or false ?
#313
B A N N E D
LMFAO, but anyhow....
first of all is that 1st gen ClL, a 4 cylinder (2.3CL) or a 6 cylinder (3.0CL)
then just tossing in a set of COLDER plugs and the motor lives, possible..., but do you want to play that russian roulette though (you can eventually build up to it, but i would not just run it striaght out of the box, like that though)
as far as your motor being ported, the ecu should have already basically taken care of that, and the amount of additional fuel you inject with the shot, is based on the size of the shot itself, and not the motor (maybe some depending on exactly what A/F ratio it likes to make the most power)
#314
^ Not sure if it was a four or six.
I hope I'm not jumping the gun here but I just located a complete type s motor local for $275.
Un sure of the milage but $275 how could I really go wrong,as long as the block is still good.
My clp motor is still fine,no problems.
If I can find a way to get it to my house it will be getting disasemble and built.
Does anyone know if I need a type s ecu or harness to run with no cel?
#319
B A N N E D
#320
Your Garage
also the IMRC will not work because it requires a separate module that you can find and try and make work, or get an rpm switch and try that. I left mine open like phee did and I have no complaints
