Tire pressure should be... ?
Old Jun 16, 2025 | 02:30 PM
billjay's Avatar
If you look at the sticker on the door jamb, tire pressures should be 42 psi. But in the Acura EV app is recommends 38 psi. I just got my tires rotated by Acura and they are all now at 42 psi. What are people setting their tires to?
Old Jun 16, 2025 | 09:57 PM
swannyva's Avatar
My EV app recommends 38 front and 42 rear, which agrees with the door jamb sticker - for a Type S.
John
Old Jun 29, 2025 | 03:04 PM
calbear92's Avatar
In the US, the door jam label is for MAX load. For regular loads, perhaps it is 38 PSI. I couldn’t find it in the manual (new to Acura since Thursday).
Old Jun 30, 2025 | 08:05 AM
civicdrivr's Avatar
The Type S manual only shows pressures if driving at high speed (cold: 39 front, 45 rear). The door jamb is usually the place to go for pressures, but I usually adjust from there for comfort/handling). However in a car this heavy, I just go with the pressures given there (38f/42r).
The max pressures would be dependent on the tire itself - and is noted on the sidewall. The Michelin Primacy has a max rating of 50psi.
jackson5
3G RDX (2019+)
33
Sep 12, 2020 02:39 PM
princelybug
Sep 2, 2008 04:11 PM
r3mix3r
Apr 10, 2003 12:56 PM
NeedForSpeed
Dec 5, 2001 08:13 AM
NSXNEXT
Aug 8, 2001 07:04 AM
