View Poll Results: Which wheels are cooler?
Enkei Vulcan 18x8's with taller sidewall ?
0%
Enkei CUV 18x8's with taller sidewall?
0%
Acura TL 19x8 polished diamond cut upgrades. Stock tire size
100.00%
Voters: 2. You may not vote on this poll
Need wheel advice... Poll?
Old Mar 8, 2019 | 08:52 PM
Frozen Tundra ZDX's Avatar
5th Gear
I have been going nuts trying to figure out new wheels for my Grigio ZDX. The choices of wheel sis frustrating.
I first had my heart set on Vossen cv1 like the famous choice in wheel thread. I refuse to go 22", and other Vossen CV1 choices have too smakk offset. I would rather not go 20's in other brands for cost reasons(wheel/tire prices), I do like a couple enkei choices however they are 18x8. I would rather not increase sidewall height to keep diameter the same. So enkeis are pretty much out.
enkei vulcan
enkei cuv
but then I cam across a set of Acura TL accessory upgrades that is pretty sharp. I did all my research and while being 19 x 8 55mm offset, I could either go 245/50/19's or even keep same size tire 255/50.19 based on toyo tires website. I like toyo proxes st iii. I am very particular about tread design.
what do you think of these wheels? same pics in this thread here https://acurazine.com/forums/4g-tl-t...ould-i-937868/
Old Mar 8, 2019 | 09:01 PM
5th Gear
here are pics of Acura 19's. these were crazy expensive new. I have a hookup on local craigslist. They include tpms and excellent shape. All in with brand new toyo proxes stiii, they would be about $300 less than enkei 18's and $600 less than enkei 20's
I am really digging the idea of putting a bigger tire on it and seeing how they would look.
Old Mar 8, 2019 | 09:04 PM
Do it!
I wasnt very fond of the enkeis you posted, but then when I saw the Stock accessory wheel, I was smitten!
Old Mar 9, 2019 | 09:35 AM
5th Gear
being 55 offset, they might even look decent as is. worst case scenario a small spacer might be needed?
anyone with experience using a Acura car wheel on SUV?
Old Mar 13, 2019 | 03:14 PM
Type34's Avatar
Sorry man, I don't like any of those options. Especially when compared to the stock ZDX wheel choices.
If cost is an issue and you want to change out your wheels, have you thought about the Camaro 20s? You can get a used set cheap (it's the same 5 x 120 bolt pattern)...you'll just need hub rings to center the hub, but otherwise, it's a direct bolt on...
Old Mar 13, 2019 | 03:18 PM
Type34's Avatar
Honda Pilot and MDX owners bolt on Camaro wheels quite often...I also included a shot of the ZDX wheels on the Pilot to show they are interchangeable...
Old Jun 14, 2019 | 12:56 PM
xerd521's Avatar
8th Gear
You can look into the 2018+ MDX A-Spec wheels. I think it may look better on a Grigio ZDX.
Old Jun 14, 2019 | 04:34 PM
zdxsr's Avatar
Personally, I don’t like any of those, but that’s OK if you do. It’s your ride, tailor to any style you like; however, I would go with the widest ones that will not cause you issues. Wide just makes it look meaner.
For Example:
Old Jun 14, 2019 | 08:05 PM
kevin barbee's Avatar
ZDX LOVER
Nah none of them look good to me. a BMW X6 type wheel would look more in line with a ZDX
Old Oct 4, 2019 | 10:24 AM
BeachTyme's Avatar
Got Beach?
I wanted to mention in this wheel thread that I have posted a like new set of stock ZDX wheels in the marketplace. Don't mean to thread jack, but figure most of the ZDX members here probably don't go there often.
evilone
Dating & Relationships
23
Oct 28, 2004 04:56 AM
boltjames
Apr 11, 2004 10:42 PM
nabster
May 21, 2001 06:51 PM
