LEDs again! This time stop-lights too
Old May 19, 2013 | 04:27 PM
Sandro's Avatar
I upgraded my LEDs once again. This time I put new switchbacks from here
http://www.vleds.com/bulb/3157-3156-...-pair-b-o.html
It is my second set of these exact bulbs cus one of them from my first set died within 3 days. But I must admit that it shines alright! Perfect color match with the rest of their stuff. DRL LEDs are discontinued model but still works perfect. I was about to change them for new 10-LED bulbs when I found out that Vleds sent me HB4 9006 instead of HB3 9005. Now I have to deal out with replacement and thats not good because of overseas shipping. Here is how it looks now.
And finally I modded tail lights, which I planned to do for a while because stock bulbs in there are disgusting. I decided to try Vleds V3 Triton bulbs despite of their horrendous price of 100$. Also I replaced side marker bulbs with 10-LED red bulbs to increase their brightness. Installing V3 Triton was a pain in the ass, to say the least. All because there is little to no space between the tail lights and chasis. Bulb itself is plug & play and pretty easy to install, but it took me one hour of trying to put the lights back in place with all new wires and sockets, I still can't tell what part of it was blocking the way. So if I ever have to remove the lights its gonna be a challenge again.
But the result is really nice. Those bulbs are noticably brighter than stock so now I may even tint the tails a little. I just hope they don't die soon because there have been a lot of complaints and failures with them.
I can officially say that my tail lights are 100% LED now
Old May 19, 2013 | 07:39 PM
pvdq's Avatar
Wow that is really nice
Old May 20, 2013 | 08:02 AM
tsuweicherng's Avatar
Nice work Sandro!
Old May 22, 2013 | 11:20 PM
Sandro's Avatar
thanks for support! so far those V3 Triton bulbs seem worthy
Old May 25, 2013 | 03:32 PM
Sandro's Avatar
Just ordered 5k white tritons for back-up lights heh)
100$ plus shipping again.
The only nice 7440 socket bulbs that would fit and give nice lighting
Tail lights tint is comming next
Old May 27, 2013 | 03:01 PM
Timmy18's Avatar
Love it!
Old May 31, 2013 | 03:37 AM
markwon's Avatar
The LEDs look amazing!
Old May 31, 2013 | 08:53 AM
terdonal's Avatar
Looks good Sandro.
Old May 31, 2013 | 10:50 AM
Sandro's Avatar
doing my best
Old Jun 18, 2013 | 12:49 AM
Sandro's Avatar
for user rejipic - your inbox is full and i cant PM you
Answering your question:
As for Vleds bulbs here is what I use:
1) DRL - 9005_10_XB_W_5K. Only thing you need for them is load resistors. You can get them on ijdmtoy.com
2) Front parking light/turn signal - 3157_42_WA2_CK_5K. You also need load resistor for them. You can get them on ijdmtoy.com too
3) For license plate light I use 194_5_3C_W_5K
4) For rear side markers I use 194_10_CP_R
5) For brake lights I use V3_R and V3_BASE_7443. This is red V3 Triton bulb with 7443 wiring (not 7443 CK)
6) For reverse I ordered V3_W_5K with V3_BASE_G2_7443 wiring. Havent received them yet
Old Jun 18, 2013 | 10:13 PM
redjpic's Avatar
3rd Gear
Sandro..Thank You very much!!!
Old Jun 18, 2013 | 10:37 PM
redjpic's Avatar
3rd Gear
Sandro,
This item number does not show up on Vleds website...is it a different number?
Old Jun 18, 2013 | 11:39 PM
Sandro's Avatar
Oh they added standard and CAN-bus proof option. I I have CAN-bus proof but both should do for Acura. Here is the link http://www.vleds.com/bulb-type/minia...25-1-pair.html
Old May 12, 2015 | 03:12 PM
Dragon27's Avatar
big thumbs up for this post. I ended up putting opt7 led bulbs in the fog lights and drl (with resistors). These led bulbs have a high output lighting that was brighter than the stock fog light bulbs that came in a stock maxima (my previous ride). I also ended up putting super white bulbs into the turn signal/parking light and vled 194 for the license plate...
Old Mar 12, 2017 | 12:54 AM
con5tant's Avatar
Dumb question..but could someone please circle where the rear side markers are on the car?
Old Mar 12, 2017 | 12:01 PM
zdxsr's Avatar
Wait until dusk, then turn your parking lights on and walk around the back. You'll see them.
Old Mar 14, 2017 | 12:29 AM
con5tant's Avatar
How do you access the bulbs in the taillights? Unable to find anything.
Also, does the 7443 led require a resistor?
Old Mar 14, 2017 | 08:52 AM
zdxsr's Avatar
You must have not searched this forum? I just found this link: https://acurazine.com/forums/acura-z...-bulbs-905440/ Sandro provided the answer.
Old Mar 18, 2017 | 04:42 PM
con5tant's Avatar
Question... Have you replaced the bulbs in your taillights? Because it's not clear the way it's explained by Sandro in that. I tried doing it just now and literally had no idea what to do after removing the 2 screws. I'd rather see an owners manual picture or something.
Old Mar 19, 2017 | 11:22 AM
zdxsr's Avatar
YES. I have replaced a bulb in the right side tail assembly when I first got my ZDX.
What you are struggling with are the pins (circled in red below). They are strong fasteners, and considering they haven't been touched since the car was assembled they're going to be stubborn.
You can search You Tube for how to replace a MDX tail light since I didn't find a ZDX one. You will see the holding force of those pins.
Old Mar 19, 2017 | 06:59 PM
con5tant's Avatar
I finally got them off. Ended up breaking the plastic tab thing where the two screws go...oh well. They were on there pretty good
oo7spy
Jun 19, 2023 12:48 AM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
benny_jdm
Jan 31, 2016 06:15 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
