G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Old 02-17-2012, 05:10 PM
  #681
vietxquangstah's Avatar
Originally Posted by awz05TL
Oh, didn't know that. Do we need another resistor for it?
In other words no. If you want to upgrade your stock reverse lights to bright HIDs or any LEDs on the market, you do not need any resistors or anything at all.
Just simply remove the old bulb, put in the new. You don't need to add anything at all. Just straight forward and swap the bulbs. Just like changing the interior lights of your car to LEDs.
No need for resistors yo
Old 02-17-2012, 05:58 PM
  #682
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ he just needs to make sure he tops off the indicating fluid
Abdul, lets just meet up....will help you out with everything
Old 02-17-2012, 09:06 PM
  #683
Chapter Leader (Midwest Region)
McCollins23's Avatar
Ok fellas go easy on me, Ive looked through this thread and I could not find the exact part number and place that you guys are ordering from. I just need (1) .12 ohm resistor for my front switchbacks. If someone has an extra one to pass on to me that would be awesome as well.
Oh and by the way whats up Anil, long time no see. We need to get together soon and hang.
Old 02-17-2012, 09:56 PM
  #684
Silvertl88's Avatar
i have 9 0.12ohm resistors. I bought the min buy (10parts) from Digikey and recently installed mine with no issues other then frustration getting the damn signal/hazard relay out from underneath the steering wheel.
if you are looking for one let me know.
Old 02-17-2012, 10:31 PM
  #685
swoosh's Avatar
hahaha hell yeah bro....been a while.....
had a lot of fun the other night, the gang is CRAZY (in a good way)....made my miss my STL gang LOL....
about the resistors, just get a 0.22 ohm one....
Old 02-17-2012, 11:25 PM
  #686
Yeah it was fun! Silvertl is gonna send me an extra one that he has. I dont plan on switching to rear led's so I think a 0.12 should be fine for my application from what I read. I may be recruiting you and some other folks to help me put on my aspec kit when I get it also
Old 02-18-2012, 07:54 AM
  #687
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
If you're going on the mission of having to pack and ship all these resistors, might I suggest charging $5 for them...you'd make a profit worth the effort and most people will NOT mind paying five bucks to get one. At least I wouldn't.
Dark Rican, I wasn't talking about the soldering, i was talking about the PITA of taking that relay out again. It sucks.
PS...my recommendation is based on MY experience...my front LED's which are for base 04 which are 7440....the white was staying on at full intensity when you would blink the orange UNTIL I either unplugged the rear oem bulbs OR installed the LED rears.
This was with the .24 resistor. So my theory was that you should stick with .12 for just fronts and .24 only if you're doing both.
Maybe other bulbs are different.
Old 02-18-2012, 05:54 PM
  #688
swoosh's Avatar
^^^ you mean 7443 ???
7440 is single circuit and 7443 is a dual circuit.....maybe you had that experience coz you installed the wrong bulb....
as i mentioned front are dual circuit (on + blinking)....where as the rear are single circuit (blinking)....if you put a 7440 upfront, it will just stay on and will not blink.....
Old 02-19-2012, 12:58 AM
  #689
Shoeface's Avatar
So I finally got around to putting in my V2 switchbacks today. Thanks Anil for the resistors
Here's what the PITA relay looks like taken apart
G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS-s4vx5.jpg
I soldered on a .12 ohm resistor for just having front LED's. Everything went well on the first try - things blinked fine as they're supposed to (I've got a vid of it, haven't had time to convert/upload) but just ran into some problems tonight coming home from the bowling alley. The blinkers stopped working. The white works (parking lights) but they don't blink, nothing blinks on my dash, and hazards don't work.
I haven't looked at the relay yet, but does anybody have any suggestions or what could have caused this? Could it be the relay or a fuse? It was my first ever soldering job, so it might not have been perfect.
Old 02-19-2012, 01:59 AM
  #690
Shoeface's Avatar
Got the quick video uploaded. Not the greatest quality - HTC Evo. But proof that they were working before I had my problem
Old 02-19-2012, 06:32 PM
  #691
swoosh's Avatar
^^^ no problem bro....
did u use flux while soldering ? or how much solder did u use ?
easier fix would be if the resistor has come loose....I hope this "didnt" burn the 0.12ohm resistor....
remove the module and see if the 0.12 is sitting nice and snug....if not, solder it and see if it works....
if this doesnt work, replace with the 0.22 and see what happens....
PS: blinker not working means relay not working....check the capacitor/IC and make sure they are all connected the way they should be....
Old 02-19-2012, 06:47 PM
  #692
Shoeface's Avatar
I plan on tinkering with the relay tonight. Hopefully it's not shot.
I went back and read through some of this thread again, trying to figure out how a 0.22 resistor came into play. The first few pages said 2 x 0.12 = 0.06 for all four corners. Then later, people used 2 x 0.12 = 0.24 for all four corners. Which is correct? And then what's the purpose of a 0.22? I haven't planned on getting rear LED's yet.
Old 02-19-2012, 06:51 PM
  #693
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I used 0.24ohm.
If you use a .24ohm, it works if you have just the fronts, but if you plan on getting the rear LEDs too, it will still work.
If you use .12ohm, the fronts work, but if you want rear leds too, you'll have to swap the resistor AGAIN.
  #694
swoosh's Avatar
^^^ well if you have only front LED's then you need 0.06X2 = 0.12....later people used 0.24 since they have LED's in all 4 corners, so 0.06x4 = 0.24 and I think 0.22 came in just coz 0.24 wasnt available and someone tried it and said "it works"
Shoeface (02-19-2012)
Old 02-19-2012, 06:56 PM
  #695
Shoeface's Avatar
That makes more sense than what I was thinking. I'll let you know what comes of it.
Thanks!
Old 02-19-2012, 07:30 PM
  #696
Thanks!
Keep in mind that when you solder resistors in a series circuit, total resistance adds UP.
If you solder the resistors in parallel, total resistance GOES DOWN.
So just because you have two 0.06ohm resistors and solder them together doesn't automatically make them 0.12. It depends how you soldered them together, in a Series or a Parallel circuit.
Old 02-19-2012, 07:39 PM
  #697
swoosh's Avatar
^^^ glad you mentioned it VIET....I doubt Shoeface will solder the o.12 and 0.22 one together but good info
PS: missing my electronics lab right now
Old 02-19-2012, 08:26 PM
  #698
awz05TL's Avatar
Haha, thanks man, I will hit you up once I have my LED!!
Picking up me resistors tomorrow from buda!!
Old 02-20-2012, 12:05 AM
  #699
swoosh's Avatar
^^^ sounds like a plan
Old 02-20-2012, 08:17 AM
  #700
yes you're right, I meant 7443...not 7440...I'm very aware of the difference since you'll recall the issue I had with the whites no turning off when the amber would blink (like the sidemarker blinking issue).
Anyway, in MY case...the ebay bulbs I used would NOT switch"back" correctly UNTIL I put in the rear LED's too. Just my experience and I started off with the .24 ohm resistor.
Old 02-20-2012, 09:55 AM
  #701
swoosh's Avatar
^^^ yeah since that is toooo much resistance....you have LED's upfront and bulbs in the back on the same circuit and you replace the shunt resistor by a 0.24 ohm one....
am not able to diagnose Shoeface's problem coz he has a 0.12 ohm resistor which should work
Old 02-20-2012, 10:15 AM
  #702
I wonder if his solder ran across both leads?
Old 02-20-2012, 10:22 AM
  #703
swoosh's Avatar
^^^ but it was working in the video....
i think the solder melted from overheating the resistor and hence it came loose....either way, we will know when he opens up the module again....
Old 02-21-2012, 01:08 PM
  #704
Two 3G TL Baller
The Blue Abyss's Avatar
Location: Coppell, TX (4 miles N of Dallas Cowboys' HQ)
I just did this mod a few weeks back. Bought the two pack of resistors from the local Fry's for $0.99, and bought the switchback LEDs from V-LEDS.com (took them forever to get them back in stock and shipped).
Originally Posted by Roger555
Hey you guys that have a FRY's it looks like they carry it in some of there stores
http://www.frys.com/search?search_ty...bmit.y=0&cat=0
Old 02-22-2012, 12:42 AM
  #705
Shoeface's Avatar
I honestly have no idea what happened. There didn't appear to be any physical damage like something was burnt. Anyways, I replaced the 0.12 resistor with the 0.22 resistor and same results - no blinking. I don't know enough about electronics and circuit boards to know what may have happened.
Either way, I ordered a new relay for $30, should be here this week. I'll be at a loss if it still doesn't work
Old 02-22-2012, 12:52 AM
  #706
ellyellyelly's Avatar
such a helpful mod, alot easier than i thought.
just installed a .22 ohm that i got from frys, i only have the front switchbacks for now and it works perfect! where can i get the switchback sidemarker bulb and whats the brightest rear led i can get and where?
Old 02-22-2012, 08:51 AM
  #707
shoeface, did you try soldering the original shunt back in to see if it worked?
Old 02-22-2012, 09:04 AM
  #708
swoosh's Avatar
I agree with Jer....did you solder the original shunt resistor back in ?
Post some pix of the relay (for us to see if you burnt anything while soldering )
with the new relay if you drive down to Olathe, will fix it for ya
Since the rear has a diffuser, any LED you get will be bright....i recently saw a 27SMD LED indicator and it was bright as hell....check out vleds and superbrightleds....
For the side markers check out this thread:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/teaser-thread-about-markers-side-%3B-843961/#post13470926
Old 02-22-2012, 09:31 AM
  #709
Shoeface's Avatar
No I did not try that. I also think I threw it away because I had everything working and didn't think I needed it.
Old 02-22-2012, 09:59 AM
  #710
Dang...
Old 02-22-2012, 12:03 PM
  #711
2007 6SMT Type-S
SurfingScotty's Avatar
Sorry this may be a bit off topic but does anyone have a good number for JLC Lighting? I've sent back their shitty merchandise back in November '11. I've called, and have never gotten through. I've emailed and have never gotten a response to the item I sent back.
Old 02-22-2012, 12:09 PM
  #712
I will never buy from them again...i would consider it money lost, man. No offense to them or their products but dealing Kinetic, their vendor was enough to turn me off forever.
Old 02-24-2012, 04:33 PM
  #713
Silvertl88's Avatar
JLC Lighting
626-872-6942...they sent this number to me on facebook to call them about a coupon code. I did and got right through to someone even though they werent helpful at all.
i really want to buy the led drl kit they have but i want to make sure their decoder works like it should and i havent found a direct answer anywhere.
anyone have insight on that?
SurfingScotty (02-25-2012)
Old 02-24-2012, 04:35 PM
  #714
Silvertl88's Avatar
As for this thread...i soldered the resistor in place a couple weeks ago and im about to put my switchbacks in tonight. I hope all goes well
P.S. i have 2 more 0.12ohm resistors if anyone is looking for them.
Old 02-25-2012, 03:10 PM
  #715
Silvertl88's Avatar
Here is some pics and video of what the V-LEDS 1157 60 SMT 6K switchback looks like in oem 08 type s headlights. The amber reflector is still in there and you can only see it at night and does not effect the light output.
i love this mod!
rockstar143 (02-25-2012)
Old 02-25-2012, 03:18 PM
  #716
swoosh's Avatar
^^^ looks good bro....but y dont u just roll the windows down rather than opening the door again and again LOL
Old 02-25-2012, 04:48 PM
  #717
Wow, those are super bright! Nicely done!
Old 02-26-2012, 12:07 AM
  #718
Shoeface's Avatar
New resistor came in the other day so I slapped it in as is and everything works again, just with the hyperflash.
Round 2! I'm gonna have my friend do it this time. He's repaired LCD/LED monitors before so it's a safe bet.
Old 02-26-2012, 10:10 AM
  #719
I find it REALLY weird that about 80% of us were able to do this mod without any problems, but the others are having all types of different errors.
Old 02-26-2012, 02:07 PM
  #720
swoosh's Avatar
WOW....really bro ? I am using the 0.22 ohm resistor which i send you....i got 2 of them in, using 1 and send the other one to you....and the hyperflash is gone
did u solder it properly or why didnt the first one work ???
to add to the problem VIET,
both the resistors i send Shoeface, were working on my car....the 0.12 ohm worked fine but only killer the hyperflash when i hit the hazard light and not on the indication part.....the 0.22 fixed everything....
so both resistors worked on my car and none work on his....weird right ....
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
