A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
#2001
You forgot the timing belt is not the same as oem. Mitsuboshi (used in the Aisin kits) is the oe supplier for Toyota. Gates (called Unitta in Asia) is the oe supplier for Honda timing belts.
#2002
Fair enough, but I think Mitsuboshi and Gates belts are considered equivalent. The Gates water pumps on the other hand have been questioned. I know some have had no problems, but these things don't just come from nowhere.
#2003
I have done many of these and personally think the Mitsuboshi T belt is a better quality but that the Gates T belt is very good as well.
#2004
ekrekel, I was one of those that had a problem with a Gates water pump in only 50k miles. I will never use one again. I would definitely only recommend the Aisin or OEM/Yamada pump.
#2007
Yeah, you won't use the full 2 gallons (at least I didn't), but you'll need 2 jugs.
#2008
NFN...brushless, available for purchase NOW on prime amazon...I think I'm going with the DeWalt...only advantage the Makita has is the electric brake (no mention of it on the DeWalt)...but disadvantage is "ships within 2 months" and is $250 with NO battery and charger/case.
Thanks for the recommendation.
#2009
www.amazon.com/gp/product/B00X52TWA4
IIRC, it has the brake. He covers that in the video.
Edit: ^^^this is the detent anvil model. The model he reviewed is the hog ring anvil.
Here's the hog ring anvil (couldn't find it with just one battery):
no battery
#2010
meh, damn edit timer.... only the IR has the brake. Not a big deal IMO.
I'd probably go with the hog ring anvil version of the DeWalt. You can buy DeWalt knock off 5 Ah batteries for ~$58. A DeWalt 5 Ah battery is going to run over $100.
#2011
Thanks, man...I read up on it and am okay with the detent anvil since it'll be legit, with battery and case and charger for $300...can't beat that. The makita had the brake too, but there aren't any in stock anywhere and I don't feel like WAITING, getting NON prime with no battery for only a $60 savings over the dewalt.
#2012
I've used this kit twice. https://www.amazon.com/gp/aw/d/B008E...?ie=UTF8&psc=1
The Honda stamp on the WP is the only difference AISIN. KOYO pulley and identical tensioner. You probably don't need the cam or crank seals. I wouldn't have been able to replace the crank seal if I didn't have to take the oil pump off due to the dreaded oil pump gasket leak.
See parts 3 and 5
ALTERNATOR BRACKET for 2006 Acura TL
Part 13
P.S. PUMP - BRACKET for 2006 Acura TL
See parts 3 and 5
Part 13
Thank you
#2014
The Gates is working fine for me...
#2015
Honda OEM serpentine belts are either made by Bando or Mitsuboshi. The Mitsuboshi is definitely the nicest serpentine belt I've seen. I used one on my TL. It has a higher quality fabric-looking finish (exactly like OEM) vs the Gates basic rubber look I have on my Pilot. The Bando non-OEM belt I used on my brothers Civic has a cheap looking glossy finish. AutohausAZ has the 6PK2135 for $14 + shipping.
Link to Mitsuboshi 6PK2135M Serpentine Belt
Ebay has them for $24 shipped:
Link to mitsuboshi 6PK2135M | eBay
aIRpeACE (04-16-2016)
#2017
FYI, the first Gates belt lasted 110K miles with no issue before I changed it, the 2nd Gates belt has been on for ~15K now, no issues. Whether you spend $19 shipped for the Gates or ~$25 shipped for the Mitsuboshi really means little difference when you're talking about 110K miles...
#2018
Yes...Everyone has used the Mitsuboshi belt. It came on the car installed from the factory. Definitely the highest quality belt for the money. See line 11 at the following link: OEM Acura TL 2005 A/C COMPRESSOR parts
Here is the OEM Honda belt with the OEM part number on it and the Mitsuboshi logo:
#2019
#2020
I didn't notice any change in noise between the Mitsuboshi and Gates....
#2021
The timing belt is covered up, you don't really hear it. What makes a difference is using a better quality quieter serpentine belt like the Gaborback. The serpentine belt is exposed to outside element at all times.
#2022
The serpentine belt IS what we're talking about. I've never run the Gatorback so I can't compare it to the OEM.
#2023
Don't fall for all that aftermarket BS. Use OEM. Honda always picks the best stuff. If you have the opportunity to get OEM in an aftermarket box for less money, then it should be a no-brainer. Especially if the other aftermarket brands cost about the same. This is why I recommend the following for a 105k service...
Gates TCK kit (no water pump)
Aisin or Honda water pump (whichever is cheaper)
Aisin tensioner
Honda Coolant
Mitsuboshi Serpentine belt
NGK Laser Plat plugs (from advance autoparts w/ coupons)
Honda Thermostat
This is 100% same as OEM parts, most in aftermarket boxes.
Aisin tensioner
Honda Coolant
Honda Thermostat
#2024
someone earlier in this thread recommended Bando serpentine belt. It is under $15 on RackAuto which is over half the price compared to Honda OEM belt. I hope I wont regret putting this in instead of Honda OEM belt.
More Information for BANDO MFG. 6PK2135
#2025
I have a gatorback...which is noisy, they switched it for another one...I had oem originally obviously...
I'm convinced it's the tensioner pulleys. I swapped mine once...but now, if I don't drive the car for a while, it's squeaky until it warms up. If I drive it regularly, it doesn't happen.
#2026
#2029
Mitsuboshi
this is the best price for a serpentine belt i found so far.
you can also order the type 2 coolant to qualify for free shipping
#2033
I see your schwartz is longer than mine I'm going to have to find one of those. Where'd you find that?
In for details on changes between #1 and #2!
I've been putting off valve adjustment #2, need to get it done. Been about 15K since TB change #2 (228.5K total miles now).
#2034
LMAO, you mean the feeler gauges? I bought them on amazon a while ago! They come straight, I bent them to how I felt I could get around stuff. Shorter ones would probably be best!
Well, I kinda cheated cause this round of valve adjustment was done on my NEW (to me) TL-S...and it runs nice and silently! Followed our original convo though and did .008 and .013...
I'd say lessons learned for this go around:
ONLY use your thumbs to press the spark plug gaskets in...
and even palming with a 1/4" ratchet...I managed to strip out one of the IM upper cover bolts Damn magnesium!
Also, I HIGHLY recommend you split this job up...tackling THIS AND the 105 TB service was super daunting. I like doing this and then waiting a few months so you're only digging into the SIDE of the motor.
#2035
Awesome write up. After reading this thread and researching countless hours on this job, I think I have the balls to tackle this. I have a 07 and a couple of months back I had to replace the radiator and I change the spark plugs already. I'm no mechanic but just like to work with my hands. Any tips or pointers from pros here regarding this job. I bought the car 2 yrs ago with $60k and I am at $105k and going to go on a 600 mile road trip soon so I don't want to be stranded on the road. I don't think water pump and timing belt was ever changed.
i wish I had a buddy to help me out but looks like I'll be flying solo on this.
What at are the essentials stuff I need to do this job? I don't mind spending the extra money for genuine parts.
much thanks to all for your insight.
#2038
rockstar143 (06-25-2016)
#2039
+1 to the crank pulley. I ended up having to heat mine with a small torch (the kind they sell for sweating copper plumbing pipe) and then used a 4' piece of black gas pipe (so it won't bend) on the breaker bar. Also a small block of wood under the bar to keep it all straight. Read the entire thread. And give yourself plenty of time. I have an extra car so spent a couple of hours every night over the course of a week. Went well and replaced a motor mount, plugs, and a few other items.
#2040
I bought the OEM kit a while back and didn't have the balls to DIY for my TL-S. Kind of glad I didn't after reading this as inexperienced as I was back then... fast forward to today reading through it again after tinkering with an S2k -> Stealership banked on me. So extra kit available!
