Windows 2003 Server Back-up and Restore question
Old Jan 19, 2006 | 07:48 AM
icy CL's Avatar
i've been playing around with this back up and restore feature of Windows 2003 Server. I am able to succesfully back-up the whole C drive and system state. But whenever I try to do a restore, it always fails. I can't get my server to boot. It always gives me an error. What I do when i try to restore is, reinstall the OS, then restore the entire C and system state. i let it override any existing files. when it is done restoring all the files, it ask to reboot. that's when i am faced with thi s issue. once it reboots, i don't exactly remember the error code but it won't load the OS with the restored files. why is that and can someone guide me on this. thanks.
Old Jan 19, 2006 | 08:22 AM
Whiskers's Avatar
Go Giants
Most likely will need the error code - Are you reinstalling the same version of 2003 (SP1?).
Old Jan 19, 2006 | 09:02 AM
doopstr's Avatar
Get Ghost, your life will be easier.
Old Jan 20, 2006 | 01:23 PM
icy CL's Avatar
Yes I am installing the same version of 2003 SP1. This is the process I follow:
- Reinstall a clean copy of Win 2003 Server on an exact machine (hardware wise...all same parts and hardware configuration)
- when done, i run restore using the Windows 2003 server utility
- when running restore, i select the following: restore "C" and "system state"; i select "restore files to original location" and also select "replace existing files".
I let the restore feature run. Once done, i check the log and it says restore completed and successful. I reboot which it asks for. After rebooting this is the error I get:
"Windows could not start because the following file is missing or corrupt:
\WINNT\SYSTEM32\CONFIG\SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM.
Select "r" at the first screen to start the repair."
Old Jan 20, 2006 | 01:44 PM
Whiskers's Avatar
Go Giants
Are you restoring the whole machine or just the system state. Is it an Active Directory Controller?
Old Jan 20, 2006 | 02:31 PM
icy CL's Avatar
the whole C drive (which is the whole machine) and system state. No, it is not a DC. it is my application server.
Old Jan 20, 2006 | 03:55 PM
knight rider's Avatar
Rooting for Acura
I think you are backing up the OS too and that is what is giving you your error. Try backing up only what you need BU'd. I think that will work. If you have files all over the place then try to consolidate them to a few folders before backing them up.
Old Jan 20, 2006 | 04:04 PM
Rooting for Acura
I don't know if this will help but it might be worth reading.
read this
Old Jan 21, 2006 | 07:41 AM
icy CL's Avatar
read this
page cannot be displayed
Old Jan 21, 2006 | 07:51 AM
Whiskers's Avatar
Go Giants
Try reinstalling the OS manually and then laying over the system state.
Old Jan 21, 2006 | 09:44 AM
Rooting for Acura
http://www.kellys-korner-xp.com/xp_sys32.htm
Old Jan 27, 2006 | 04:28 PM
icy CL's Avatar
found out what i was doing wrong. i wasn't using the ASR feature...basically a system restore floppy disk for my specific server. did a back up and created an ASR disk and now am able to restore no problems at all. thanks
Old Jan 27, 2006 | 04:40 PM
Billiam's Avatar
Big Block go VROOOM!
Double and triple ceck the ASR stuff. Maybe I'm nuts, but I could swear I recall reading somewhere that the ASR disks are tied to the backup sets. Whenever you make a backup you want to be able to recover the OS from, you also have to make a new ASR disk with it. Or something like that.
Old Jan 27, 2006 | 07:09 PM
icy CL's Avatar
thanks for the heads up. i will test this soon. i don't usually change the system settings...just the database. gracias gringo.
BoricuaTL
Apr 8, 2016 01:08 PM
LECKEY73
Feb 22, 2016 01:32 PM
mazen222
Oct 27, 2015 12:01 AM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
