Network guys, I need your help..
I have my Windows XP box and my Infrant ReadyNAS hooked up through a Gb switch. That switch is hooked up to my home router.
However, when I transfer files from my computer to the NAS or vice versa and check my network utilization statistics in the task manager, it varies between 8-11% utilization.
How can I get my windows box to up how much it utilizes for the connection? The transfers are so slow even with the Gb connection it's getting annoying.
Originally Posted by baby_igor
Do you have all the ports set to full duplex?
Ports on the router? switch? nic card?
I never explicity set anything to full deplex, didn't know I needed to.
The gigabit switch does not have an interface of any kind so nothing on there can be adjusted.
After doing some reading on the internet, I think I might have found the culprit. I think it's my hard drive. The read times off my hard drive may not be fast enough to fill up the network pipe and that's probably my bottleneck.
What do you guys think?
GB Switch means nothing. There are very few drive set ups that will actually function at those speeds. BOTH drives matter (read and write). This really isn't a network problem. ;]
STUPID assumption, but BOTH cards are gigabit right? =] Never know. LoL.
The NAS does support Gb connections w/jumbo frames. My Intel Mobo supports Gb connections as well, but no support for jumbo frames.
Try a crossover cable and connect the NAS directly to your PC. See if there is any difference in speed. That will rule out if the switch (or router) is the culprit (doubtful).
How many drives do you have in the NAS and what RAID type are you using? You will have overhead due to parity checking, not to mention network overhead...
8-11% of 1gb is still 80-110mb... Still faster than a 100mb connection (which might get 20-40mb transfer)...
Also, don't get bits mixed up with bytes...
OculiAquilae
11-19-2018 02:24 PM
IndycarFaster
09-11-2015 02:52 PM
