Network guys, I need your help..
Old Jul 22, 2007 | 09:01 PM
Sly Raskal's Avatar
Question Network guys, I need your help..
I have my Windows XP box and my Infrant ReadyNAS hooked up through a Gb switch. That switch is hooked up to my home router.
However, when I transfer files from my computer to the NAS or vice versa and check my network utilization statistics in the task manager, it varies between 8-11% utilization.
How can I get my windows box to up how much it utilizes for the connection? The transfers are so slow even with the Gb connection it's getting annoying.
Old Jul 22, 2007 | 09:45 PM
baby_igor's Avatar
Do you have all the ports set to full duplex?
Old Jul 22, 2007 | 09:52 PM
Sly Raskal's Avatar
Which ports are you referring to?
Ports on the router? switch? nic card?
I never explicity set anything to full deplex, didn't know I needed to.
The gigabit switch does not have an interface of any kind so nothing on there can be adjusted.
Old Jul 22, 2007 | 09:57 PM
Sly Raskal's Avatar
I just checked the properties of the nic card, it's line speed and duplex setting is set to Auto detect.
Old Jul 22, 2007 | 10:05 PM
khiyal's Avatar
make it 100/full
Old Jul 22, 2007 | 10:10 PM
Sly Raskal's Avatar
Originally Posted by khiyal
make it 100/full
Don't you mean 1000/Full since It's on a Gb network??
Old Jul 22, 2007 | 10:18 PM
Sly Raskal's Avatar
Alright, so there's no option for 1000/Full.
there are only these options:
Old Jul 22, 2007 | 10:21 PM
Sly Raskal's Avatar
Forgot to mention, I'm also running Cat6 cables.
Old Jul 22, 2007 | 10:24 PM
Sly Raskal's Avatar
After doing some reading on the internet, I think I might have found the culprit. I think it's my hard drive. The read times off my hard drive may not be fast enough to fill up the network pipe and that's probably my bottleneck.
What do you guys think?
Old Jul 22, 2007 | 10:31 PM
kyle77777's Avatar
Gonna cost to catch up
Thats probably correct
Old Jul 22, 2007 | 10:50 PM
SupaRookie's Avatar
Kang Ho
I'm not a network guy yet, but studying to get my CCNA. But what you are saying sound correct. I would however, change your link speed to "AutoNegotiate 1000Mbps" instead of Auto Detect. If all your equipment is Gigabit, why not choose 1000Mbps?
Old Jul 23, 2007 | 01:01 AM
Sly Raskal's Avatar
The onboard Gigabit controller on my Intel mobo doesn't support Jumbo frames either.
Old Jul 23, 2007 | 07:33 AM
doopstr's Avatar
What kind of hard drive you got in there? 1st gen SATA is rated at 1200Mbit/Sec. Even if you had a "slow" SATA disk I would expect it to do better than 10% of your 1Gb connection.
Old Jul 23, 2007 | 07:49 AM
CleanCL's Avatar
GB Switch means nothing. There are very few drive set ups that will actually function at those speeds. BOTH drives matter (read and write). This really isn't a network problem. ;]
STUPID assumption, but BOTH cards are gigabit right? =] Never know. LoL.
Old Jul 23, 2007 | 11:39 AM
Sly Raskal's Avatar
I have to check the exact model hard drive I have installed on my windows box and which drives are on the NAS.
The NAS does support Gb connections w/jumbo frames. My Intel Mobo supports Gb connections as well, but no support for jumbo frames.
Old Jul 23, 2007 | 12:31 PM
Whiskers's Avatar
Go Giants
There are many packet tracers you can use...
Old Jul 23, 2007 | 12:35 PM
Sly Raskal's Avatar
packet tracers???
Old Jul 23, 2007 | 12:38 PM
Whiskers's Avatar
Go Giants
http://www.google.co.uk/search?hl=en...+packets&meta=
Old Jul 24, 2007 | 03:39 AM
Kikaida's Avatar
Try a crossover cable and connect the NAS directly to your PC. See if there is any difference in speed. That will rule out if the switch (or router) is the culprit (doubtful).
How many drives do you have in the NAS and what RAID type are you using? You will have overhead due to parity checking, not to mention network overhead...
8-11% of 1gb is still 80-110mb... Still faster than a 100mb connection (which might get 20-40mb transfer)...
Also, don't get bits mixed up with bytes...
Old Jul 24, 2007 | 12:53 PM
Sly Raskal's Avatar
I dont' think I have a crossover cable. If I find one, i'll give that a go.
I have 4 500GB Seagate barracuda drives installed. I do understand there is quite a bit of overhead for syncing the data, parity checks, etc. Hence one of the reasons why I want to upgrade the RAM in the NAS to 1GB, my NAS is an older version that only shipped with 256MB of RAM
Yea, I haven't done the math behind whether my connection is faster than the normal 100Mb connection, I just wanted to ensure I was utilizing my Gb connection as much as Possible.
I try not too, and I'm aware of the differences, sometimes I goof though. units was always my pitfall.
Feb 25, 2020 09:57 AM
OculiAquilae
Nov 19, 2018 02:24 PM
Sep 17, 2015 10:16 AM
IndycarFaster
Sep 11, 2015 02:52 PM
Nicho863
Sep 3, 2015 09:16 PM
