Laptop Question
Old Feb 25, 2006 | 04:35 PM
amisconception's Avatar
werd
Question Laptop Question
What the hell?
Why is my laptop's screen dim with the AC cord plugged in but bright with it unplugged and only running on the battery? It was the other way around but it's like confused or something...
How do I fix this?
Old Feb 25, 2006 | 05:38 PM
uu's Avatar
uu
to save power. You can change the setting under control panel --> Power Management.
Old Feb 25, 2006 | 05:49 PM
werd
i'll try, but it makes no sense. it's backwards.
Old Feb 25, 2006 | 05:55 PM
TallyCL-S's Avatar
about::blank
look on your keyboard, usually there is are brightness buttons....usually the 'Fn' button and something else. i don't think you can control that through power management.
Old Feb 25, 2006 | 08:06 PM
Sly Raskal's Avatar
I dunno how your laptop automatically changed.
have you tried using the FN key plus hitting the brightness buttons to adjust it and see what happens for when it's plugged in and not plugged in?
what kinda laptop is it?
Old Feb 25, 2006 | 09:49 PM
demolition_x's Avatar
Agean Blue Bishes
under power save in mine you can play with that kinda stuff. also the funtion buttin and some other keys mess with the brightness. it would help if you said what type of laptop you have
Old Feb 25, 2006 | 11:36 PM
werd
the FN buttons worked
thanks
Old Feb 26, 2006 | 02:34 AM
TallyCL-S's Avatar
about::blank
Gg
Old Feb 26, 2006 | 10:40 AM
proaudio22's Avatar
-S namyaC-
It remembers your brightness settings on ac power and battery. So if you dim it yourself on ac power, and brighten it up when using the battery - it will remember that.
That's how mine is because usually on ac power I'm at home in the dark and don't want it super bright. On battery, I'm usually at work or on a plane and want it brighter.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
