iTunes (windows) complaint about burning CD's
Old Feb 24, 2006 | 05:55 PM
Sly Raskal's Avatar
Thumbs down iTunes (windows) complaint about burning CD's
So I noticed a while ago that in iTunes (Windows version) that you can choose the speed to burn at when you burn your CD's.
Well my complaint is that why is it that on the Windows version, they have a list of speed available starting off at 2x I believe, but they only let you burn up to a speed of 24x or Max Available? My Burner supports 52x, but what if I had discs that only supported 48x? Well the outcome of that was basically my disc didn't burn correctly and it wouldn't play properly all the time, sometimes it would, sometimes it wouldn't. And when this happened I didn't know why until I went into the Options of iTunes and figured out this little computer-unfriendly feature of iTunes. So I set it at 24x and haven't had a problem since.
Even still, I wish they'd simply update the allowable burn speeds in the windows version to account for the higher speed cd burners that are out. I can't remember the last time I saw a cd burner that only supported up to 24x anyways. 48x burners have been out for a long time. at least longer than iTunes for windows has been out.
It's just annoying because I have to set my speed at 24x because the only discs I have are 48x compatible. I'm not impatient, I can go do something else while waiting for the CD. it'd just be nice if it supported a wider range of burner speeds.
My only guess as to why they don't do this, is possibly because they simply port the program from the mac version perhaps and don't bother changing anything to ensure it works
Anyone else have the same annoyance?
All around I think iTunes is a good program, this is just one of those little features that sticks out in my mind that bugs me.
Old Feb 24, 2006 | 05:58 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Macs have slow cd burner speeds....that's why :wink:
Old Feb 24, 2006 | 06:00 PM
Sly Raskal's Avatar
yea, that's what my initial guess was. It's just annoying that they don't update it for PC's.
Old Feb 24, 2006 | 06:48 PM
BC2G's Avatar
Registered Big Dog
whenever i burn a cd with i-tunes its like a 50/50 chance the whoel thing will work...
sometimes it only will play half the cd, other times all :ghey:
Old Feb 24, 2006 | 08:03 PM
Sarlacc's Avatar
The Third Ball
Never had an issue burning a CD with itunes....on a mac
Old Feb 24, 2006 | 08:09 PM
Whiskers's Avatar
Go Giants
Use Nero
Old Feb 24, 2006 | 08:18 PM
mt6forlife's Avatar
Apple didn't write the CD burning code in iTunes. They licensed a hack job from Gear Software. It a piece of shit and very pissy about cooperating with other CD burning programs.
Old Feb 24, 2006 | 09:50 PM
Sly Raskal's Avatar
if that's the case, then the culprit has been found!
Old Feb 24, 2006 | 09:51 PM
Sly Raskal's Avatar
did you check the burning speed on iTunes for your machine? check that and and lower it down to 24x and try burning a cd again and see if it helps.
cuz after I changed mine it burned just fine.
calrow
May 3, 2017 10:21 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
