Computer Help please Windows 98
Old Sep 17, 2004 | 04:35 PM
carcaze's Avatar
I currently running window 98. My PC have both a modem and a network card. We recently install a router to our broadband. But the PC keep trying to setup MSN with the modem instead of the network card. ANyway to make the it go through the network card instead of the modem ???
Any help here would be greatly appreciated.
Thanks in advance.
Old Sep 17, 2004 | 04:41 PM
cma2180's Avatar
What browser do you want to use for the internet IE or msn explorer???
Old Sep 17, 2004 | 04:51 PM
Edr0e's Avatar
Windows 98
Press windows key + pause break at the same time.
Go to network adapters tab then select the modem and go to properties. See if you can disable the modem.
If not try going to network connections and make sure the modem is disabled and the network card is enabled.
Old Sep 17, 2004 | 06:03 PM
MADCAT's Avatar
Christ, I haven't trouble shooted a 98 machine in over 2 years.
Old Sep 17, 2004 | 06:08 PM
drcookie's Avatar
If I could still remember ... try this ... if you are using IE, go to Internet Option, select "Connections" tab. If you have dial up properties installed, it should be shown inside the box. Below the "Dial-up and Virtual Private Network Settings", there are three buttons. Select "Never dial a connection". When you open up IE, it will not attempt to use the modem anymore.
Hope this helps.
Cheers !!!
Old Sep 17, 2004 | 06:30 PM
w1n78's Avatar
100k miles club
here's a guaranteed solution
get rid of windows 98. if you must run windows, run XP or at least 2000 pro. your system will run alot smoother. i don't even think microsoft themselves support 98 anymore
Old Sep 17, 2004 | 06:40 PM
Casper42's Avatar
04 TL 6MT NAVI ABP/Q
Hope this helps.
Cheers !!!
Other Programs like Outlook Express have a place in their options for "Connection Method" or something like that. Just make sure its on NONE or Never Dial.
Or if you will never use Dialup again, but might use the modem for faxing, you can go into Dial Up Networking and delete the entries to dial an ISP. This way you dont have to disable the modem itself and can still use it for faxing.
Old Sep 17, 2004 | 06:48 PM
Raheel's Avatar
Hope this helps.
Cheers !!!
That is the correct way to do it, your computer thinks you use dial up, u just need to fix it so it knows you are on broadband and it doesnt need to call in.
But Just upgrade to XP, you will notice a big Difference
Old Sep 17, 2004 | 07:35 PM
subframe3's Avatar
I still run '98 and had the same problem. I was able to fix it, but I did not have to disable the dial up adapter. Here's how I fixed it: In Control Panel click Internet Options then click the "connections" tab, then click "LAN settings". Select "automatically detect settings." Click "OK." When you are done, all of the dial-up options under the "connections" tab should be grayed out. I hope this help.
Old Sep 17, 2004 | 08:00 PM
Raheel's Avatar
I think its the same this as Dr. Cookie said above ^
Old Sep 17, 2004 | 09:05 PM
subframe3's Avatar
Actually his suggestion started out the same but then took a different path.
Old Sep 17, 2004 | 10:28 PM
Raheel's Avatar
O, than my apologies
Old Sep 17, 2004 | 11:14 PM
subframe3's Avatar
No big deal. I just hope the dude gets his problem fixed. Life is cool.
Old Sep 17, 2004 | 11:30 PM
drcookie's Avatar
There are many ways to accomplish the same task.
Cheers !!!
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
