Android: Phone News and Discussion Thread
Old Mar 28, 2011 | 02:06 PM
  #2401
is300eater's Avatar
I Shoot with a Camera
It says "T-Mobile" on top (front)
Here's a pic
Old Mar 28, 2011 | 02:17 PM
  #2402
CGFebTSX04's Avatar
Here's a pic
That is the T-Mobile Vibrant which unfortunately will not work with Canadian 3G unless you use Wind I believe. That one does not have the internal SD card problem though. All the international Galaxy S looks like this:
Note the button layout and it does not have carrier branding and has the Samsung logo on the top. It also has a front facing camera which the US carriers and the Captivate do NOT have except the Vibrant 4G.
If you're interested I may be selling my i9000M once Samsung gets it back to me hopefully in the next few weeks as it should be in repair right now. Although I don't know if I'm comfortable in selling a product that may break again in the future. I do have a copy of the receipt but this is the second time the internal SD Card corrupted and who knows if it'll corrupt again. Since you're probably from Canada it would be faster to get repairs as I have to send it out to Canada and wait back which takes a while with customs. I'll let you know if you haven't bought a phone yet.
Old Mar 28, 2011 | 02:35 PM
  #2403
is300eater's Avatar
yeah, I'm on Mobilicity which is the same AWS system as Wind... but that guy just texted me saying that he sold it anyways
Old Mar 28, 2011 | 03:17 PM
  #2404
CGFebTSX04's Avatar
Oh okay. In that case the T-Mobile Vibrant, Vibrant 4G and Nexus S should work fine for you. Most of the T-Mobile Vibrants go for like $300 brand new on eBay and shipping to Canada should be like $20. It might take 2 weeks depending on where its coming from and customs to get there. Then just unlock the phone yourself or ask someone who has a T-Mobile account to call in and ask for an unlock code since its free. The model number you want is the SGH-T959 for the T-Mobile Vibrant.
Old Mar 28, 2011 | 04:10 PM
  #2405
is300eater's Avatar
that's good to know... thanks
edit: damn, just out of curiosity, I went to Craigslist/Seattle and there are used ones there going for $200-$250... Fucking Canadian price gouging
Old Mar 28, 2011 | 04:21 PM
  #2406
CGFebTSX04's Avatar
Yeah $400 is pretty high for a T-Mobile Vibrant considering that it doesn't even have a front facing camera and the Vibrant 4G came out that has one. Also if you're interested in unlocking it yourself, here's the thread:
http://forum.xda-developers.com/show...ghlight=unlock
It consists of rooting the phone and downloading an app from the market. Its fairly easy to do. If that doesn't work, there's a manual way to do it that's a little bit more complicated.
Old Mar 28, 2011 | 04:23 PM
  #2407
is300eater's Avatar
thanks,
damn, there's a guy in Seattle selling his Nexus S for $380!
Old Mar 28, 2011 | 05:38 PM
  #2408
phee's Avatar
I got the Shifts
i just sold a vibrant for 250 wish i wouldve known
Old Mar 29, 2011 | 12:34 AM
  #2409
CGFebTSX04's Avatar
For the people running a custom ROM with a compatible kernel that uses the init.d script at startup, here's a tweak that speeds up your external SD card read and write times:
Link: http://forum.xda-developers.com/show....php?t=1010807
Many of us are disappointed about the reading speed of the SD Cards on our Android Phones. It doesn't matter if you have fast 10 Class SD Card, it performs very poorly on the Phone comparing how it performs on the PC.
The clue is the Cache size for reading from SD Card. It's set to 128 KB, on some ROM's even to 4 KB!
For advanced users and those who know how to use ADB, you can test the different buffer sizes to compare the read/write speeds on the fly instead of flashing each different zip file and then rebooting and retesting.
Code:
Connect your phone to your computer then open up a command prompt or open up a terminal on the phone.
>adb shell
$su
#cd /sys/devices/virtual/bdi/179:0/read_ahead_kb
#echo "128" > /sys/devices/virtual/bdi/179:0/read_ahead_kb
Run the SD tool app to test the new buffer size and compare
Change the value in red above in the command to any buffer size. By default, most phones keep it at 128 kB which is pretty small. Try these other values: 1024, 2048, 3072 or 4096 and compare each time using the SD tool app from the market.
To verify the cache buffer size, use the "cat" command in a command prompt or terminal.
Code:
>adb shell
$su
#cat /sys/devices/virtual/bdi/179:0/read_ahead_kb
Once you've figured out the buffer size that gives you the best speed, download the buffer size you want to flash in the first post in CWM. Your ROM will need to be able to use the init.d script at startup so it gets reapplied automatically at boot. You can verify this by looking for your /system/etc/init.d folder. If its there, then the script will work. Otherwise, you will need to reapply it manually after each reboot or use a scripting app that'll run it each time.
For those who don't know how to use ADB or terminal, just flash each zip file in the first post, reboot and compare each time using the SD tool app. Its a longer and more tedious process but once you find the buffer size you want, just flash it and forget it.
Old Mar 29, 2011 | 12:42 AM
  #2410
Mizouse's Avatar
Here's a pic
my friend has this phone on tmobile, says the phone sucks.
Old Mar 29, 2011 | 12:45 AM
  #2411
CGFebTSX04's Avatar
SD Card booster from the market also does the same thing if the post above went over your head. lol. But it'll cost you money:
https://market.android.com/details?i...=search_result
You will still need root but I don't think you need a init.d compatible kernel.
Old Mar 29, 2011 | 06:36 PM
  #2412
is300eater's Avatar
okay, I need you guys' opinion (quick)...
there's T-Mobile myTouch 3G "Slide" (updated to 2.2) f/s locally on CL, which I'm tempted because I like the slide keyboard (even tho, the screen's res isn't as nice and it's smaller)...
http://www.gsmarena.com/t_mobile_myt...slide-3270.php
or for $100 another guy is selling his Nexus ONE...
which one should I go with? I'm suppose to be meeting up with the guy with Nexus ONE pretty soon...
Old Mar 29, 2011 | 06:48 PM
  #2413
speedemon90's Avatar
If your into custom ROMS and like playing with the phone go for the Nexus One. Also if you want the lastest updates. Nexus One is running 2.3.3 I believe. And maybe a bigger update in the summer hopefully.
I dont know the specs of the mytouch3g though. How is the hardware compared to the nexus one?
Old Mar 29, 2011 | 06:50 PM
  #2414
CGFebTSX04's Avatar
For $100 I'd definitely get the Nexus One. Why? Its Vanilla Android and will get updates first just like the Nexus S. Its very well supported by devs at XDA and its one of the easier phones to mod. So I'll make a pros cons list.
Nexus One
Pros: Vanilla Android, Easily customizable, Great dev support from XDA and Google, Will get updates first because its a Nexus phone, Slightly faster than the MT3GS
Cons: Multi-touch is a little wonky because HTC cheaped out on the sensor (won't really notice it that much), No physical keyboard (Again, won't notice it much because you can just get any keyboard you like in the market)
Get the Nexus One if you want to have peace of mind in terms of Android updates. The MT3G Slide will probably not get Gingerbread officially. XDA will probably bring it but why wait for them when you get it first with the Nexus phones which are currently running Gingerbread now officially.
Old Mar 29, 2011 | 06:55 PM
  #2415
is300eater's Avatar
alright, thanks guys
Old Mar 29, 2011 | 09:57 PM
  #2416
is300eater's Avatar
so, I picked up the Nexus ONE, and it's pretty cool... the previous owner had a ton of contacts, is there a fast way to delete them all? (I'm wondering if any of those girls are cute )
Old Mar 29, 2011 | 10:07 PM
  #2417
CGFebTSX04's Avatar
lol. was the previous owner running a custom ROM by chance?
You could do a factory reset:
Homescreen --> Menu --> Settings --> Privacy --> Factory data reset
This wipes everything and should prompt for your GMail to sync with.
Old Mar 30, 2011 | 05:03 AM
  #2418
is300eater's Avatar
^^^thanks,
a couple things, loving the tethering... I know I'm late on this, and it really isn't a big deal anymore, but I think it's great!
the other thing, the camera's not working... I guess this is a bug... still trying to figure it out
Old Mar 30, 2011 | 08:33 AM
  #2419
GIBSON6594's Avatar
My Garage
^^^thanks,
Have you checked if it's rooted? If it's a nexus one, it probably is.
Old Mar 30, 2011 | 10:19 AM
  #2420
CGFebTSX04's Avatar
^^^thanks,
Hopefully its not a hardware issue. Maybe you should do a whole reflash of the official Gingerbread update and wiping your cache, dalvik cache and do a factory reset in recovery:
http://phandroid.com/2011/02/24/manu...3-gingerbread/
Old Mar 30, 2011 | 01:40 PM
  #2421
yea if somethings not working do a reflash of stock 2.3.3 like he said ^
Old Mar 30, 2011 | 01:48 PM
  #2422
is300eater's Avatar
Alright, I'm just such a noob with that stuff. I clicked on the link and just from reading, I was kinda lost after after step 2 or 3 But I'll try later
Old Mar 30, 2011 | 02:54 PM
  #2423
GIBSON6594's Avatar
My Garage
Don't get intimidated. Most of this stuff is easier than it seems.
Old Mar 30, 2011 | 02:57 PM
  #2424
is300eater's Avatar
okay, so what does this mean? "Rename the file update.zip and copy it to the root of your microSD card via USB."
Old Mar 30, 2011 | 03:18 PM
  #2425
GIBSON6594's Avatar
My Garage
If using XP, simply rename the file "update.zip" (if using Vista or higher, rename it to simply "update" as Windows will determine the file type and automate the extension).
Then mount your SD card (with either your phone or a card reader) and put the renamed file in the top directory. That means it's not within an other folders and is on the highest level of your SD card.
Old Mar 30, 2011 | 04:14 PM
  #2426
is300eater's Avatar
ugh, I get to the last step, which is "apply sdcard:update.zip" and it'll attempt to update, but then says there's an error in the sdcard
I've followed the steps like 5 times now
Old Mar 30, 2011 | 04:56 PM
  #2427
GIBSON6594's Avatar
My Garage
What version of windows are you using?
Old Mar 30, 2011 | 05:03 PM
  #2428
is300eater's Avatar
Windows 7 and NO, I didn't rename it with the word "zip"...
but I think I may have figured out the problem... well, I'll let you tell me if I'm right...
my N1 is currently 2.2... in order to go 2.3, don't I have to update to 2.2.1 first and then 2.2.2... AND THEN 2.3.3?
Old Mar 30, 2011 | 05:06 PM
  #2429
GIBSON6594's Avatar
My Garage
http://android.clients.google.com/pa...8.656099b1.zip
Try this zip.
Old Mar 30, 2011 | 05:19 PM
  #2430
is300eater's Avatar
didn't work either...
but I noticed some deviations from the steps....
step #6 where it says "When you see the triangle with an exclamation point symbol, press the “Power” and “Volume Up” buttons at the same time."
well, that triangle with exclamation point never came up... and just goes straight to the next step...
and also, in the last step... #8 where it says "When the screen displays “Install from sdcard complete” select “reboot system now” and wait for the phone to power back up."
well, for me... the word "complete" isn't there... does that matter?
thanks for being patient with me but right now I gotta go run some errands, will try again tonight
Old Mar 30, 2011 | 06:10 PM
  #2431
CGFebTSX04's Avatar
Can you tell us which ROM your phone is on now?
Homescreen --> Menu ---> Settings --> About
Scroll down and see what the build number is. It almost sounds like you don't have a factory recovery.
Old Mar 30, 2011 | 06:40 PM
  #2432
is300eater's Avatar
Not sure what's "ROM" but does word "cyanogen" (or something like that) mean anything?
Old Mar 30, 2011 | 07:03 PM
  #2433
ParaSurfer1979's Avatar
Originally Posted by DarkSithCL
Thanks for the info on the 3 D Evo!
I was asking my wife if she wants one... I will send her the video...
Also... the Epic 4G went to gingerbread on the past day or so... one of the guys at work got the update... its pretty sweet ... funny watching the update take over the phone ...
Epic 4g gingerbread looks nothing like an HTC phone because of sense ui. the EVO 3D's version of 2.3 will be on EVO 4G in the next few months and Thunderbolt by this summer.
Old Mar 30, 2011 | 07:18 PM
  #2434
I agree. Some of the none official roms left some hardware not working. Cameras being the main issue. Put the official update on. get insurance on phone so if its a hardware probhlem, they'll fix it.
Old Mar 30, 2011 | 07:20 PM
  #2435
GIBSON6594's Avatar
My Garage
YES, jesus. He's the biggest developer on Android.
You're running a custom recovery. CG is right.
Basically you're not running stock Android.
Now the question is do you want to go back to stock?
Either way, go back into recovery and go to wipe. Wipe everything you can...Dalvik, cache, battery stats. Then restart and see if your camera works.
From there, we can either reflash Cyanogen mod or put your stock recovery back on and reflash stock Android.
Old Mar 30, 2011 | 07:25 PM
  #2436
is300eater's Avatar
I told you guys I'm a total noob
Old Mar 30, 2011 | 07:47 PM
  #2437
GIBSON6594's Avatar
My Garage
I'd stick with Cyanogen. I have it on mine and many nexus one users do as well. It's very well featured.
Wipe everything and click the below link. Download the file on top called update-cm-7.0.0-RC4-N1-signed.zip and flash it.
http://download.cyanogenmod.com/?device=passion
Old Mar 30, 2011 | 08:43 PM
  #2438
DarkSithCL's Avatar
Be Strong AND Courageous!
fo sure... I was scared to root... now everyone who sees how cool just a few of the rooted features are on my EVO is wanting their rig rooted....
BTW... congrats on ur Nexus One is300 !
Old Mar 30, 2011 | 09:13 PM
  #2439
is300eater's Avatar
I'll give it shot
thanks man, I'm loving this phone, despite the camera issue
Old Mar 30, 2011 | 09:26 PM
  #2440
CGFebTSX04's Avatar
Yeah, Cyanogen is one of the biggest and probably best custom ROMs for Android at the moment. You're running an unofficial ROM. You can upgrade to a newer version of CyanogenMod since they just released RC4 today with some more fixes.
http://forum.cyanogenmod.com/topic/1...30-march-2011/
To make it easy for you, I suggest you use ROM Manager from the market (It should already be installed on your phone actually):
Open up ROM Manager. Confirm your phone. Hit Download ROM. Scroll down to Cyanogenmod RC4. It'll download the ROM and GApps. Click on it when its done in your notificaiton bar. It'll ask you to backup and wipe cache. Just hit wipe cache. No need to backup since the data isnt yours. Let ROM Manager do its thing and when it reboots you should have a fresh clean Cyanogenmod ROM.
Watch this video to learn how to flash Cyanogenmod using ROM Manager:
http://www.youtube.com/watch?v=B9ZpW7Ms7eM
Note that the steps are similar just different files.
