DIY A-105: Power Steering Whine fix
Old Dec 3, 2009 | 01:33 AM
Majofo's Avatar
A lot of you new members are probably experiencing a power steering whine in cold temps < 60F, which goes away as the engine compartment gets warm. The culprit is the o-ring on the PS pump inlet pipe. The o-ring has become glazed & lost it's original elasticity so it's contracting more than spec and allowing air to enter the pump when the temps drop. The fix is simple, replace the o-ring. For you guys who are a bit timid mechanically.. here's a simple DIY to guide you. I had a video but I couldn't find the original file. Although this should be very straightforward. Enjoy.
Tools Needed:
  • 10mm wrench
  • shop towels / paper towels
Parts Needed:
  • New O-ring P/N: 91345-RDA-A01 (orange)
Part 1
Part 2
Part 3
Part 4
Part 5
If I left anything out, feel free to add it. I changed the PS with new Honda PSF. I might be switching up to Redline Syn PSF since it's been almost a year since the change, let me know if you guys want a DIY on it.
Old Dec 3, 2009 | 02:27 AM
erick3's Avatar
thanks majafo VERY useful diy!
Old Dec 3, 2009 | 04:52 AM
hata_61's Avatar
nice,cheap fix for a really annoying problem. but if i remeber correctly there was a TSB on this.TSB 07-060 i think.
Old Dec 3, 2009 | 08:47 AM
Inaccurate's Avatar
Majofo, you da' man !
Great illustrations. I like those red balloons...... Note to myself - steal the red balloon idea for my pics too.
Old Dec 3, 2009 | 09:57 AM
Majofo's Avatar
Thanks for posting up the TSB hata
http://www.in.honda.com/Rjanisis/pubs/SB/B07-060.PDF
The torque on the ps inlet bolt is only 8 lb.ft! That's almost finger tight so don't torque it down very much. Inacc the red ballons are from MS Word. Just change the fill color & transparency. I also forgot to include to rub a little ps fluid on the new o-ring.. I was conflicted with my junk ps fluid but I did so anyways. If you don't have fresh ps fluid around you can dip your pinky in the res & just smear a coat around the new o-ring before replacing the inlet tube.
Old Dec 3, 2009 | 09:58 AM
swoosh's Avatar
takin care of Business in
damn no warm apple pie ???
well GREAT DIY !!!
shit that rhymed !!!
Old Dec 3, 2009 | 10:29 AM
BuffBakerGA's Avatar
well GREAT DIY !!!
This is no time... to rhyme.
Old Dec 3, 2009 | 11:35 AM
swoosh's Avatar
i know its no time to rhyme
but i thought it was worth a dime
not just pennies which u put in
in ur shoes i have been
got flamed all the time
thats why now am spitting a rhyme which is worth a dime
lets cut this shit short
it aint earning us any bread
so lets just shut up
and get back to the thread !!!
Old Dec 3, 2009 | 12:33 PM
Majofo's Avatar
Swoosh.. you just spent the last hour writing that huh?.. don't lie..
Buff Baker.. from sugar hill.. I'll save you some time by updating your rhyme:
a hip hop the hippie the hippie to the hip hip hop, a you dont stop the rock it to the bang bang boogie say up jumped the boogie to the rhythm of the boogie, the beat ...by, the hibby dibby hip hop and ya don't stop!
Please stop.
Old Dec 3, 2009 | 01:36 PM
swoosh's Avatar
^^^ dude actually less than 6 minutes from the other dude posting to me writing.....LOL
but yeah as i ended my rhyme i said lets stop wasting time and get back to the PS whine !!!
and am a brown dude LOL !!!!
Old Dec 3, 2009 | 02:36 PM
Majofo's Avatar
Originally Posted by Majofo
Please stop.
fixed.. lol.
I wouldn't have guessed from your previous post.
Old Dec 3, 2009 | 03:30 PM
swoosh's Avatar
^^^ None the less great DIY....this forum saved me $600 last winter....had exactly the same problem, but had the dealership fix it for me....didnt have to pay, so might as well !!!
Old Dec 12, 2009 | 10:17 PM
sick puppy's Avatar
I have the same issue. I'll see if the dealer will fix it under the "goodwill clause" as listed on the SB and report back. If not, I'm more than capable of completing this easy fix.
2005 TL w/ 91k
Old Dec 13, 2009 | 08:53 AM
DanL's Avatar
8 lb/ft is a lot more than finger tight -- perhaps you're thinking of 8 lb/in, not 8 lb/ft. Granted, 8 lb/ft isn't a lot and you do need to be careful not to twist off the bolt or strip the threads.
Personally, I think anyone who does any DIY on their car needs both a lower-range 3/8" and an upper-range 1/2" torque wrench. Even a cheap Harbor Freight set is better than nothing. But if you don't have a set, it's not too hard to visualize in your head how much force 8 lb/ft is. It's simply the amount of force applied by hanging an 8 pound weight on the end of a one foot long socket wrench. If you're using a small 4" long box end wrench, you'd need to apply 24 lbs of force to the end of the wrench (4" is 1/3 of a foot so you need to apply 3 times more downward force).
Old Dec 13, 2009 | 09:12 AM
Majofo's Avatar
I wholeheartedly agree, but the only thing is it's such a tight squeeze to access that 10mm bolt that my 3/8 torque wrench wouldn't fit so I ended up feeling it out. My main concern was to not strip the threads, that's a pretty terrible feeling & something that eventually happens to you when you do DIY projects. It's happened a couple times to me while using a torque wrench when swapping the shocks & replacing brake pads.
Old Dec 14, 2009 | 09:12 AM
msurwl's Avatar
Unbelievable timing on this post. My '05 TL started making this noise yesterday morning.
Old Dec 14, 2009 | 11:17 AM
swoosh's Avatar
^^^ really glad Majofo made a DIY !!!
a similar thread saved me around $600 last year !!!! they didnt have a DIY thow !!!
Also Majofo does the 2G TL act in a similar manner, any clues ??? and I recently saw some air bubbles in my PS reservoir, is this normal or should i replace the o-ring ???
Old Dec 14, 2009 | 12:03 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
I took my car in last week to get this whine fixed. They said it wasn't the O-ring known issue, but instead it needed a new steering rack and pump. Grrrr...
Acura split the cost with me so I ended up having to pay $1050. I'm not done working with them on it as I don't think a steering system should fail after 106k miles on a decent car.
Old Dec 14, 2009 | 12:47 PM
Majofo's Avatar
Talk to tripnbeats about that.. poor guy has replaced 3 pumps & 8 racks so far.
You're not insinuating I own a 2G TL are you? lol.. I did find a few related threads on that side but nothing like the 3G occurrence. If there's a very noticeable bubbling then there must be a air leak somewhere, hopefully not a fluid leak as well. I'd investigate it a little further.
Old Dec 14, 2009 | 12:50 PM
CarrieLynn's Avatar
WTF lol im soooooooooooo glad i just found this thread!! Ive been hearing this for a few days now and had no clue what it was. I dont remember this problem last winter tho....
ill fix it this weekend
good info!
Old Dec 14, 2009 | 02:07 PM
swoosh's Avatar
Nah....there was some thread where i provided the link to this thread, only the hear the owner had a 2G....so hence just wanted to confirm that.....
Yeah there was some bubbling....not a fluid leak IMO coz the fluid level would do down gradually.....but yeah a definite air leak....prolly time to get a new o-ring !!!
Old Dec 14, 2009 | 06:19 PM
deepblue626's Avatar
can anyone please let me know how do i change the PS fluid after i done this?
Old Dec 14, 2009 | 06:20 PM
also will it be an problem if there is air in the flud?
Old Dec 14, 2009 | 07:36 PM
salu8819's Avatar
"Let's Do This"
Majofo i have the same whine from the PS every morning......But its LOUD and annoying, i hope this will fix it.
Old Dec 14, 2009 | 08:42 PM
CarrieLynn's Avatar
yup, mine too!!
need me to fix yours for you? lol
Old Dec 15, 2009 | 12:50 AM
05silverbulleTL's Avatar
nice fix made nicer! see to find out...
nice tip man. just saw another topic on this...
thought i add something to it for those that want to go out of the way to cure this problem.
in picture 5 of his post, find the p/s fluid neck off of another older model honda and replace it with the metal piece from that pump. that piece (sourced cheaply from a wreckign yard if possible) along with replenishing the brittle old o-ring will cure the expansion/contraction problems in your noisy cold p/s pump from air entering into unit.
ok, i have more honda tricks... but i don't have drive this car much.
will postr more solutions if i see them and find an answer to it. ok, bye.
Old Dec 16, 2009 | 12:33 PM
Majofo's Avatar
No it's not a problem, the air is going into the pump and exiting the res. There's not a hydraulic issue like air in the braking system.
I'm planning on changing mine again soon. I'll do a DIY guide when I'm done. The main method is switching the return pipe & letting it drain out the system until it's dry by turning lock to lock while the car is on. I think there's another method of turkey basting the res, turning lock to lock & repeat but I'm not so clear if that really gets the old stuff out effectively.
Tell me about it.. My first car had some shaved gears on the flywheel so when I would turn it on it would make the most horrendous noise, although the PS whine is annoying & somewhat embarrassing it still ranks below that but slightly above squealing brakes & a worn AC compressor bearing.
Old Dec 16, 2009 | 06:03 PM
bring the car to dealer today, they will fix for me for free.
Old Dec 16, 2009 | 09:47 PM
allykahn's Avatar
I started getting the whine last week, extremely loud. Took it to the dealer since I have an extended warranty. They replaced the power steering pump and fluid. I only have 63,000 miles.
Old Dec 17, 2009 | 08:23 AM
Please stop.
Your rap is crap, it stinks all over the map...
I went to Jackson Acura in Alpharetta, GA and they did the recall for free even though i was out of warranty... Whine is gone. They actually replace the hose assembly that has the rubber gasket in it. They also did the wiper motor breather tube for free as well... +1 for Jackson Acura.
Old Dec 17, 2009 | 10:29 AM
Indy04TL's Avatar
I started having this noise last Monday, 12/14 on my '04 TL with 52K miles. Being not much of a DIY person, I took it to a dealer and they wanted to replace PS pump, etc. I told them to try your fix first. (I had had the TSB done last summer). They did the O-ring and changed the fluid. Guess what--NO MORE WHINING NOISE!! Surprise, Surprise!! They even called me back the next day to make sure everything is OK!! Charged me $75, but that is OK. Thanks for your help, I am sure it saved me several$$$.
Old Dec 17, 2009 | 10:55 AM
swoosh's Avatar
^^^ they lived up to the expectations of being a stealership.....GAWD DAMN !!! $75 for this.....
but yeah if you wouldve gone with the PS pump you would be looking at around $1000 parts+labor.....
Old Dec 17, 2009 | 12:02 PM
salu8819's Avatar
"Let's Do This"
Going today to pick up the O ring..............It cost .77 cents LOL
Old Dec 17, 2009 | 12:11 PM
just drup off the car, they will replace the power steering hose and 0 ring and wiper motor under recall. this is an recall you do not need to do it yourself.
Old Dec 17, 2009 | 12:20 PM
Sangana21's Avatar
I get that squealing noise when its moist outside. I was told its just my belts, that they need to dry. But its getting kind of ridiculous. It sounds like I am driving a schoolbus. I never had this problem with my RSX type S or my civic. Could it be the same thing?
Old Dec 17, 2009 | 12:28 PM
salu8819's Avatar
"Let's Do This"
already took it in for the recall when it was first annouced.....it still does the noise. plus i no longer have warranty
Old Dec 17, 2009 | 12:32 PM
is the o ring fix the problem?
Old Dec 17, 2009 | 12:35 PM
Fulani has a TL's Avatar
Alot of us already had the recall done. But we still get the squeel/whine.
I did this this morning. All good now.
a 66 cent piece of rubber fixed it gotta love discounts
Mod's a possible addition to the garage?
Old Dec 17, 2009 | 01:04 PM
Majofo's Avatar
Most everyone who had the recall done also had this problem as Fulani said so it's safe to say most shops aren't replacing the o-ring.
Old Dec 17, 2009 | 06:40 PM
salu8819's Avatar
"Let's Do This"
Just installed the new O ring with my father LOL............... hopefully it works and gets rid of the LOUD annoying noise. Have to wait tomorrow morning after the motor is cold, ill post up the results... Oh yea while we were under the hood i found out my motor mount is broken FML!!!! i was wondering why my shifts werent smooth LOL
