A/C blowing in spurts
So I started my 04 today, and when I turned on the AC (auto) it started blowing hard then stopped totally then on again, it actually does this is 5-10sec intervals. Then about 3-5min into the drive it stops and AC functions normally again. It seems to only do it when cold or at beginning of startup..
I was thinking possilbe blower motor? Someone said expansion valve, but I don't think that would actually cause it to stop blowing.
Anyone experience this?
AC motor switch / transistor / resistor.
#15 - 79330-S6M-941
I had the same issue and took the car into the dealer and had the blower motor replaced under warranty. When I told the service dept what it was doing they just ordered a new blower and said its a known problem.
No reason to replace a whole engine if it only needs an oil change, know what I mean.
You can access the transistor below the glove box (not behind glovebox), just remove the lower cover (should be 3 clips and a release pin in the back). Disconnect the 4 pin connector and replace the transistor switch (should be a couple of fasteners in place). Put it back together and you're done.
johnny3 (10-14-2011)
Glad it worked out Schul!
Exact same issue here. The past 2-3 weeks, when I first get into my car I can hear/feel the blower turning on and off in spurts. Then after a few minutes it all goes back to normal. Today when I got in my car at work....nothing....said f'it and started driving home (with my seat heat on high) and about 4 minutes later it comes on and works perfectly.
Guess I will be calling my local Acura and Honda dealers in the morning to find their pricing and see if I am lucky enough to only have this be my issue.
I hate dealer markup some days. $53 list, $64 at the local Honda dealer, $68 at the local Acura dealer, and $40 from Delray. Guess that is the price you pay for having it in stock and available immediately.
And fixed. Less than 5 minutes to replace the transistor. I spent more time looking for the "clips" that holds the lower panel in place before I realized you just pull it down. Two screws hold the module in place. My drive into work this morning was nice actually having a functional heating/defrost system.
Biggie_B
02-26-2017 11:14 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
