gas thread
Old Jan 3, 2012 | 01:37 PM
spaceboy's Avatar
gas thread
i have been a fan of Chevron and never had any Shell or 76...at least not in my TL...recently my friend told me he once put in Shell and notice engine is a lot quieter compare to Chevron...he has a 09 Mazda 3 and he usually put in 89 octane.
anyone here experience any difference on their TL with different brand of gas???
Old Jan 3, 2012 | 01:41 PM
most top tier gas stations are the same.
as long as you're putting in 91+ then you will be fine.
Old Jan 3, 2012 | 01:46 PM
Flipster23's Avatar
Your friend isn't doing anything putting 89 in his 3. The 3 doesn't call for 89 or 91.
Like Justin said Top Tier gas, is all the same out here Chevron, Shell, 76 those are the only 3 I use for all my cars as well.
My dad uses Sam's Safeway and AM/PM in one of his trucks and has been running fine since 2005 when he bought it brand new.
Old Jan 3, 2012 | 01:47 PM
Gfaze's Avatar
S E L L
Your friend is delusional.
Old Jan 3, 2012 | 04:15 PM
aznboi2424's Avatar
Top Tie, 91 octane only for my car. Doesn't matter what brand.
Old Jan 3, 2012 | 04:20 PM
spaceboy's Avatar
do u guys think a bottle of chevron fuel cleaner thing every 6 month or one year will make it cleaner???
Old Jan 3, 2012 | 04:25 PM
aznboi2424's Avatar
It certainly wont hurt. But I thought that Shell and Chevron already has cleaning agents in the fuel. I bought a bunch of additives when they are FAR and I'm still going through them.
Old Jan 3, 2012 | 04:27 PM
spaceboy's Avatar
^^ yeah thats what i thought...91 cleans enough i guess
Old Jan 3, 2012 | 04:28 PM
Flipster23's Avatar
If you use non top tier gas then it wouldn't hurt.
Old Jan 3, 2012 | 04:29 PM
spaceboy's Avatar
so u will even take Arco, Valero or Rotten Robbie 91 octane??
Old Jan 3, 2012 | 05:05 PM
vic06b's Avatar
Old MT TL
my mom got a Toyota Prius and those things are really sensitive to brands of gas. She has tried filling up 3 times at every brand of gas. Said the ones that she had best mpg at was: in order.. 1. Costco, 2.(tie) Chevron & Shell then 3. 76
so now we switched from Chevron to Costco but thats just my family and I
Old Jan 3, 2012 | 05:06 PM
vic06b's Avatar
Old MT TL
oh and for the True Love (TL) only 91
Old Jan 3, 2012 | 05:10 PM
Flipster23's Avatar
I used to use Costco but then I moved further away from the Costco..
Old Jan 3, 2012 | 05:28 PM
carcrazy's Avatar
7th Gear
i use shell 91 & only shell... i dont like mixing gas brands with others... but thats just me... the only time i really switch gas is when i want to really clean out is when i use 76, 100 octane
Old Jan 3, 2012 | 07:44 PM
clean out and 100 octane!?!?!?
do you know what you're talking about?
do you know the benefits of using 100 octane?
certainly not for cleaning.
Do you know why we need a high octane for engines?
Old Jan 4, 2012 | 01:32 AM
spaceboy's Avatar
i m curious, why do TL require premium?
Old Jan 6, 2012 | 07:54 PM
aznboi2424's Avatar
Because of our high compression engines. If you use lower octane gas with high compression engines, you'll get early detonation. This will cause knocking in engines but today's engines come with a knock sensor that will retard the timing so it will allow the engine to run on lower compression at the cost of performance.
It was a type, I meant Top Tier.
Old Jan 19, 2012 | 12:55 AM
lakesh0wtime's Avatar
So is 91 from Arco okay? I live a block away from one and all the other gas stations have way higher prices.
Old Jan 19, 2012 | 09:13 AM
Flipster23's Avatar
Arco sucks
Old Jan 19, 2012 | 11:54 AM
Hapa DC5's Avatar
אני עומד עם ישראל
I try to stick with top tier, but in the past have used Safeway, Arco, etc. Just 91 in my Infiniti.
Old Jan 19, 2012 | 05:04 PM
aznboi2424's Avatar
Arco gas won't blow up your car but it's not a Top Tier station.
Old Jan 24, 2012 | 06:27 PM
spaceboy's Avatar
Top 3 on my list...Chevron>Shell>76
Old Jan 24, 2012 | 06:49 PM
DCdonDubby's Avatar
Sunoco > other stations [./]
Old Jan 25, 2012 | 09:08 AM
Flipster23's Avatar
We don't have that in Sac.
Old Jan 25, 2012 | 01:41 PM
spaceboy's Avatar
Not SJ either...
Old Feb 28, 2012 | 09:33 PM
Hi speed's Avatar
runnin a little boost
If anyone is looking for 100 octane we have a 76 station here in SJ that sells it from the pump. $7.25 last time I was there. Good for counteracting heat soak in the summer and few extra HP in the 3G TL's. I don't know the exact address but it's near the Capitol auto mall.
Old Feb 29, 2012 | 03:50 AM
Batosai's Avatar
bye Acura, hello Toyota
Lemme see...the CL I used 91 pisstane Chevron, then on the Evo it was 91 pisstane Chevron, presently the MR2 uses wherever the hell it's cheapestane....heheheheh. But that's about to change.....
Old Feb 29, 2012 | 09:21 AM
Flipster23's Avatar
Boostin!
Old Mar 2, 2012 | 12:16 PM
jjdrivesajazz's Avatar
i use anything 91 octane, gasoline has to pass regulation in order for it to be sold in california, the only difference from shell to chevron to arco is the additives they put into it
spoiler900
Oct 10, 2015 06:48 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
STL TL-S
Sep 23, 2015 08:52 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
