Midwest Illinois, Indiana, Iowa, Kansas, Kentucky, Michigan, Minnesota, Missouri, Nebraska, Ohio & Wisconsin
105k Maintenance time for the TL-S
Old Oct 2, 2014 | 01:40 PM
imakeholesinu's Avatar
Ok boys and girls (specifically in the STL, MO area) it is almost time for my 105k maintenance.
I've received quotes from Frank Leta ($2000+) and jh ($1600). This includes Timing Belt, Tensioner, Water Pump, Spark Plugs and Valve Adjustment.
I do have a coupon from Acura that will save me 10% if I take it to the dealer.
Any other places I should check?
Old Oct 2, 2014 | 01:49 PM
check out Honda dealerships too.
Old Oct 9, 2014 | 12:26 AM
nist7's Avatar
Huh, interesting point. Would they do work on TLs though? I mean we all know that underneath the Accord and TL is similar but never heard of Honda dealers doing work on TLs....heh
Old Oct 9, 2014 | 03:44 PM
1black_seven's Avatar
Slot Machine Lubricator
Yes, they will.
Just don't try to take a Honda to an Acura dealer, they don't have time for your riff raff.
Old Oct 9, 2014 | 03:49 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
They absolutely will and will be happy to do so. The only thing they can't / won't do is warranty work. Warranty work needs to be done by an Acura dealer.
Old Oct 10, 2014 | 01:15 PM
Well it turns out I just got an e-mail from Frank Leta and they are going to give me $500 off of any service. Combine that with the coupon I got from Acura for 10% off the major maintenance I may be scheduling my maintenance through the dealer.
I will still call a couple of Honda dealers around here to see what they'll charge me and if it is anything lower than what Frank Leta will charge with my discounts.
Thanks for the input all, I'll let you know what I end up deciding on and update after the maintenance is complete. I do have the extended dealer warranty on the car as well which has a little less than 2 years left on it.
Old Oct 10, 2014 | 03:41 PM
NBP04TL4ME's Avatar
Just make sure you can double dip on the coupons (dealer and Acura). Typically dealers will only honor one.
Old Oct 10, 2014 | 07:05 PM
nist7's Avatar
Originally Posted by 1black_seven
Yes, they will.
Nice! Good to know! And so I'm assuming then prices may be cheaper as well in general?
If that's the case then I will definitely look into Honda when it's time for my second timing belt service
Old Oct 10, 2014 | 07:13 PM
NBP04TL4ME's Avatar
Yes. Honda labor rates are cheaper and the parts are as well.
Old Oct 10, 2014 | 07:53 PM
nist7's Avatar
Makes sense of course. But pretty messed up though cause basically the parts come from probably the same OEM sources and it's just stamped "Acura" instead of "Honda"
I'll definitely keep this in mind next time I need dealer service.
My local Acura dealer has a real posh lounge area with big ass TVs and a drink/food bar with two people serving up food and coffee. Definitely part of the reason it's so expensive! For me, I could care less about the waiting area as long as the work is done right. But for the clientele of Acura they gotta keep up that "posh" "uppder middle class" image I guess.
Old Oct 10, 2014 | 07:57 PM
NBP04TL4ME's Avatar
Yup and same holds true for Nissan / Infinity, Toyota / Lexus, VW/Audi ..........
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
forrie
Sep 15, 2015 09:57 AM
MyGuti
Sep 12, 2015 06:52 PM
ahsm
Sep 9, 2015 08:35 AM
