3rd light install wiring
Old May 19, 2020 | 03:38 PM
Acura83's Avatar
Does anybody have a link or a diy instructions on wiring the tailoghts to the 3rd light thanks.
The harness is there but idk what wires specifically to attach from the 3rd light install.
This is where I’m at the wiring
Old May 19, 2020 | 06:57 PM
DaIll1's Avatar
The 'T' off the main harness is under the driver side 'C' pillar (between the rear door window and back glass) cover over the package tray behind the rear seat back. There is 2 wires only that go up under the headliner and Blue is +.
edit: Your picture is into fender and you won't find it there.
Old May 19, 2020 | 07:13 PM
Acura83's Avatar
Gotchu
Old May 20, 2020 | 12:57 PM
Acura83's Avatar
Am I in the right direction I’m looking into that small dark circle.
Old May 20, 2020 | 01:14 PM
DaIll1's Avatar
Sorry man, the only way to access it without a sawsall is from the inside of cabin. It is in the 'C' pillar (rear roof).
You have to remove this cover to get to it. This is the closest thing to social media I do.
Old May 20, 2020 | 01:16 PM
Acura83's Avatar
Thanks bro I really appreciate the help 🤝
Old May 20, 2020 | 01:22 PM
Acura83's Avatar
I just unplug it (yellow connector) and wire it?
Old May 20, 2020 | 01:25 PM
DaIll1's Avatar
It's all good. There is so much to learn about cars and the jargon of them.
I saw your pic. I tapped into the lead running up. I don't think that connector is a good spot unless that connector is where the harness going up connects. There is only 2 wires and the Blue is +.
Mine didn't have a connector, it just teed off the main harness.
Old May 20, 2020 | 01:49 PM
Acura83's Avatar
Is it this wire. ?
I hope it is lol
Old May 20, 2020 | 01:57 PM
DaIll1's Avatar
Is it this wire. ?
I hope it is lol
It looks like that connector leads somewhere else. I tapped into wires here.
Old May 20, 2020 | 02:03 PM
Acura83's Avatar
Ok I’ll cut it open and see the wires 🤟
Old May 20, 2020 | 02:17 PM
Acura83's Avatar
I just plug both wires to the blue wire ?
Old May 20, 2020 | 02:19 PM
DaIll1's Avatar
Cut blue wire only. one side goes to flasher. the one that comes from the flasher goes to the bulb feed side.
Sorry for any lagging in my response, I'm doing paint prep on my diffuser panel.
Old May 20, 2020 | 02:55 PM
Acura83's Avatar
Your good bro understand, your Acura came out sick !!!
What other things have you planned ?
Old May 20, 2020 | 02:59 PM
DaIll1's Avatar
After I get the diffuser done I'll be going back to the side skirt extensions.
Old May 20, 2020 | 03:24 PM
DaIll1's Avatar
If you don't mind, I'd like to use your photos to make it easier for anyone else that wants to do the flasher upgrade.
Old May 20, 2020 | 03:37 PM
Acura83's Avatar
I have the wire now , but do I just cut the blue ? And attach the red one in , can you explain this part lol I don’t wanna mess this up.
Old May 20, 2020 | 03:53 PM
DaIll1's Avatar
The flasher module has one line from power and one line to bulb. Attach the side closest to harness to from power side and the side that runs up under the headliner to the to bulb side. Where you get the ground is up to you, I got mine in the fender area because if I need to replace the module I would rather pull the fender liner than the 'C' pillar cover.
Old May 20, 2020 | 04:16 PM
Acura83's Avatar
so I do cut the blue wire? Or a little then I attach the red wire onto the blue
Old May 20, 2020 | 04:30 PM
DaIll1's Avatar
You need to cut the blue wire completely. One side to the module power in line, one side to module out to bulb line. The blue wire needs to go through the flasher module.
Old May 20, 2020 | 04:41 PM
Acura83's Avatar
gotchu !! I’ll keep you updated
Old May 20, 2020 | 05:28 PM
Acura83's Avatar
I got them like this
Old May 20, 2020 | 06:02 PM
DaIll1's Avatar
From what I see it looks ok. I don't know the colors of the flasher module, but yes, split and run through the module. If you have the ground hooked up, you should be able to hit the brake and see the light flash.
Old May 20, 2020 | 06:37 PM
Acura83's Avatar
so I did the brakes and did not see anything the led light is red I’ll have to wait till night
Old May 20, 2020 | 09:09 PM
Acura83's Avatar
so it did not turn on I just need to attached them more closer I guess I’ll do it tomorrow.
Old Sep 24, 2020 | 03:26 PM
DaIll1's Avatar
Here is a visual
Black is ground and can be hooked into any ground wire or to body.
Old Sep 26, 2020 | 11:20 AM
Acura83's Avatar
Is the wiring correct?
Old Sep 26, 2020 | 07:29 PM
DaIll1's Avatar
If I see the black wire connected to both red and yellow. NO. Black is ground and makes that a short. The red and yellow look correct, but the black wire needs to be connected to chassis ground, even if you just tap it into the other wire in that 2 wire harness.
Maddizm
69
Oct 23, 2024 12:54 PM
garunas
3G RDX DIY & FAQ
Jul 6, 2023 08:52 AM
CL-Slick
Oct 4, 2008 09:22 PM
CL-Slick
Sep 17, 2008 11:08 PM
jfkhan
Apr 9, 2008 11:19 AM
