Leaking Tub Spout Help
Old Jul 2, 2013 | 09:45 PM
Renegade's Avatar
Making it Happen
Just had my bathroom completely remodeled about 6 months ago, and bought and had the plumber at the time install the following trim and valve below. Now, after I shower, the spout drips for a few seconds every 45-60 seconds or so, it is not a constant slow drip. What do I need to do to fix this?
Moen 3510 M-PACT Moentrol 1/2-Inch IPS Pressure-Balancing Valve with Volume Control - Amazon.com Moen 3510 M-PACT Moentrol 1/2-Inch IPS Pressure-Balancing Valve with Volume Control - Amazon.com
Moen TS3713 90-Degree Moentrol Tub and Shower Trim Kit without Valve, Chrome - Amazon.com Moen TS3713 90-Degree Moentrol Tub and Shower Trim Kit without Valve, Chrome - Amazon.com
Old Jul 2, 2013 | 09:58 PM
NSXNEXT's Avatar
Obviously first thing is are you turning the faucet completely closed? If yes...
Sounds like the washer on the end of the cartridge is worn causing it to not completely seal the cold/hot water lines.
You need to shut off the water and open the lowest faucet in the house to drain the water from the pipes.
Remove the handle (probably an Allen holding it in place).
Then remove the cartridge with an open end wrench. Easiest is to just replace the entire cartridge. Probably less than $20.
Old Jul 2, 2013 | 09:59 PM
NSXNEXT's Avatar
Could also be that the cartridge is not tightened enough. The washer should last years not months.
Old Jul 2, 2013 | 10:36 PM
Renegade's Avatar
Making it Happen
have never done one of these things, it seems premature for the washer to already be shot. What is the cartridge, is there a universal replacement or moen will replace for me? Is it different than the valve? Sorry for the rookie questions.
Also what do you mean by the lowest faucet in the house?
Old Jul 3, 2013 | 09:22 AM
NSXNEXT's Avatar
No worries. Everyone has to learn sometime.
I would call Moen and explain the situation. They are very good at fixing customer problems. They will probably send you a new cartridge.
The cartridge is the valve that opens and closes to allow water to flow. It's the thing that you are turning when you turn the handle.
If you want to remove the cartridge without getting soaked you need to drain the entire system (hot and cold water) from the pipes in the house. Opening the lowest faucet in the house (basement, kitchen on first floor) allows you to drain the water from the system.
Old Jul 3, 2013 | 12:10 PM
stogie1020's Avatar
Needs more Lemon Pledge
There are a TON of youtube vids on how to replace the cartridges.
Helped me out, just remember (or take pics) the order you remove stuff and COVER the damn drain with a towel to prevent parts from going down it!
Old Jul 3, 2013 | 12:23 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Simple cartridge replacement job.
Sometimes you just get a bad one that wears out prematurely.
It's a pretty simple job.
Old Jul 3, 2013 | 12:30 PM
stogie1020's Avatar
Also, put some plumbers grease on the seals.
Moen should send you a new cartridge for free, it's worth asking.
Old Jul 4, 2013 | 12:33 PM
MR1's Avatar
MR1
05/5AT/Navi/ABP/Quartz
6 months. Why not call the plumber that installed it, he should fix it for free.
Mike734
Dec 10, 2021 01:25 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
