Heated Garages
I drive a Subata.
just get a couple of those heat fans from Costco
6 Forward 1 Back
I have small kids so I got a couple of these to heat a 4 car garage. It works out well. I had to put another circuit in though cause running both kept blowing the breakers.
Mr. Heater has a line above the mini jet:
http://www.mrheater.com/
My step-dad has a permanently mounted heater and a 300lb tank outside his garage, but I'm unsure what model/costs were.
My buddy has one of those tube heaters but it runs on kerosene. It kicks ass. Can heat up a two car garage quickly. You need to be a little careful with them. If you don't vent the garage it will burn up the O2 in their and you end up taking a nap.
F1 cart racer
we have a 3 car garage, two in the front and one on the side all connected.
2 of these are going in, they have a thermostat on them also.
Hot Dog garage heaters by Modine.
http://www3.modine.com/v2portal/page...ontent_013.htm
I have a Vented 60,000 BTU natural gas Garage heater. I also have my garage insulated and dry walled. If you plan on doing it the right way this is the way to go, if you dont have a finished off garage id use a LP style heater. Problem is with those is you really need a "Well Ventilated" space or the fumes will get to you. What i have can get costly to run if you use it a lot but i can get it 80 deg in my garage with little effort when its -10 deg outside.
I paid 400 or so for mine, and had to tap into my Gas line (which was easy to do for me)
