Heated Garages
Old Jan 10, 2009 | 11:37 PM
Rajca's Avatar
wham bam thank you ma'am
Heated Garages
so i work in my garage a lot and want to know how and what i need to make my garage heated and aprox. the cost to make it and run it. and if any of u got any pics that would be nice too
Old Jan 10, 2009 | 11:43 PM
nbennettksu's Avatar
i heart latin chicks
12 space heaters.
Old Jan 10, 2009 | 11:52 PM
JS + XES's Avatar
I drive a Subata.
just get a couple of those heat fans from Costco
Old Jan 10, 2009 | 11:55 PM
Rajca's Avatar
oh and i have a 2car garage. i borrowed one of those propane heaters. looked like a mini jet engine and took up quite of space and u could stand anything in front of it bc it would burn it and made a lot of noise but it did its job.
Shoofin's Avatar
Moving to Home & Garden, where it belongs...
Old Jan 11, 2009 | 02:36 AM
Speed_Racer's Avatar
6 Forward 1 Back
I have small kids so I got a couple of these to heat a 4 car garage. It works out well. I had to put another circuit in though cause running both kept blowing the breakers.
Old Jan 11, 2009 | 08:30 AM
GreenMonster's Avatar
Yeah, I've got one of those too. Works well, but it's not the best. To do it the "right" way will cost a bit.
Mr. Heater has a line above the mini jet:
http://www.mrheater.com/
My step-dad has a permanently mounted heater and a 300lb tank outside his garage, but I'm unsure what model/costs were.
Old Jan 11, 2009 | 09:13 AM
doopstr's Avatar
My buddy has one of those tube heaters but it runs on kerosene. It kicks ass. Can heat up a two car garage quickly. You need to be a little careful with them. If you don't vent the garage it will burn up the O2 in their and you end up taking a nap.
Old Jan 11, 2009 | 10:45 AM
AS3.0CL's Avatar
F1 cart racer
we have a 3 car garage, two in the front and one on the side all connected.
2 of these are going in, they have a thermostat on them also.
Hot Dog garage heaters by Modine.
http://www3.modine.com/v2portal/page...ontent_013.htm
Old Jan 11, 2009 | 10:51 AM
AS3.0CL's Avatar
F1 cart racer
what i posted is more of a long time solution, tube heaters will work great if u just need for a short time. the one we have just went.....
Old Jan 11, 2009 | 11:07 AM
Rajca's Avatar
how much do you guys spend on the heaters?
Old Jan 14, 2009 | 07:51 PM
fsttyms1's Avatar
I have a Vented 60,000 BTU natural gas Garage heater. I also have my garage insulated and dry walled. If you plan on doing it the right way this is the way to go, if you dont have a finished off garage id use a LP style heater. Problem is with those is you really need a "Well Ventilated" space or the fumes will get to you. What i have can get costly to run if you use it a lot but i can get it 80 deg in my garage with little effort when its -10 deg outside.
I paid 400 or so for mine, and had to tap into my Gas line (which was easy to do for me)
Old Jan 14, 2009 | 11:15 PM
Rajca's Avatar
your gas line? u sure its not your neighbors? lol
Old Jan 15, 2009 | 07:13 AM
fsttyms1's Avatar
Nope it was mine. I wish it was my neighbors every time i get the bill though.
Old Jan 30, 2009 | 11:07 AM
Yeah, My stepdad has a Modine... as soon as I heard the "hot dog" name I remembered
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
