Does the "patch" work?
Put it on her nipples and try ripping them off if you get pissed off at her.
Wouldn't know, if I remember correctly studies said it was as effective as the pill, but doesnt prevent you from getting the HIV....
I'm sure it works on the same concept as the patch for smokers. The drug (in this case hormone) is taken in through the pores of the skin into the blood, where it then does it's magic.
The pill works the same way, only it's in a solid form initially... What did you think it did??? Went down and blocked your little boys from entering the fallopian tubes???
It's all hormones... Patch, pill... It's all the same.
teh Senior Instigator
Originally posted by LegendC
My girlfriend got pregnant on it and her OB said he has seen a lot of other users get pregnant.
OWNED, and people wonder why my girl is on the pill and I still wear a rubber
Friend of mine started the patch and some anti-depressants at the same time, and she put on about 20 pounds. Don't know if it was the bc or the other, but it could make your gf heavier.
Maybe that's how it works - it makes her tubby so you don't want to have sex with her.
I think most forms of birth control (other than condoms and butt sex) cause the little lady to blow up like a tick. Unfortunate, but better than her expanding due to a bun in the proverbial oven.
Originally posted by Maynard
It works well as long as you keep it on. The major side effect I've seen is skin irritation- and becareful becasue it doesn't stay on all that well in water. Alot of OB-GYNs I work with recommend it.
Originally Posted by SilviaGTO
i worked with a woman who swore by the pull out method. even though she admits both her children were born from that.
Pulling out requires lots of self-control and an ability to predict the exact moment when he is going to ejaculate. He must pull out completely from the woman and ejaculate away from her body. If he forgets or doesn't pull out in time, there's a definite possibility of getting pregnant.
If anyone thinks that pulling out is a form of safe birthcontrol it's not!
Even if you pull out and put it in her mouth or her hair or wherevere there is that chance...so be smart and use a condom or make sure she is on the pill!!!!!
mada51589
Jan 9, 2025 04:40 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
Knock on wood.
