Help intalling ATI Radeon 9800 SE
Old Aug 28, 2005 | 08:11 PM
S A CHO's Avatar
That was uncalled for...
So I got this card and am having a little trouble installing it....The card went in fine but its not powering the monitor on......I plugged it into its slot, plugged the power cable into the hard drive ( it suggested I do that) then plugged the cable into the power supply.....I turn on the computer but the monitor doesnt come on.....
check it out...http://www2.ati.com/manuals/r9800Getting_Started.pdf
page 12 is what Im referring to......anything that might help would be appreciated...
Old Aug 28, 2005 | 11:12 PM
srika's Avatar
Moderator Alumnus
are you using the DVI or standard VGA output?
Old Aug 29, 2005 | 10:12 AM
S A CHO's Avatar
Standard VGA......I called ATI and they cannot suggest anything except return the card.......should of fuckin stuck with nVidia.....
Old Aug 29, 2005 | 11:32 AM
srika's Avatar
Moderator Alumnus
It's possible it may be trying to use the DVI out. Of course, you can't confirm this, since you don't have DVI and hence you have no video. What I would do to test it is, put an older video card in that only has VGA - and see if this works with your monitor. If this works fine, then yes the ATI card may be bad. Did you even get to install the Radeon drivers? or no, because you never got a video signal...?
Old Aug 29, 2005 | 11:44 AM
S A CHO's Avatar
No never got a video signal. Im not sure what you mean by having a card that only has VGA...my old card was a GeForce 2 MX400....I put the GeForce back in and that card works fine....my guess is that the card is screwed up...
Old Aug 29, 2005 | 12:45 PM
srika's Avatar
Moderator Alumnus
I mean, a card that doesn't have a DVI output. If your old card is working fine, it does sound like there is a problem with the ATI card. If for some reason you can't return it (where you bought it), you can deal with ATI directly to get it replaced with a working unit.
Go here and click on "Warranty Service Request"
https://support.ati.com/ics/support/...e&folderID=281
just a suggestion.
Old Aug 29, 2005 | 09:04 PM
S A CHO's Avatar
Yeah, the dude on the phone suggested I do this if I couldnt find a solution, thanks for pointing me to the site..
Old Aug 30, 2005 | 07:27 PM
S A CHO's Avatar
Well, I returned the card, got another one and it still doesnt work........It must be my motherboard...which is weird becuase its only 3 years old and has all the latest drivers......
Old Aug 30, 2005 | 09:01 PM
srika's Avatar
Moderator Alumnus
that sucks man.....
DanMan1464
Jan 6, 2005 11:59 AM
zigzagzig
Console & Computer Gaming
Dec 9, 2004 07:30 AM
Tunaboy
Oct 3, 2004 02:11 PM
srika
Technology
31
Jul 3, 2004 12:22 AM
