GT4: Official Thread
Old Jun 10, 2005 | 06:05 PM
  #3161
MSZ's Avatar
MSZ
Lola
So R2 is a bit more realisitic than R3 I guess.
Old Jun 10, 2005 | 06:08 PM
  #3162
srika's Avatar
Moderator Alumnus
It may also have to do with the track and car... I mean, I don't think it's JUST the tires... it would be interesting to see what top speeds they are hitting in real life compared to GT4... I guess you could only really compare the Pescarolo, since its the only car in GT4 that's racing at Le Mans right now. Of course, assuming they are the same models.
Old Jun 11, 2005 | 07:25 AM
  #3163
Kighter's Avatar
I dunno if anyone is still running the C60 (which is what the GT4 Pescarolo is). Most of the new Courages are the C65 with different power (teams work out their own engine deals).
The Audi R8s would be your best comparison I think. Still the same ole car and motor.
I would bet they are running tires far harder then we have available to us in the game, and I have yet to see any speed trap times. Next week we can do a more accurate race since we'll know their speed trap times and how many laps they are doing between pit stops. Then we can adjust tires accordingly and run a little test.
Old Jun 11, 2005 | 11:45 AM
  #3164
srika's Avatar
Moderator Alumnus
oh shoot duh how the hell did I forget about the R8....
Old Jun 11, 2005 | 02:49 PM
  #3165
Zapata's Avatar
Cost Drivers!!!!
12% completed btw...i love my turbo s2k w/ custom gears. Nothing like stayingint the 8-10k range the entire track
Old Jun 11, 2005 | 03:05 PM
  #3166
Doom878's Avatar
Don't forget the Bentley Speed 8. Isn't it still in there?
Old Jun 11, 2005 | 03:06 PM
  #3167
Doom878's Avatar
And how do you use NAWZ? I equipped it in one car but couldn't figure it out.
Old Jun 11, 2005 | 03:54 PM
  #3168
srika's Avatar
Moderator Alumnus
I read somewhere that its the R1 button.....
Old Jun 12, 2005 | 12:15 AM
  #3169
Doom878's Avatar
Tried that. Don't know why it didn't work.
Old Jun 12, 2005 | 01:02 AM
  #3170
srika's Avatar
Moderator Alumnus
Go into button configuration and see what's up. If the button is set correctly, go into the car settings and max out the NAWS settings and see if you can notice the NAWS when you hit R1.... with some cars, the default setting is so subtle that sometimes it's hard to tell if it's even working.
Old Jun 13, 2005 | 01:12 PM
  #3171
mc_yanzo's Avatar
Masshole
NOS???
Cheaters!!!
Old Jun 13, 2005 | 01:56 PM
  #3172
Kighter's Avatar
Bentley only ran 3 years and retired. When they developed the Audi R8 the coupe version didn't have as much promise so they dropped it it. When Bentley was looking to get back into LM racing they started with that car and developed it up and it dominated in it's last year. So it's basically an R8 hardtop...
We'll know soon what the pit strategies are and whether we can run a fairly accurate comparison.
Old Jun 17, 2005 | 12:11 PM
  #3173
Doom878's Avatar
Anyone try the Saleen S7 race. Man this thing doesn't turn.
Old Jun 17, 2005 | 12:59 PM
  #3174
srika's Avatar
Moderator Alumnus
you're going too fast....
also, you may be giving it too much throttle in the middle of the turn... causing it to oversteer. ease up on the throttle and it should turn.
Old Jun 17, 2005 | 01:09 PM
  #3175
Kighter's Avatar
Trail Brake that hog - make it stick it's ass out and then hit the throttle. Wheeeee.
I actually kinda like the S7. It's sooooo long that it makes power oversteer a little easier to control. It's slow that way but fun. Might also wanna try one compound softer on the front tires. I tend to do that on some cars - helps with turn in and makes your rears last a little longer - kind of a personal preference though.
By the way - I've been running Nurburgring Enduros unattended this week (haven't had much time to sit down and play). Got 2 more F1 colors. I'm thinking now it'd be cool to have the whole set.
Old Jun 17, 2005 | 01:31 PM
  #3176
srika's Avatar
Moderator Alumnus
you know you can race using any F1 color in arcade mode, right? I mean, it's not the same as actually having EACH car in your garage, but damn.... if that's what you wanna do, knock yourself out.
ps. I like the S7 too.
Old Jun 17, 2005 | 04:17 PM
  #3177
MSZ's Avatar
MSZ
Lola
The S7 is much better than SLR, handling wise.
Old Jun 18, 2005 | 11:48 AM
  #3178
Doom878's Avatar
My S7 doesn't oversteer. It tends to understeer. The only mods I did to it was brakes and Stage 2 weight reduction.
Old Jun 18, 2005 | 04:35 PM
  #3179
srika's Avatar
Moderator Alumnus
oops.... my bad. I had em reversed. when I said oversteer, I meant understeer
btw the following will minimise understeer..... don't do them all at once though because then you may really mess up the handling - try them one at a time to optimally find out the difference:
more negative front wheel camber
more positive rear wheel camber
less front wheel toe in
less rear wheel toe out
softer front springs
stiffer rear springs
less forward weight distribution
you could also:
decrease front tire pressure
increase rear tire pressure
if you could.
Old Jun 19, 2005 | 01:37 AM
  #3180
Doom878's Avatar
I usually kill ASM first. That usually fixes my problem.
Old Jun 19, 2005 | 04:37 PM
  #3181
evilone's Avatar
COME AT ME BRO!
ok i have a problem. what car did you guys use to beat the last race in profesional series? i hooked up the 86 toyota monoltia(sp?) to just over 1100hp and still cant win. and whats the best car to use for nurinburge 24hr race
Old Jun 19, 2005 | 05:01 PM
  #3182
MSZ's Avatar
MSZ
Lola
I used Minolta and I won all races. So if you can't win with Minolta you can always use the F1 which can be won in the N-Ring 24hr enduro:
I used Nissan R92CP @ N-Ring. Leaded by 32 laps over the 2nd place car at the end of the race.
Old Jun 20, 2005 | 07:43 AM
  #3183
Doom878's Avatar
Don't soup up the Minolta to 1100hp. It'll kill your tires much faster and kill the handling. I notice the top dog cars don't like mods.
Old Jun 21, 2005 | 10:50 PM
  #3184
Doom878's Avatar
HOly crap. Anyone drive the Aston Martin DB9 Coupe. I bought it instead of the V12 Vanquish due to the higher torque and lighter weight. I did exhaust, chip, and Level 1 weight and the car was pretty badass. Awesome pick up. Had power everywhere in the band. Reminded me of the Z06 with the RWD torque.
Old Jun 21, 2005 | 10:54 PM
  #3185
srika's Avatar
Moderator Alumnus
no way..... I need to try it. sounds good. I would imagine it handles better than the Vanquish...
Old Jun 21, 2005 | 10:59 PM
  #3186
Doom878's Avatar
I didn't pick the Vanq also because of that heavy ass V12 which would screw up my turning. Not to mention it was like $100k cheaper.
Old Jun 22, 2005 | 10:23 AM
  #3187
mc_yanzo's Avatar
Masshole
I was bored the other day so I bought a Supra RZ and a PDG CL-S. I have way too much money ($9.5mill) and still have over 100 days left for the black beauties.
Old Jun 22, 2005 | 11:58 AM
  #3188
Doom878's Avatar
Hah. I went shopping last night too. I bought a Cobra R and Phoenix Yellow Type R USDM.
Old Jun 22, 2005 | 01:00 PM
  #3189
vwong's Avatar
n00b
I was debating which one I should get the other night. Now I know which one I will be buying.
Old Jun 22, 2005 | 03:15 PM
  #3190
Doom878's Avatar
Well I never drove the V12 Vanquish so I hope you like it.
Old Jun 22, 2005 | 03:53 PM
  #3191
MSZ's Avatar
MSZ
Lola
I have both cars. DB9 is a bit more mobile but I would say both cars are much better than the E55 that we're using right now in the time trial...
Old Jun 22, 2005 | 04:00 PM
  #3192
vwong's Avatar
n00b
Yeah...who picked that car?
Old Jun 22, 2005 | 04:18 PM
  #3193
srika's Avatar
Moderator Alumnus
h8
Old Jul 6, 2005 | 06:20 PM
  #3194
Mizouse's Avatar
too much to search but what days do the black beauties show up again?
Old Jul 6, 2005 | 06:24 PM
  #3195
Mizouse's Avatar
nvm im not that lazy day 694, almost there at day 682 right now
Old Jul 6, 2005 | 09:41 PM
  #3196
Mizouse's Avatar
funny im finding out right now, when you run out of gas, instead of your car just dieing it limits you to 50mph.. kinda lame i was hoping that itd like sputter to its death HEH
Old Jul 6, 2005 | 09:59 PM
  #3197
srika's Avatar
Moderator Alumnus
run out of gas? are you talking about GT4?
Old Jul 6, 2005 | 10:20 PM
  #3198
Mizouse's Avatar
yea
Old Jul 12, 2005 | 08:23 AM
  #3199
mc_yanzo's Avatar
Masshole
Hadn't played GT4 in awhile so I fired it up the other day. I got my S license so I could do the Extreme Events. I did them all except the GT Championship - man, that thing is gonna take FOREVER.
But the Sauber is worth it.
Old Jul 19, 2005 | 09:08 AM
  #3200
mc_yanzo's Avatar
Masshole
Man this GT Championship is kicking my ass. I've qualified first for every race, Bspec driver is over 7000 points, and most races I'm at 5 (Push). Lots of babysitting needed for these races!
After 4 races - 2 firsts, 1 second, and 1 sixth
