Tundra 86'd for an 86 which was 86'd for a Sequoia
Old 10-10-2020, 07:09 AM
  #601
LFG RANGERS!!!!!!!!!!!
e30cabrio's Avatar
Received 1,992 Likes on 1,366 Posts
Apparently unforeseen happened.
Old 10-12-2020, 04:07 PM
  #602
e30cabrio's Avatar
WOOT!!
civicdrivr (10-12-2020)
Old 10-13-2020, 06:24 AM
  #603
rockstar143's Avatar
Received 20,014 Likes on 14,518 Posts
I forget, are you doing all these upgrades to track it?
Seems like the car has already come such a long way.
Old 10-13-2020, 06:36 AM
  #604
e30cabrio's Avatar
Not directly. I might do a few track days but modding is a hobby.
Old 10-13-2020, 07:27 AM
  #605
I know that life!
Old 10-13-2020, 03:22 PM
  #606
e30cabrio's Avatar
Got the alignment. Is it as bad as it looks to my trained to think red is awful eyes and do I need to do something and if so what?
lol
Old 10-13-2020, 03:28 PM
  #607
Received 5,559 Likes on 3,794 Posts
Does seem like a lot of camber, but I'm not sure what the stock height OE numbers are.
Maybe the drop pushed some extra camber?
Old 10-13-2020, 03:35 PM
  #608
-2 is fine, to me...
keep me in on my toes though.
e30cabrio (10-13-2020)
Old 10-13-2020, 03:44 PM
  #609
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Green toes is where it counts. And RWD Toyota Gang is all about negative camber. Sooo... Looks good to me.
Old 10-13-2020, 03:49 PM
  #610
S2000 and both Audi are about the same spec...
doesn't eat up tires.
Gang gang.
Old 10-13-2020, 04:43 PM
  #611
e30cabrio's Avatar
10q
Old 10-13-2020, 07:15 PM
  #612
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,460 Likes on 4,980 Posts
If anything I'd get adjustable top hats to dial in more camber up front to amplify turn in. Those things love camber. I had mine at -2.3 front and -1.8 rear. Handled like a dream.
Costco (10-14-2020)
Old 10-13-2020, 07:17 PM
  #613
civicdrivr's Avatar
Also if you find that you're suffering from bump steer I have the roll center correction kit from Whiteline. I don't think they sell it anymore. Still brand new.
If you're not suffering from bump steer though, there's no need for it.
Old 10-13-2020, 07:26 PM
  #614
e30cabrio's Avatar
Which are the best ones?
Old 10-13-2020, 09:17 PM
  #615
e30cabrio's Avatar
I don't have bump steer.
I do have movement!
Old 10-14-2020, 06:37 AM
  #616
I think he was letting you know that if you need it, he will sell it to you on the low
Old 10-14-2020, 08:10 AM
  #617
I'd think a bit of toe out would liven the turn in, moreso than a bit of extra camber? Maybe a bit of extra caster to add camber on turn-in?
Old 10-14-2020, 08:40 AM
  #618
civicdrivr's Avatar
More toe out will wear the tires faster; camber (within reason) won't.
Caster certainly helps, but that requires new bushings or adjustable arms, which drives the price up (and usually come with loud, clanky heim joints).
00TL-P3.2 (10-14-2020)
Old 10-14-2020, 08:58 AM
  #619
e30cabrio's Avatar
I understood, they look nice but I don't have bump steer.
Which top hats do you suggest M?
Old 10-14-2020, 09:11 AM
  #620
Good points. Do the twins not have any caster adjustment? I remember the ND Miata folks dialing them to about the max caster they could take without any issue.
Old 10-14-2020, 09:54 AM
  #621
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
He can chime in but I'm running the Raceseng plates. Real purdy, and you can adjust caster a bit as well.
Yeah, one of the sticking points about this platform, among other things. But there are plenty of options to fix that.
civicdrivr (10-14-2020)
Old 10-14-2020, 10:02 AM
  #622
e30cabrio's Avatar
They are nice, do they offer financing?
lol
https://raceseng.com/cascam-caster-c...baru-brz-2013#
Obviously, they replace the shock mounts?
A) they are out of stock, (B) the options I need push it to 620 + tax & shipping I assume.
Old 10-14-2020, 10:53 AM
  #623
civicdrivr's Avatar
I suggest these if you're looking to keep noise on the front end to a minimum:
https://www.ftspeed.com/part/fr-s-br...-toyota-86-201
I also like the Verus setup, but they will likely be a bit noisier due to the bearing.
https://www.ftspeed.com/part/fr-s-br...-camber-plates
Costco (10-14-2020)
Old 10-14-2020, 11:12 AM
  #624
Costco's Avatar
Camber bolts are a great alternative. Been too long since I looked into it but just keep your fingers crossed... you should be able to get -1.5 - 2 degrees with just the bolts.
Honestly the plates are overkill unless you really want specific alignment numbers or are tracking the car. As M said, the extra camber really helps the car stick, and yeah the spherical bearings make the front end a little clunkier sometimes. I just step on the go pedal harder, or turn the volume up and the sounds automagickally go away.
I thought the extra sounds would bug me at first, but between how loud my exhaust is and the tire hum everything gets kinda washed out. What's annoying is when the gf complains, but I think we all learn to tune that out a bit
Old 10-14-2020, 02:26 PM
  #625
e30cabrio's Avatar
The back is ok?
Ordered the bolts. Thanks guys!
Old 10-14-2020, 02:53 PM
  #626
civicdrivr's Avatar
The rear is pushing it a bit for my tastes, but I think you'll be fine.
I ran SPC rear LCAs and toe arms (along with the SPL eccentric lockout plates) on mine without a problem. But that's $500 worth of parts you may not need.
Old 10-14-2020, 09:35 PM
  #627
e30cabrio's Avatar
Are these what you mean?
Old 10-14-2020, 09:38 PM
  #628
civicdrivr's Avatar
Yep. I didn't use the eccentric that comes with the LCAs, since I just went with the adjustable arms instead.
Old 10-14-2020, 09:45 PM
  #629
e30cabrio's Avatar
You do the adjustment with the toe arms instead of the eccentric on the LCA?
Old 10-15-2020, 08:18 AM
  #630
civicdrivr's Avatar
The eccentric insert that's included with the LCAs is actually for the toe link. You use the cam bolt included with the LCAs for camber adjustment.
https://www.spcalignment.com/instruc...60-INS_WEB.pdf
The eccentric for the toe link requires a press and is installed in one of two configurations. I didn't like that (from an install and adjustment perspective), which is why I went with the adjustable toe links.
But I definitely recommend the SPL lockouts for the toe link bolt on the subframe.
The following 2 users liked this post by civicdrivr:
Costco (10-15-2020), e30cabrio (10-15-2020)
Old 10-15-2020, 08:42 AM
  #631
e30cabrio's Avatar
Thanks!
Old 10-15-2020, 11:03 AM
  #632
e30cabrio's Avatar
WooT!
Happy happy joy joy!!!
The following 3 users liked this post by e30cabrio:
00TL-P3.2 (10-15-2020), civicdrivr (10-15-2020), Costco (10-15-2020)
Old 10-15-2020, 11:30 AM
  #633
Costco's Avatar
Hmm... I ran SPC LCAs before and they would not retain alignment angles. That was when I wanted rubber or poly connections to minimize clunking.
After driving for some miles, the bolt for camber adjustment on the SPCs would slip no matter how much they were tightened. I thought my alignment guy might have been limp-wristing it, so I marked the slots and tightened things up myself. Turns out the slotted design kinda sucks IMO. I didn't use the lockout kit like M did though, so that's probably why. If you go that route, I agree with adding the lockout kit.
Thought about putting loctite, but seemed like a ghetto solution so I just got rid of them. Self-lubricating rod ended LCAs are an option, but more NVH is possible (and more $$$)
Old 10-15-2020, 11:32 AM
  #634
Costco's Avatar
Nameless makes good shiiiet though! dat Helmholtz resonator
Old 10-15-2020, 11:51 AM
  #635
e30cabrio's Avatar
My entire exhaust will be Nameless. Header to catback.
Can't wait to get it installed & finalize my tune.
Old 10-15-2020, 12:20 PM
  #636
civicdrivr's Avatar
I didn't have that issue with mine over the 10k+ miles I had them. I don't recall a buddy of mine having that issue either.
BUT - that's one reason I don't like cam bolts - if they slip, your alignment settings are gone (which I why I suggest the lockouts on the toe bolts).
Old 10-15-2020, 01:30 PM
  #637
That seems unfair.
Give it a name. I'm thinking "Flatulence"
Old 10-17-2020, 09:34 AM
  #638
e30cabrio's Avatar
Exhaust r&r commenced. My least liked part of any job, lifting.
6ton Tundra stands ok???? :P
Old 10-17-2020, 10:01 AM
  #639
e30cabrio's Avatar
Undertrays off, hoping I can get at the upper end link bolts without taking the wheels off (I will if need be) forgot about the sway bar until I got it apart.
Old 10-17-2020, 10:48 AM
  #640
e30cabrio's Avatar
Couldn't get at the bolt. Once off couldn't get the end link out would have needed to loosen/move the strut & throw off the alignment, I'll install it after I get the toe bolt in there when I'm ready for another alignment (6 months between lifetime alignments)
Already tired. have not touched the exhaust yet.
lol
Quick Reply: Tundra 86'd for an 86 which was 86'd for a Sequoia
