Tundra 86'd for an 86 which was 86'd for a Sequoia
Old Nov 4, 2025 | 10:07 AM
  #4481
Yumcha's Avatar
@e30cabrio : Hey sir...checked and I can see your images.
Old Nov 4, 2025 | 10:12 AM
  #4482
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
@Yumcha Yup, seems they are taking 5 minutes where before it was immediate.
Old Nov 4, 2025 | 01:15 PM
  #4483
PhilB81's Avatar
Dang, all your blades went! Did the mounting break or something?
Old Nov 5, 2025 | 09:37 AM
  #4484
Yumcha's Avatar
Old Nov 6, 2025 | 07:52 PM
  #4485
e30cabrio's Avatar
New radiator, mounted the new fan on the clutch.
Old Nov 7, 2025 | 04:23 PM
  #4486
e30cabrio's Avatar
Fixt.
Old Nov 9, 2025 | 05:38 PM
  #4487
e30cabrio's Avatar
Halogen bulbs burned these lenses, lots of the used ones are browned on the low beam, new ones are 13-1600.
Got this one for 350 & cleaned it up.
Old Nov 9, 2025 | 06:04 PM
  #4488
Amazing what a bit of elbow grease can achieve
Old Nov 9, 2025 | 07:06 PM
  #4489
e30cabrio's Avatar
I'm happy with the transformation.
Old Nov 9, 2025 | 07:40 PM
  #4490
Being able to see at night makes a big difference.
Cleaning the lenses & replacing the bulbs in the Mini made a massive improvement to nighttime visibility.
Old Nov 13, 2025 | 07:14 PM
  #4491
e30cabrio's Avatar
Here's a couple with the lights on.
Old Nov 16, 2025 | 12:36 PM
  #4492
e30cabrio's Avatar
One of my 4 Deco units was acting up, There was a sale on the newest unit so I ordered it. Amazon delivered it in it's retail box at my door which has had issues with theft. I just don't get it.
WTF Amazon???
I had 2 of the predecessors in the back yard & garage, now 2 of these are there, the new ones replaced 3 of these.
Before, I was getting 70% wirelessly and losing 2-300 MBPS on the VPN, now it's within the margin of error.
Wired on the media PC:
Wired VPN
Wireless on my phone 10 feet from the main node.
Old Nov 22, 2025 | 11:25 AM
  #4493
e30cabrio's Avatar
'Cause I can't get a day off, drama dujour, is the the hesitstion/rough shift/no fucking clue came back, ran codes and the only one was P1605.
P1605 code indicates a rough idle or a Knock Control CPU Malfunction, often linked to a problem with the engine's air and fuel supply or the ignition system. Common causes include a dirty Mass Air Flow (MAF) sensor, a clogged throttle body, vacuum leaks, or issues with the spark plugs and ignition coils. A Faulty Engine Control Unit (ECU) or its software can also be the cause, which might require reprogramming.
Googled it & cleaned the MAF/TB plate verified nothing in the intake & because I forgot to knock the gas pedal around the truck didn't start & then the truck was electrically dead.
Brought out the 10 amp trickly charger, nothing, 110 amp clicking, had to get the 200 amp monster I never need out from behind 1/2 the junk I have & it started. Took it to Batteries + where it came from & of course it tested good.
Jacked the now warm truck up to check the fluid & was drenched in hot ATF. On a bright note, the thin sockets I got a few months ago with my long reach Milwaukee were perfect for getting in there.
Screenshot 2025-11-22 at 10.09.05 AM.pngScreenshot 2025-11-22 at 10.09.23 AM.png
Old Nov 29, 2025 | 07:40 PM
  #4494
e30cabrio's Avatar
I'm Stefan, I'm a modaholic.
I really wanted the Harrop, but it is 2k more & there is tax & shipping on top of that so really 3k
Old Nov 29, 2025 | 08:06 PM
  #4495
Isn't the Tree already supercharged?
Old Nov 29, 2025 | 08:14 PM
  #4496
e30cabrio's Avatar
Yes, this is an upgraded bigger blower.
https://www.cspracing.com/products/m...3ur-feMagnuson 05-26-57-107-BL - TVS2650 Magnum Supercharger Upgrade Kit for 2007-2021 TVS1900 Supercharged Tundra 5.7L 3UR-FE
TVS2650 Magnum Supercharger Upgrade Kit for 2007-2021 TVS1900 Supercharged Tundra 5.7L 3UR-FE.
Magnuson’s Toyota Tundra Magnum TVS2650 Supercharger Upgrade Kit provides everything you need to convert your TVS1900 Supercharged Tundra into a Magnum Performance TVS2650 powerhouse. The OEM look Tundra supercharger system incorporates a huge charger air cooler integrated into a large plenum with optimized tapered runners while retaining OEM levels of drivability and reliability. The Magnuson TVS2650 Tundra Supercharger Upgrade Kit makes some serious torque at the crank for enhanced off-roading, towing and street performance.
Can't imagine how much torque it will make, it already has 574 LBs (on the first old motor)
Old Nov 30, 2025 | 11:33 AM
  #4497
Well, ok then
Old Dec 4, 2025 | 02:53 PM
  #4498
e30cabrio's Avatar
While the SC is off, ordered delrin spacers to lower IATs.
https://www.aesinnovate.com/product-...r-kits-v8-5-7l
Applicable
Now offering 3UR spacer in Billet Aluminum and Delrin verison for order
  • Toyota 3UR-FE (5.7 Liter) V8 engine now has the option for an Intake Manifold Spacer Kit offered by Anderson Engine Solutions. This Toyota Tundra/Sequoia/ Land Crusier intake manifold runner is an aftermarket "bolt-on" item without any modification to the engine to INCREASE low end torque performance.
This torque modification is designed for individuals who require more torque from their engines at idle to mid-range rpms, After installing this allows for quicker accelaration, increase throttle response, and is ideal for off-road enthusist looking to increase their vehicle ability in situations where more torque is needed.
This product is made of high strength Delrin material for preventing heat soak into the intake system but the spacers can be made of T6061 Aircraft Aluminum and anodized for corrosion resistance upon request. Please contact for quote. Lead time for Aluminum only is 2-3 weeks from order date.
**Patent Pending**
This product features:
- Direct fit to OEM air box/plenum or compatible to aftermarket cold air intake system.
- CNC machined runner Delrin (POM-C) 1.00" thick with gasket groove
- OEM Toyota Intake Gaskets with the kit for proper sealing.
- 15 Count Additional Hardware
3UR Runner Kits (V8 - 5.7L)
4 Reviews
$365.00Price
Starting at $34.87/mo or as low as 0%APR.Payment method logoLearn More
Material Type*
SelectQuantity*
Add to Cart
  • PRODUCT INFO
    The Advantages of High Performance Delrin (POM-H)
    • Temperature resistance (up to 250F max)
      • Prevents excessive heat transfer
    • High Material Stiffness
    • Low Friction & Wear
    • Fatigue Resistant
    • Chemical Resistant
    • Dimensional Stable
    • Low moisture absorption
    After installation, the additional length of the intake port air flow path allows for the 3UR-FE engine to reach max torque at a lower engine speed. This decreases the need to operate the vehicle at higher RPMs to achieve a max engine performance and increases drivability of the truck overall while promoting better low end torque/mileage per gallon (MPG).
    NOTE: This product is not C.A.R.B. approved. Not for street use in California. This product shall not be used in a manner that violates Federal EPA Laws and regulations.
Old Dec 6, 2025 | 12:48 PM
  #4499
e30cabrio's Avatar
This happened this morning, inching towards 10.
I was getting 12+ on the 2.2" pulley but the builder said stay under 10 so I am usnig a 2.3" now.
Not shocking with such nice weather.
Old Dec 21, 2025 | 08:17 AM
  #4500
e30cabrio's Avatar
Waiting for the 2650 stinks!
Spacers came.
[​IMG]
Old Dec 25, 2025 | 09:49 AM
  #4501
e30cabrio's Avatar
I needed the spacers to isolate the SC from heat for which delrin is better suited. The Vendor had a delay and offered the more expensive aluminum version. I traded mine out for a delrin set.
attachFull1172513
Old Dec 28, 2025 | 02:18 PM
  #4502
e30cabrio's Avatar
09/30/2021 I got an AGM battery from Batteries+ 08/12/2023 it failed & was replaced under warranty. 12/28/2025 it failed & replaced and for some reason they also gave back 100.8. It still has a full warranty until September.
P88420905 Fulfillment 12/28/2025 ($100.81) Completed
Old Jan 3, 2026 | 11:45 AM
  #4503
e30cabrio's Avatar
Sequoia doing truck things.
attachFull1174578
Old Jan 4, 2026 | 09:55 AM
  #4504
e30cabrio's Avatar
After a week of delays the Topdon Phoenix Plus2 came. It's much higher quality than the Autel much faster and more comprehensive.
I like that it generates reports which can be emailed and printed.
[​IMG]
[​IMG]
Old Jan 6, 2026 | 12:22 PM
  #4505
1StGenCL's Avatar
958 & 991
[​IMG
[​IMG
That report feature is cool!
Old Jan 9, 2026 | 08:33 PM
  #4506
e30cabrio's Avatar
Upgraded to 2Gb, wired I'm getting over 2, wireless pretty damn close.
Old Jan 17, 2026 | 09:27 AM
  #4507
e30cabrio's Avatar
Whelp, looks like I'll have hoses & stickers.
5lb box
[​IMG]
120lb box
[​IMG]
Old Jan 17, 2026 | 12:49 PM
  #4508
e30cabrio's Avatar
Woot!!
Good news both out for delivery, bad news estimate is now as late as 8:30 :P
attachFull1178829
Old Jan 17, 2026 | 09:00 PM
  #4509
e30cabrio's Avatar
Stuffs a popping!
UPS map showed the truck at the local UPS store so I went there & got it!
Old Jan 18, 2026 | 04:53 PM
  #4510
e30cabrio's Avatar
Here's so far today.
[​IMG]
Once it sets (fingers crossed) I'll cut around the ports at the front and do the snout.
[​IMG]
Needed something to apply pressure.
Old Jan 18, 2026 | 06:41 PM
  #4511
e30cabrio's Avatar
Love the way it looks.
Old Feb 12, 2026 | 05:36 PM
  #4512
e30cabrio's Avatar
New 2650 going in!
Old Feb 12, 2026 | 06:56 PM
  #4513
e30cabrio's Avatar
This is where I stopped, need to route the PVC & coolant for the SC hoses & the intake tube & I'm done!
Old Feb 13, 2026 | 12:38 PM
  #4514
e30cabrio's Avatar
Done!! No leaks! Around the block it feels the same got 6.7lbs.
Work intrudes so it'll be a bit before I can take it on the street. So far thrilled!!
Old Feb 14, 2026 | 04:29 PM
  #4515
e30cabrio's Avatar
Full cat shields are back on first time in 2+ years, big one had become garage counter space, rearranging all of that was almost as much work as the install which is almost as much exertion as the blower swap.
lol
Old Feb 15, 2026 | 10:53 AM
  #4516
e30cabrio's Avatar
It feels great, have to wait for full beans as I can't log or tune until UPS feels like delivering my upgraded MPVI4 I paid for 2 day delivery but it sat in Kentucky for 2 days & now although it's been at the local center since early AM Friday says not delivering until Tuesday.
WTF, I checked they are working on Presidents day.
Old Feb 15, 2026 | 03:59 PM
  #4517
e30cabrio's Avatar
This happened when I went to get lunch, rear camera go to 17 seconds, front go to 14 seconds.
Rear
Front
Old Feb 15, 2026 | 06:12 PM
  #4518
e30cabrio's Avatar
Before anyone brings up my voice over, I watched it without sound.
lol
Old Feb 15, 2026 | 06:29 PM
  #4519
Old Feb 17, 2026 | 09:29 AM
  #4520
BreezyTL's Avatar
"aren't you fuckin precious"
