Tundra 86'd for an 86 which was 86'd for a Sequoia
Old May 24, 2025 | 11:43 AM
  #4361
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
Drove the car to get e85, tested 85%.
Damn O2 stopped reporting, swapped in another new sensor, no change. Waiting for the tuner to get back to me on fixing it.
It is running great, also, THIS:
Old May 27, 2025 | 02:55 PM
  #4362
e30cabrio's Avatar
Fucking hits keep coming. Pool filter housing top blew up.
Adiós 2k
[​IMG]
[​IMG]
Old May 27, 2025 | 03:40 PM
  #4363
Blew the whole top off?
Old May 27, 2025 | 07:14 PM
  #4364
e30cabrio's Avatar
Yup. Blew it out of the yard, no idea where it went.
Old May 27, 2025 | 07:25 PM
  #4365
Yikes. Always been an [irrational?] fear.
our filters at our old house had to be cleaned monthly & they got bad quickly.
This pool is much more manageable.
Old Jun 2, 2025 | 06:26 PM
  #4366
e30cabrio's Avatar
1600 later.
The cleaning system brain lid immediately broke.
Old Jun 8, 2025 | 12:02 PM
  #4367
e30cabrio's Avatar
The fun never stops! The seal between the intercooler and body is leaking into the intake on the driver side.
I ordered the seal & O rings, used Toyota FIPG as a bandaid, waiting for it to cure now.
[​IMG]
[​IMG]
[​IMG]
[​IMG]
[​IMG]
[​IMG]
[​IMG]
[​IMG]
[​IMG]
[​IMG]
Old Jun 9, 2025 | 01:14 PM
  #4368
BreezyTL's Avatar
Just think, you could be relaxing on the couch instead. Wrenching sounds more funner, even tho the couch would be cheaper!
Old Jun 12, 2025 | 10:01 PM
  #4369
e30cabrio's Avatar
Forgot to post, it leaked worse, semi locked up, killed the starter, I hoped I was wrong & it was the flexible links, It wasn't starter came today, dropped the truck at Firestone via AAA.
Old Jun 13, 2025 | 06:52 PM
  #4370
e30cabrio's Avatar
I'm fucked
Must be a hole in the block, it's losing oil. The mechanic said it was above the starter, as there is oil on it.
Old Jun 13, 2025 | 06:55 PM
  #4371
You need to buy a lotto ticket. All this bad luck must be waiting for a windfall.
Old Jun 15, 2025 | 03:01 PM
  #4372
e30cabrio's Avatar
WIth my luck, my windfall will be a meteor through the roof.
Old Jun 15, 2025 | 04:32 PM
  #4373
e30cabrio's Avatar
I'm really looking forward to working on the Sequoia this summer....
Old Jun 17, 2025 | 10:11 AM
  #4374
e30cabrio's Avatar
Good thing I didn't take the recommendation to rebuild the original heads.
Piston 1
Piston 5
Old Jun 17, 2025 | 10:27 AM
  #4375
At this point with all the time and money you have into these you could have a brand new Sequoia TRD Pro and a pretty awesome M car.
Old Jun 17, 2025 | 10:32 AM
  #4376
e30cabrio's Avatar
Old Jun 18, 2025 | 02:29 PM
  #4377
e30cabrio's Avatar
Motor will be going to the installer today.
[​IMG]
[​IMG]
Old Jun 18, 2025 | 05:01 PM
  #4378
e30cabrio's Avatar
Motor done, being delivered to the shop, AAA took the Sequoia there now.
Never expected less than 72 hours after they got my core that it would be done.
Old Jun 20, 2025 | 12:45 PM
  #4379
e30cabrio's Avatar
Amazon finds new & inventive ways to annoy daily!!!
I ordered 2 gallons of coolant in the order for oil, Trans fluid & coolant for delivery today.
They seem to have split the two gallons up.
Old Jun 21, 2025 | 08:28 AM
  #4380
e30cabrio's Avatar
Both BAT & C&B refuse to host the Z unless I agree to no reserve. Both claim better engagement, I'd think the only engagement would be people hoping to get it for nothing, & I'm not interested in giving it away, I want a 15k reserve, which is less than 1/2 of my insane upside down amount I'm into.
Fucking sucks.
Old Jun 21, 2025 | 08:55 AM
  #4381
Should've bought a Merc
Old Jun 21, 2025 | 09:13 AM
  #4382
e30cabrio's Avatar
I'd be losing my shit if this were mine..
https://bringatrailer.com/listing/19...ign=2025-06-21
Old Jun 21, 2025 | 06:01 PM
  #4383
e30cabrio's Avatar
Amazon sucks giant hairy donkey balls, now the coolant is "shipped" with another order & magically on time, nevermind no movement since "processing" at carrier facility at 7:30am.
Old Jun 21, 2025 | 06:36 PM
  #4384
I do like an E30.
Saw a super clean E36 M3 today at a Publix in Pensacola
Old Jun 25, 2025 | 07:25 PM
  #4385
e30cabrio's Avatar
I was suposed to get the Sequoia back today, shop called, said ICE arrested 2 mechanics that had bogus papers so maybe next Wednesday
Old Jun 27, 2025 | 02:14 PM
  #4386
e30cabrio's Avatar
Finally working on it!
Never thought I'd be glad my car was invisible.
But I can still track it as long as an iPhone is around.
Old Jun 28, 2025 | 10:56 AM
  #4387
e30cabrio's Avatar
Wife had another procedure yesterday, implant expander removed, area cleaned out, new one put in. The surgery went well, they added a pico 7 wound vacuum to keep negative pressure in there & minimize infection, which buzzed all night, Dr said they are 99.9% reliable, but this means it is defective, so had me cut it off.
Whoo hoo! we win the negative lottery again!!
https://www.possiblewithpico.com/patient-info
Got good batteries at least.
Old Jun 30, 2025 | 08:10 AM
  #4388
e30cabrio's Avatar
These came yesterday, I like the magnetic holder, my drawer space is full & the 17mm bottom makes it easy to get a wrench on & slip them into tight spaces. 24-6mm.
Old Jun 30, 2025 | 10:27 AM
  #4389
That pump buzzes in case of an issue or is the buzzing the sound of it working? Looking at the link you sent, it does not have audible or tactile user feedback and only the lights on the top indicate issues or proper function.
Doctors will tell you all kinds of bogus BS when it comes to device reliability but I can tell you with my professional opinion as someone who has been working in med device for the past 13 years that nothing is designed to be 99.9% reliable and most definitely not a disposable temporary use external pump that isn't even remotely critical to sustaining life. I've worked on external pumps that have to work otherwise someone could die and they are rated at 99.5% reliability.
Old Jun 30, 2025 | 11:12 AM
  #4390
e30cabrio's Avatar
It was a recurring buzzing that kept her up all night. I have 0 knowledge of the failure rate of medical devices, that's what the Surgeon said.
Even if it had a 51% positive outcome rate us getting a bad one is outside the normal negative rate. Sorry if I offended you, also thanks for the empathy regarding the cancer, needing 2 additional procedures, and all that goes with that.
Old Jun 30, 2025 | 11:23 AM
  #4391
No offense at all and apologies from me on lack of empathy regarding your situation. My comment was more so such that you can have an informed idea of how this stuff works and how they're rated, docs are great at what they do but they don't get the device side beyond the intended use so wanted you to feel better about the fact that you're probably not in some 0.01% camp of people having a bad device. Also, reliability isn't calculated on a linear scale, it's exponential so going from 99.5% to 99.9% requires exponentially more confidence/testing/data to make it happen.
Anyway, the buzzing noise is probably the pump working as they're hardly silent and especially so for the temporary use ones. To be safe, I'd suggest you check the indicator lights and see if there are any error codes present. I don't work for (and never have) Smith and Nephew but a lot of these function in similar ways and the way they communicate error/fail states is a federally regulated thing so they HAVE to indicate to you that there is a fault present in some way that would make you take note of the issue consistent with the risk level of the error present. We had one device that was for life sustaining support and it had an absolutely ear piercing alarm powered by a separate battery AND capacitor that would go off if the device took a shit and/or lost power. Testing that thing was annoying AF but understandable given the effects.
I sincerely hope that the next few procedures go off without an issue and you start getting some good news ASAP, you all really need it. My work is starting to migrate more into interventional oncology treatments so this stuff hits home for me on a professional front.
Old Jun 30, 2025 | 11:36 AM
  #4392
e30cabrio's Avatar
Thanks, Her issue was the left breast keeps getting infected, they cleaned & R&R'd the expander 2x now, he said if there was puss this time (was not last time) he would not put it back & another procedure using either muscle from the abdomen or tissue from the back would be a future thing (unless we opted to just go there now) This has been holding up radiation so it needs to be over asap as the initial dual mastectomy was in April.
He said it was all good in there so he put a new expander in & upped the antibiotics he used as well as putting her on another, stronger antibiotic she is talking now.
We're just ready for this to be over, it is seriously scary shit. (oh and we are waiting for the result of a biopsy last week from near the pancreas found by the pet scan) so yeah, really fucked up year.
Old Jun 30, 2025 | 12:02 PM
  #4393
Hoping for the best for you both.
My wife's dad had to have a partial mastectomy earlier this year & has some pancreas/liver stuff going on as well, so I can empathize a bit.
Old Jun 30, 2025 | 12:10 PM
  #4394
e30cabrio's Avatar
I meant to address the buzzing/lights. Based on searches, it said the buzzing was most likely a leak, although it has a leak light that was never on except during "boot up." Seeing as its purpose was keeping negative pressure in there, I can see the noise being normal operation, unfortunately, it was really loud. The Dr. said just cut it out, so we did.
Old Jun 30, 2025 | 12:29 PM
  #4395
ttribe's Avatar
I lost my dad to pancreatic cancer 23 years ago. I REALLY hope that biopsy comes up negative for cancer.
Old Jun 30, 2025 | 12:32 PM
  #4396
e30cabrio's Avatar
Sorry ttribe, I get it. Pretty much everyone in my family that died has died of cancer, scary, scary shit indeed. Thanks
Old Jun 30, 2025 | 12:57 PM
  #4397
We're 'fortunate' that my FIL's isn't pancreatic, it's a neuro-endocrine that's on his pancreas. He starts treatment for it this week.
Old Jun 30, 2025 | 01:08 PM
  #4398
Oh man, I'm sorry to hear all the trouble you're having. Definitely hoping for the best for you and your family and also REALLY hope that biopsy comes back negative.
Old Jun 30, 2025 | 03:40 PM
  #4399
e30cabrio's Avatar
Thanks, waiting for results sucks.
Old Jul 1, 2025 | 04:28 PM
  #4400
e30cabrio's Avatar
Results are finally in, thankfully, it's benign.
