rockstar143's 2013 CTS-V SUV Wagon Thread - GM Owner & Cut Springs
#2243
Might as well have been bracket racing.. Shiett!!
#2244
Jesus.....
#2246
![what](https://acurazine.com/forums/images/smilies/what.gif)
#2247
What's super crazy is the mods list on that V..
I know it's on welds and slicks.. but under the hood:
2.19 upper pulley (stock lower)
5" CAI
Meth
cat back, gutted cat
Cam
heat exchanger / 5 gal icechest
Tune
Some polishing here and there..
That's it.. shiet.
I wonder what cam he's running
5" CAI
Meth
Cam
Tune
That's it.. shiet.
#2248
guys running just a upper / lower pulley, high-flow exhaust, tstat, CAI, injectors, and tune are in the 10's trapping in the mid / high 120s.. no cam.
freaking crazy to me..
Oh Sickest TL (10-31-2016)
#2250
That guy hooked pretty damn well. If I were driving it, I'd probably have closer to 2s 60ft. I think his 60 was near 1.5s.
#2251
Granny shiftin', not double clutchin' like you should...
#2252
Received 7,772 Likes
But... Coupe. ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
And look at that stance. What do you think that is? Like 25mm spacers?
#2253
Hella flush, brah... at 130MPH
![Drag](https://acurazine.com/forums/images/smilies/drag.gif)
#2255
Jason, go ahead and order the springs!
Okay, soooo...
I decided to give the wagon a rear suspension makeover.
First up, new rear magnetic ride control shocks...$494 shipped.
I'm really glad I did this. Rears feel TOTALLY revamped and if this is how the suspension is supposed to feel then I'm glad I decided to stick with mag ride. Sport VS tour is VERY obvious now.
I might swap the fronts too and then sell the NON blown front shocks on ebay.
Fuckin brake dust!![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
but worth it...I found that if I foam gun the pressure wash, most of the dust comes off...
![Name: 20161028_161149_zps0dg7j37y.jpg
Size: 129.4 KB](https://acurazine.com/forums/attachments/car-talk-5/58320d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_161149_zps0dg7j37y.jpg)
New MR
![Name: 20161028_164122_zpsnjtvso8b.jpg
Size: 191.6 KB](https://acurazine.com/forums/attachments/car-talk-5/58321d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_164122_zpsnjtvso8b.jpg)
Even the side I didn't think was leaking...WAS leaking
![Name: 20161028_170747_zpshqz8ndtn.jpg
Size: 96.3 KB](https://acurazine.com/forums/attachments/car-talk-5/58322d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_170747_zpshqz8ndtn.jpg)
![Name: 20161028_170839_zpsve4yjpuk.jpg
Size: 185.5 KB](https://acurazine.com/forums/attachments/car-talk-5/58323d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_170839_zpsve4yjpuk.jpg)
the bolt likes to get stuck in the non bolt side threading...this was how I fixed it otherwise the bolt just spreads the lower arms![Bored](https://acurazine.com/forums/images/smilies/bored.gif)
![Name: 20161028_165916_zpssm7yzjk5.jpg
Size: 112.2 KB](https://acurazine.com/forums/attachments/car-talk-5/58324d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_165916_zpssm7yzjk5.jpg)
easier to swap MR sensor over while old shock is off the car
![Name: 20161028_171024_zpss0smpci2.jpg
Size: 160.9 KB](https://acurazine.com/forums/attachments/car-talk-5/58325d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_171024_zpss0smpci2.jpg)
after some FB messages with Tony NorcallSS...I confirmed that it would indeed be good to shorten the rear bump stops...so I cut the bottom piece off
![Name: 20161028_173817_zpse3fpskxv.jpg
Size: 126.5 KB](https://acurazine.com/forums/attachments/car-talk-5/58326d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_173817_zpse3fpskxv.jpg)
![Name: 20161028_174109_zpstj84tstg.jpg
Size: 120.2 KB](https://acurazine.com/forums/attachments/car-talk-5/58327d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_174109_zpstj84tstg.jpg)
In addition to that...I rotated tires...and bumped the lower cradles in for as MUCH camber as I could get. The good news is, it also bumped the height up a bit so no more saggy ass
Perfect spacing now.
After seeing bad toe wear on the rear, I decided it was better to bump up the camber and remove spacers if necessary. So far haven't touched fender so spacers are staying.
I was at -2.6 camber before on the rear...-1.1 now. after moving the cradles the tow and thrust angle were SO far off, it was scary as fuck to drive down to get the alignment.
![Name: 20161029_154110_zpsvyws2kwj.jpg
Size: 129.8 KB](https://acurazine.com/forums/attachments/car-talk-5/58328d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161029_154110_zpsvyws2kwj.jpg)
![Name: 20161029_163615_zpsmkpahrj6.jpg
Size: 98.1 KB](https://acurazine.com/forums/attachments/car-talk-5/58329d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161029_163615_zpsmkpahrj6.jpg)
PERFECT stance
![Name: 20161029_171539_zpsssfj7yiy.jpg
Size: 178.1 KB](https://acurazine.com/forums/attachments/car-talk-5/58330d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161029_171539_zpsssfj7yiy.jpg)
Also while battery was undone had my neighbor's daughter lending a hand
![Name: IMG_1932_zpspfunvdkq.jpg
Size: 111.4 KB](https://acurazine.com/forums/attachments/car-talk-5/58331d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-img_1932_zpspfunvdkq.jpg)
Green filter in...although it's raining today so not a good day to test it out...I took the opportunity to put some threadlocker blue on the lower ground bolt too...
![Name: 20161028_193325_zpsh77oewcu.jpg
Size: 176.9 KB](https://acurazine.com/forums/attachments/car-talk-5/58332d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-20161028_193325_zpsh77oewcu.jpg)
and bought another foam lance to try on this electric pressure washer...I think if I fill the soap and rinse buckets first...I actually like this way of washing a car. I'll go on craigslist and buy one.
one of my car bud's made this...![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Name: IMG-1189034741_zpsub6osl0m.jpg
Size: 122.5 KB](https://acurazine.com/forums/attachments/car-talk-5/58333d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-img-1189034741_zpsub6osl0m.jpg)
and lastly, thanks to the awesome sound of the exhaust and driving it in manual mode and downshifting and holding gears...
officially a pig
Okay, soooo...
Fuckin brake dust!
New MR
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
PERFECT stance
officially a pig
![Name: Screenshot_20161029-152559_zpsmptlpf93.png
Size: 98.7 KB](https://acurazine.com/forums/attachments/car-talk-5/58334d1501317634-rockstar143s-2013-cts-v-suv-wagon-thread-gm-owner-cut-springs-screenshot_20161029-152559_zpsmptlpf93.png)
#2258
The following 2 users liked this post by thoiboi:
rockstar143 (10-30-2016),
ttribe (10-29-2016)
#2263
Fantastic work as always, J!
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
#2264
AZ O.G NoOldManVetteOwner
Stance looks great. Strong work once again J.
Now time for moar powaaaaa
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
#2265
![Monocle](https://acurazine.com/forums/images/smilies/monocle.gif)
Thanks boys!
Yeah, they are...although I'm almost mexiflush with the added camber since the whole assembly got bumped out...
front shocks are a strong possibility...then I'd have a totally refreshed magneride that SHOULD be good for another 70K miles or more.
Yes, more power!
Wait...NOOOO you want me to get a ticket?!?!
LOL...
Damn thing moves, boy.
#2266
Too soon ese!
Word on the street is PSS will wear a lot faster if you swap them left to right..
![Whistle](https://acurazine.com/forums/images/smilies/whistle.gif)
#2268
They're not directional, but I can imagine the compound getting a wear pattern through repeated heat cycles, especially as soft as they are.
Then switching them up will wear down quicker.. Might be a bad rumor, but you can be our guinea pig.
Tires are asymmetric though, so definitely wouldn't flip them. Are you talking about the rear with the rub?
![Bite Lip](https://acurazine.com/forums/images/smilies/bitelip.gif)
#2270
J, I think you should be rolling in some Nankangs or Nexens.. fuck expensive gripey tires.
![:O](https://acurazine.com/forums/images/smilies/embarrassment.gif)
#2271
Save a set of NT555r rears for business..
#2272
Received 3,817 Likes
Oh good so no more rubbing or saggy ass anymore?
#2273
Also from the look of the one picture you posted you now have a full one finger gap in the rear?
#2275
i don't think swapping left to right matters on PSSs.... even on regular use, most Vette guys only get 7.5k miles out of them... can you imagine, new tires every oil change???
#2279
I almost bought a second set of them the other day cause they dipped down to $600 shipped but now they are back up again.
#2280
Damn, did they?
I could have gotten $600 with the rebate card on DTD but they ran out of stock.
I wish I could make up my mind on wheels...if I'm definitely getting wheels I want to hold off until i know if I'm going 20" or what.
Jason, I think the main take away is that you can adjust the rear cradles enough to make a pretty decent visual difference. I am happy to have only -1 camber now though, I can't lie...everyone would ask me why my car was pigeon toed before.
I can't tell yet because there's some gap but I'll have a neighbor and Betty ride with me to see if I make contact with fender...If so, I'll pull spacers...with no camber the rear is almost TOO flush now anyway. LOL.
