The Official Honda S2000 Thread
#8241
Turd Polisher
we will just plastidip you yellow and call it a day.
#8246
#8251
Turd Polisher
As of right now, my tool set is really not that big, but they're quality pieces and I've had no real issue(s) with them.
My Craftsman mini-chest contains 3/8" & 1/2" & 3/4" ratchets (turny clicky things) w/ all necessary short & long metric sockets. Full wrench set (w/ Torque wrench). 4 Jack stands, 2 x 2 Ton Jacks, tons of prybars & breaker bars and a large can of PB Blaster.
There's more I'm forgetting, but I'd eventually like to get some air tools, larger compressor, and some Racing ramps.
SamDoe1 (03-22-2016)
#8256
If you're buying an air compressor just to use an impact...skip it and buy a nice cordless impact.
No...not a craftsman or Harbor Freight one. A good one.
I barely ever use my compressor.
Well...unless I need to use an air ratchet or cutoff wheel.
Or blow gun.
Dammit. Buy both
Or blow gun.
Dammit. Buy both
#8257
Where do you get your snap on tools J? Fell off the truck MIA special?
The ratchets I have are just crappy Home Depot Husky and Stanley ones. I considered picking up a set of Craftsman but would much prefer a solid Snap-On set of course
#8258
Air tools are one use for compressor. Personally i would use it for pressure washing, pumping up air in tires and bikes, blowing myself
Seems like a staple to have in a DIY's garage no?
#8259
I have all higher end craftsman stuff and for the minor wrenching I do on my own, it has been just fine. I have friends with nice snap on stuff and it's definitely better but I just can't justify that much more for my application.
This is how I've ended up with a lot of things.
I've had a compressor for a while so I just run a pneumatic impact. If I had to do it again, I'd definitely get the cordless electric. Sh1t I might just do it anyway.
Or blow gun.
Dammit. Buy both
Or blow gun.
Dammit. Buy both
#8260
I have two compressors lol. One I use in the garage to run the bigger things (HVLP gun, impact, pumping up car tires, bike tires, etc) and then a smaller portable one to use with nail guns, staple guns, blowing off dust, etc...
#8261
The only tools I use are my hands
Unless I'm trying to get into a really small space. Then I use my penis.
#8262
#8263
#8266
Whoa whoa whoa whoa.......
#8268
Turd Polisher
Gotta do an oil change on the ITR when I get home. This gives me an excuse to drive it mercilessly. Which is how I always drive it. But now...there's an excuse. So...I'm excused AF.
Is what I'll tell the cops.
#8273
Small one is 6 gal but a relatively low flow rate (2.5cfm@90psi). The bigger one is actually a smaller tank at 4.5gal but has enough flow to sustain a medium size impact indefinitely (5.0cfm@90psi).
Stop with the tool pr0n or tag it NSFW.
#8274
Turd Polisher
RPhilMan1 (03-23-2016)
#8275
LOL my ebay and pawn shop finds...took a lot of hours and some spray paint and the help of my buddy wacker since snap on is guaranteed for life (or as long as they make replacement parts).
I don't have a little compressor but have often wanted one for small nail jobs etc...I have a big husky...can't recall the gallons but it'll run a sustained 125-150 cfm...with a decent hose and earthquake HF dual impact gun rated at 750 FT/LB I can even get the Crank Poullain.
#8276
Thanks Tyler...don't be jealous, my floors chip! But Rustoleum gave me a full refund so I can't complain...every few months I just mix up a batch of valspar epoxy I bought to patch and touch up so it's not obvious. I still love how clean the floors are in there, but kinda miss the rugged no shits given durability of bare concrete ass.
TylerT (03-22-2016)
#8277
I've considered doing that epoxy on the garage floor but the problem is the slab has a large crack right down the middle (stupid CA earthquakes ) Does Rust-O-Leum talk about that at all? Would their epoxy effectively just fill in that crack? I could just ask google but then that would defeat the conversation
#8278
Most modern impacts don't use that much air, usually less than 5.0cfm@90psi. 125-150cfm is commercial level compressors, no way that's in your garage as it would be absolutely massive. It's probably 12.5-15cfm.
#8279
Prep prep prep...
and do yourself a flavor and rent the fkng machine grind the first layer down to have a good bite. The acid only does so much...
my biggest issue is I did like 3 acid washes to ensure a perfect bite...1 of citrus mickey mouse shit i eat with my cereal and 2 of the muriatic shit that hussein/hitler used to put in people's cereal. STILL chips...but I've noticed it's mainly in areas where the concrete had cured with a fine dust layer that the epoxy adheres to right before letting go and flying away.
SO...
for your crack...
SO...
for your crack...
