@TylerT @rockstar143 and maybe others...
Friend of mine is interested in a B8.5 S4. Since I know you both know WAY more about these cars than I do, I told him I'd ask you all. What are your thoughts? Big things to go wrong, what to look for, expectations of maintenance, what to do/fix right after buying, etc?
rockstar143 (06-19-2022)
Turd Polisher
Off the top of my head which largely depends on mileage:
PCV system, waterpump, thermostat, carbon cleaning, DSG service, and maybe a supercharger service are the main ones I can think of.
I feel like nowadays the ad / car / service records talk - if he's willing to spend $25-$30k on a nice B8.5 with records indicating most of those things have been addressed, I think he'll have a good / trouble-free experience.
@rockstar143 probably has more input on this than I do.
Also .. if he doesn't care if it's auto / 6MT - I think the B9 S4 is something to consider as well if he wanted to spend the $30-35k range - much more potent / mod friendly motor, ZF8 is a great transmission ... but, no S/C whine.
The following 3 users liked this post by TylerT:
I wouldn't have many concerns. As you know 8.5 means no mechatronics failure point...just a DSG fluid and filter swap at 75K...easy peasy. I personally had to swap out the low pressure in tank fuel pump around 85K for $400 and 20 minutes of time.
Other than that...I have done the valve cleaning because I wanted to...didn't have any codes for it. At some point the thermostat will likely have an issue but who knows...it did at 85Kish on my S5 and hasn't been an issue on my 105K S4. So that's not a
THING you have to do but if you do...it's no biggy...tstat, water pump, pcv all at the same time. There are a lot of documented high mileage 3.0T(SC) on the forums that are still going quite strong. If the cats clog up or the starter goes that's a tight job but
that's not a KNOWN thing to happen unless you're dual pulley and beating the snot out of it all the time.
So with that said...I would highly recommend it. I have had mine for 35K almost all of which are stage 2 single pulley tuned without issue...for highway trips we load the kayak on top, bikes on the back and get 25 mpg...with nothing on it going the speed limit
it'll do over 30 with likely 400 awhp.
The B9 is definitely a monster with the tunes they are throwing on them and that is just a testament to how good a motor it is.
I think they are still a bit more pricey though...
SamDoe1 (06-27-2022)
Bought my first EV on Saturday, has on the fly switchable AWD/RWD, bright lime green & really quiet.
Spoiler
The following 2 users liked this post by 00TL-P3.2:
1killercls (06-28-2022),
Legend2TL (06-28-2022)
Like Tyler mentioned...
GEEZER
Self-propelled, of course, I'm much too lazy for a true push mower, but the yard is too small to justify a ZT/riding mower..
Need some help from the hive mind.
Anyone on here live in or close to Woodbridge VA, San Antonio TX, Jacksonville FL or Kansas City?
I know a few of you are in the Houston area, any thoughts on John Eagle Honda? They have an Accord 2.0T 6MT on the lot that I'm very interested in...
Whats up with RDX owners?
What's in Woodbridge? I'm not exactly close but...
There's an Accord 2.0T 6MT in each of those cities. They are unsurprisingly hard to come by, only 33 for sale in the country so I'll likely have to travel to get one.
Need some help to check them out from people who know cars to make sure they aren't duds.
@civicdrivr Link to car:
https://www.cars.com/vehicledetail/8...-599c73accffa/
Car in Houston:
https://www.cars.com/vehicledetail/1...-ac8fd36da3d9/
Jacksonville: https://www.cars.com/vehicledetail/a...-8f59b95dbd8f/
Car in Houston:
Avoid the Koons dealer chain.
SamDoe1 (07-01-2022)
Never heard any complaints about JE, but didn't know they had a store in SA. A bit of a drive for me (3-4 hours each way).
Had a former coworker at another Honda dealer in Houston that used to work for JE, don't recall him having any complaints as an employee, but this was back in the early 00s.
No idea why they have a 1 start rating, but only have 2 reviews. I'm sure a lot of dealer's ratings have gone down with supply shortages & inflated pricing.
That dealer is about 30 minutes from my office, but could be over an hour with how Houston traffic can be.
Another Audi question a friend has. Any experience with the 4.0T motor and trans combo? Big things to look for/worry about?
Turbos.
Marcelechka (07-11-2022)
The early B8 S5s have the NA 4.2l, which is what he has.
Ah, but Sam asked about the 4.0T, not sure which models got the boosted 4.0
If it were an MB, I'd know more
I think the bigger boys like the S6, S7 and obviously RS stuff...
only thing I've heard is oil starvation from the oil feed screens to the turbos getting clogged.
I think the fix is to remove them.
SamDoe1 (07-08-2022)
Turd Polisher
Assuming it has a 4.0T, look for air suspension leaks, too.
Otherwise, make sure services are up to date and it should be relatively trouble free.
Sounds like a good time to upgrade some turbo while he is at it.
Turd Polisher
Rawr.
Isn't @Marcelechka in a 4.0T?
B8.5 S4/5s were all 3.0T.
4.0T was offered in C7 S6, S & RS7, and S8.
As others have said, depending on mileage - wouldn't hurt to check and or replace screens, turbos, injectors, plugs & coil packs, mounts, & suspension (bag / cylinder).
Carbon build up isn't an issue for any of those cars mentioned above as they all have direct injection, which is a plus.
The following 2 users liked this post by Marcelechka:
civicdrivr (07-12-2022),
Doom878 (07-12-2022)
@Marcelechka
Carbon build up IS an issue BECAUSE they have direct injection!
Port injection cleans the back side of the intake valves, direct doesn't.
Multiport is the best of both worlds.
The following 3 users liked this post by rockstar143:
Rawr.
I tried looking up threads where the 4.0t was mentioned with the CB issue, and hit dead ends.
https://www.audiworld.com/forums/a8-...si-v8-2884294/
https://www.audizine.com/forum/showt...alnut-blasting
There was of course, no issue in finding info on the B6/7/8 config
I was no exception to this @ 100k miles...
I'm told the WMI should help with this going forward, but who knows.
Before & after pics
Before & after pics
rockstar143 (07-12-2022)
anything you do to wet the back end of the valves to help keep that crud from NOT sitting there not burning off...
should be golden.
Again, 100k miles from now it'll be on it's 3 owner down the line from you anyway, or you just have it cleaned again.
Now that I've done it twice I can say it ain't no big thing but not my favorite thing.
Believe it or not I probably should do it to the Suburban of all things...
should be golden.
Aman (07-24-2022)
Yikes, those looks mighty coked up.
Looking at a slightly more practical commuter vehicle in addition to my TL-S: https://www.weavermotorsportssales.c...wagon/86219760
Looks like someone swapped on waffles already. Has a rear end damage history so not great but otherwise decent?
Anything to know about these TSX wagons?
Prices are jacked so not sure if this is an ok deal or a really bad deal....thoughts?
Price seems fair compared to comparable vehicles with similar miles. There's not too many out there to compare to.
Looks like the dealership just bought it from auction last month for $10,600 - $1k more than MMR estimate. Add the selling fee and possible shipping, they're in it for around $11,000.
nist7 (07-16-2022)
So they're making $4k profit and they list on autotrader the following:
Due to the current market situation we have priced ALL of our inventory cars at our NO HASSLE - BOTTOM DOLLAR - CASH - price. These prices are based on NADA retail and current market availability and values.
Please note that tax / title / tag / registration (NC residents) and dealer fees will be in addition to the advertised price.
These prices reflect our bottom dollar of profit that we can keep the doors open - if that price does not work for you for whatever reason - we thank you for the interest - and we wish you the best of luck with your search. Any emails asking what's the bottom dollar or our best "CASH" price will be ignored.
Someday, an RS6 Avant+
Last Friday I brought my car in for some metal clicking sound when turning the steering wheel and they told me it was because of my rotor ?? (i thought it was either the steering rack or some suspension stuff) but whatever, as long as they fix it.
Got a 2022 7 series with 2000 miles as loaner. Loved it the first day and hate driving it starting the 2nd. It reminds me so much of my 1997 Avalon.
Now a week later, they replaced the rotors and pads and called and told me that the porter hit my car while moving it
Front bumper will need to be replaced.
Obviously, i am not happy but they will throw in the AC service for free (My AC starts to smell like shit). But i am more mad about the fact that i have to drive the stupid 7 series for another week.... #firstworldproblem
Complains about 'free' luxo-barge.
When I had my C, the usually loaner was a CLA/GLA
Got out of those by having 2 kids in high back carseats. Hard to install with the low roofline.
Usually got a C, GLC and once a GLE.
No way they'd have S for a loaner.
Hard on the outside, soft on the inside
The following 2 users liked this post by oonowindoo:
godfather2 (08-23-2022),
srika (08-19-2022)
Besides i think the loaner desk girl liked me
That always helps. That one looks decent, but I'd put my money on an S over a 7
civicdrivr (08-19-2022),
CLtotheTL32 (08-21-2022)
