Don't make my mistake
Old Nov 1, 2011 | 12:44 PM
Mr Marco's Avatar
Here is a rookie mistake I made. I wasn't going to post this because it's embarrassing, but it's good info so no one else has this issue occur. Ignore the geographical information, it was posted in Regions first.
When I was driving home I changed lanes in the tunnel quickly and noticed that rear of the car kinda slid into the lane oddly. I needed to pick up some wheel locks for Carries car at RTA on Canton Rd so I topped the hill and started coming down to the dealer. All of the sudden I had a weird vibration and pulled over into a gas station to check.
The right rear was loose, almost fall-off loose. I took out the jack and twisted her up off the ground, took off the wheel and nearly shit my pants. It looked like the hub was badly damaged around the centric ring. Then I looked at the hub closer and realized that it was the ring from the inside of the wheel.
It turns out that when I rotated the wheels/tires the hub centric ring spacer from the Breyton wheel had gotten stuck on the rear hub. I hadn't noticed it (because of the dark garage and angle of application) and put the other wheel, with spacer fully intact, right on top of it. There was just enough room for 1-1/2 spacers. When I tightened it up the wheel snugged up evenly and I didn't notice any gaps, but it was never touching the actual hub. So when I changed lanes the outer edge of that soft alloy on the spacer started to give and the wheel started wobbling. It got worse and worse until I pulled over.
The inside of the wheel was a bit chewed up as well but fortunately the other spacer was fine. And since the inside of the ring that got stuck on the hub was undamaged, I was able to file the excess aluminum away and salvage it and put it back on the front wheel where it belonged.
In the 20 years I've been swapping wheels out I've never had this happen, but I wanted to share in the hope that it never happens to any of you.
Old Nov 1, 2011 | 12:46 PM
I'm glad you're still here to post.
Old Nov 1, 2011 | 12:49 PM
chill_dog's Avatar
Oderint dum metuant.
Yikes! Glad you were able to catch it before anything serious happened.
Old Nov 1, 2011 | 12:55 PM
AZuser's Avatar
_
Similar thing sorta happened to me when I was rotating my wheels last time. I tried and tried to put the wheel on the rear, but it just wouldn't fit over the hub. At first, I was like WTF? So I remove the wheel and look to find the hub ring from the other wheel (now on the front) stuck on the hub.
Now whenever I rotate wheels, I always make sure that the hub ring is still on the back of the removed wheel before I mount it.
Old Nov 1, 2011 | 01:07 PM
Mr Marco's Avatar
A lesson learned. If there wasn't room enough for 1-1/2 spacers I might have noticed. It was as if Breyton had meant for a wider spacer to be used, but the TireRack cheaped out and put a thinner one in place. I'll have to take a pic of the damaged wheel so everyone can understand what I'm talking about.
There's such a big gap between the wheel mounting surface and the surface of the spacer that I wonder if the ring on the hub is as secure as it should be. It's at least a 2MM difference. That's a big dip on the inside of my wheel. It might just barely be touching, which could mean wheel balance issues for me in the future. I think I'll shop for thicker spacers this afternoon.
Old Nov 1, 2011 | 01:37 PM
HEAVY_RL's Avatar
Good on ya for posting.
Old Nov 1, 2011 | 01:50 PM
AMGala's Avatar
Lamborghini Aventador FTW
Might it make sense to put a little anti-seize between the ring and the hub to prevent it from getting stuck? I know some people also put some between the ring and the wheel to prevent them from getting stuck to the wheel.
Old Nov 1, 2011 | 02:31 PM
Mr Marco's Avatar
Good excuse for me to clean off any corrosion and paint the brake rotor too.
Old Nov 1, 2011 | 03:27 PM
stogie1020's Avatar
Needs more Lemon Pledge
I don't know what any of that means but DAMN, glad you are OK!
Old Nov 1, 2011 | 03:50 PM
dallison's Avatar
registered pw
wow, that was a close call. I thought it was going to be a "i crossed the white line in the tunnel and got pulled over" thread after reading just the 1st two line.
Good thing you were able to get stopped safely.
Old Nov 1, 2011 | 04:03 PM
JS + XES's Avatar
I drive a Subata.
glad you are alright
Old Nov 1, 2011 | 04:45 PM
srika's Avatar
Moderator Alumnus
wow, glad you noticed the issue and were able to pull over in time!
Old Nov 1, 2011 | 05:09 PM
BigPZ's Avatar
Registered 3.5L Member
It's like changing your oil and not noticing that the gasket from the old filter had remained stuck on....only noticing once the new filter is installed and there is oil ALL OVER the garage floor...only happens once
Thanks for sharing your moment!!
Old Nov 1, 2011 | 05:55 PM
RaviNJCLs's Avatar
Damn....glad you are OK.
Old Nov 1, 2011 | 05:59 PM
Steven Bell's Avatar
+1
Old Nov 2, 2011 | 12:00 PM
CLpower's Avatar
teh Senior Instigator
i've done it as well, when I was about 17 ad put my factory wheels back on a car...didn't notice the hub ring had stuck on.
Old Nov 2, 2011 | 12:08 PM
SuperTrooper169's Avatar
In the Mid-South meow
Yep, I've done both, the filter gasket and the hub centric ring! Both times it only happened one time and never again. I always check both things if I'm chaning my oil or rotating my aftermarket wheels.
As you can tell from all the responses Mr Marco, it happens to everyone, so just count your blessings and be thankful nothing worse happened. Now just as long as it only happens once, then you're fine. If it happens more then once, you need to stop working on your own car lol.
Old Nov 2, 2011 | 02:41 PM
fuzzy02CLS's Avatar
Honestly unless you do this yourself you'll have it happen to you too. Has happened to me several times. Getting new tires the monkeys don't realize the hub rig sitting on the hub & then mount the wheel with the one already on there to that. I had to take the wheels off a few times to correct this.
Old Nov 2, 2011 | 03:17 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Lucky
Old Nov 2, 2011 | 11:58 PM
PortlandRL's Avatar
Dang, man...glad you're okay.
You stop at that 76 across from Lexus?
Old Nov 3, 2011 | 12:53 PM
Mr Marco's Avatar
Yep, is there video of the idiot with the wobbling wheel?
Could have been worse
Note the excellent use of the HOV lane
Old Nov 13, 2011 | 02:49 AM
ClayBartrug's Avatar
9th Gear
This had never occurred to me, but I can see it happening! Thanks for sharing the info!
Old Nov 13, 2011 | 11:26 AM
civicdrivr's Avatar
I had a similar wobbly wheel story a few years ago. I came out of the optometrists office, hopped in the car, and started to drive home. The rear shook like crazy above 40mph. I thought I may have lost a wheel weight. I got home, looked at the passenger side rear, and saw that I was missing three of the five lug nuts. One was loose, so effectively only one was holding that wheel on.
That was back when the car was stock. I think someone tried stealing my lug nuts, it wasnt the best part of town.
Old Jan 14, 2012 | 03:08 PM
Mr Marco's Avatar
Update
Finally took the wheel off the RDX and put the snows on for our fast approaching winter storm.
Here is a pic of the damaged wheel. Not too bad, but you get the idea.
I plan on a BBK kit soon so I'm hesitant to deal with any rotor corrosion issues that seem to be worse on this side of the car (for some unknown reason?). I don't want to scrub my elbow off this winter only to toss these in the recycle bin in the spring.
oo7spy
Jun 19, 2023 12:48 AM
cycdaniel
Dec 17, 2019 10:58 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
johnpancakes014
Apr 8, 2016 06:47 AM
