Can you add a sub in 04 tl
The Third Ball
Received 5,105 Likes
The 04 tl already has a sub in it
it has a whole 5.1 system, the sub is located in the rear deck.
but im sure you can add an aftermarket.
Flap.
the stock sub in the 04 tl is better than the basslink imo
the 5.1 system is pretty good, youd have to change a lot to make it worthwile....
there is an av forum :P
CLS MEMBER
what is the basslink??? and i know it has a sub already but i wanted to add a aftermarket sub and amp for more bass...would i need the basslink to do that or another adapter???
Flap.
a basslink is an all in one unit, amp +sub, the stock sub is fairly nice, but if you wanted to replace it with a normal sub in box in the trunk setup you could... just take the signal from the hu and throw it into an amp... etc. an adapter or harness might make this more simple... but by adding a subwoofer that is larger, and changing the loation the imaging and surroundsound aspect of it will be thrown off some.
emailnatec
29
09-28-2018 04:27 PM
soupi
14
11-15-2015 11:15 AM
