AC Help- 99 Jeep Cherokee
Old Jul 15, 2008 | 02:16 PM
bent09's Avatar
horny =
So I have tried searching jeep forums but no one seems to have a resolution.
I figured I would ask the experts here.
The AC works but it is not really cold. It does not need to be charged. It never cools down the car enough for me to turn the blower down.
Where should I start or just take it to the dealer?
Old Jul 15, 2008 | 02:22 PM
fuzzy02CLS's Avatar
That sort of problem is usually a bad pressure switch. It should be screwed into the accumulator. It has a electrical connector.
Old Jul 15, 2008 | 02:35 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Could it also be a bad compressor?
Old Jul 15, 2008 | 03:12 PM
The Dougler's Avatar
Unofficial Goat
also check out the cabin filter and the condensor area, they could be plugged up with crap.
A real jeep guy would turn it into a air compressor
Old Jul 15, 2008 | 04:53 PM
fuzzy02CLS's Avatar
If the pressure switch is not working right the compressor will never turn on or off fully so that could lead to the belief the compressor is a fault. You need to hook up gauges to the high & low side to test this. You also need the test procedure & the settings from a service manual.
I've gotten very good with AC from fixing my Explorers. 99% of the problems & solutions are the same on any AC system.
Old Jul 15, 2008 | 05:02 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
Does your Jeep have the dual climate control? I know a ton of Grands have problems steming from it.
Old Jul 15, 2008 | 05:27 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
With out looking at it all we are doing is guessing, so far a lot of good guesses have been made but no guarantees that it is anything that has been suggested. In addition to what has been recommended check for vacuum leak, some AC controls need vacuum to operate and if there is no vacuum they don't work right.
Old Jul 15, 2008 | 05:30 PM
bent09's Avatar
horny =
Yep. I fixed the blower motor from melting away, taken it in several times for blend door, etc.
You guys gave me some good things to google on the jeep forums
I have had everything from death wobble to repeated ac problems. Might just trade it in for like an 02 MDX or something.
Old Jul 15, 2008 | 07:08 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
Im on both Jeep forums!
Old Jul 15, 2008 | 07:35 PM
coconut's Avatar
trees grow in
low freon?
Old Jul 15, 2008 | 07:39 PM
65 Fury Convert's Avatar
http://www.jeepforum.com
Old Jul 15, 2008 | 07:43 PM
Good idea... I also have a Grand Cherokee and experienced the same problems. I have a love it / hate it relationship with my Jeep.
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
TypeSJeff
Sep 22, 2015 01:34 AM
Skirmich
Sep 15, 2015 06:41 PM
bent09
Apr 24, 2003 10:33 AM
