2005 TechArt Cayman S
Old Nov 28, 2005 | 04:55 PM
Yumcha's Avatar
Old Nov 28, 2005 | 05:05 PM
DownUnder's Avatar
Not bad... not bad at all. Minus the dinky little rear wing it looks really nice.
Old Nov 28, 2005 | 05:31 PM
brianlin87's Avatar
ASM I.S. Design FTW.
I think it looks awesome. Better the dinky little wing than one of those huge GT wings.
Old Nov 28, 2005 | 05:45 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Hawt!
Old Nov 28, 2005 | 05:47 PM
einsatz's Avatar
I miss my 03 CL-S :(
I'd buy it
Old Nov 28, 2005 | 05:53 PM
stangg172004's Avatar
_____ like a rabbit
i love the look of the back in the 1st pic....
Old Nov 28, 2005 | 06:11 PM
BstonBruin's Avatar
Go B's Go
i love the whale tail
Old Nov 28, 2005 | 06:30 PM
S A CHO's Avatar
That was uncalled for...
Man, you got off on a shaky start with the first TechArt, but TOTALLY redeemed yourself with the 3 most recent postings...
indeed....
Old Nov 28, 2005 | 06:48 PM
Minch00's Avatar
Pit Stop?
Those wheels are such a waste on that car.
on the Gayman
Old Nov 28, 2005 | 08:40 PM
knight rider's Avatar
Rooting for Acura
I like that car. I has classic body lines. That TechArt version is even nicer.
Old Nov 28, 2005 | 09:33 PM
EmuMessenger's Avatar
Looks good, but needs the ceramic composite brakes!
Old Nov 28, 2005 | 09:47 PM
srika's Avatar
Moderator Alumnus
Yumchah, I would just like to say, "go you".
all notions of that nasty TechArt Boxster are now far away in my memory.... and continuing to fade away... good job.
Old Nov 28, 2005 | 11:39 PM
Sdog2012's Avatar
We dont love these hoes
i dont like it in silver but black is
Old Nov 29, 2005 | 02:27 AM
FiftyFive's Avatar
Moderator Alumnus
arent they slow
Old Nov 29, 2005 | 07:06 AM
bgsm1th's Avatar
on to the next one...
Originally Posted by FiftyFive
arent they slow
By Porsche standards perhaps...but overall, I would not consider them "slow".
Old Nov 29, 2005 | 07:47 AM
Black CL-S 4-Life's Avatar
Floyd Mayweather Jr.
Not a fan of the Cayman but this one is hot!
Old Nov 29, 2005 | 01:10 PM
DownUnder's Avatar
arent they slow
C&D got 5.1s to 60 and 13.4s @ 105MPH in a Cayman S. Doesn't seem slow to me but then again compared to a C6 Z06 which both are priced the same it's really slow.
Old Nov 29, 2005 | 01:19 PM
BadBadNeil's Avatar
The Designer
I've never really liked porsche designs but for some odd reason the Cayman I really like. I think it has something to do with the wheel well arches behind the rear window that I like much more than both the boxster and the 911.
Old Nov 30, 2006 | 11:13 AM
Yumcha's Avatar
Post 2006 Porsche TechArt Cayman S Widebody
Old Nov 30, 2006 | 11:14 AM
Yumcha's Avatar
Old Nov 30, 2006 | 11:16 AM
Yumcha's Avatar
Press release...
The TechArt Widebody based on the Porsche Cayman S doesn’t only offer spectacular design but also extra driving fun and agility. After the huge success of the Widebody concept for the current Boxster generation, the German tuner TechArt now developed a wide body version for the mid-engine coupe.
With the add-on fender flarings on front and rear axle the TechArt Widebody is eight centimeters wider than the standard car. The front extensions don’t only provide extra room inside the wheel houses but also improve the deventilation of the heated up air with their integrated wheel-house ventilation. The rear flarings are equipped with largely dimensioned air ducts to bring fresh air to the centrally placed engine.
Apart from spectacular, sporty design the TechArt designers of course paid attention to optimal aerodynamic efficiency. The TechArt front spoiler bumper reduces the lift at the front axle and improves the cooling of the front brakes with large air ducts. The TechArt rear apron with integrated diffuser rounds out the conversion.
The tail of the car can be alternatively upgraded with the large TechArt GT sport rear wing or a subtle rear spoiler.
Extremely broad wheels and tires make the TechArt Widebody concept for the Boxster complete: Specially for this wide body version they developed custom-made versions of the one-piece TechArt Formula five spoke wheel. The front axle is equipped with wheels in size 8.5Jx20, the rear axle is equipped with 12Jx20 wheels.
After extensive test drives, TechArt recommends tires in sizes 235/30 ZR20 front and 305/25 ZR20 rear for the Widebody. The height-adjustable TechArt sport suspension is specially set-up for these ultra-wide wheels and tires and the wider track of the car. The coil-over suspension doesn’t only provide an individual damping of the roadster but also lowers the two-seater car by about an inch. Cayman models with PASM system can be updated with the sporty set up TechArt VarioPlus coil over sport suspension. This suspension isn’t only adjustable in height but also in damping by a push on the button inside the cockpit.
TechArt also offers engine tuning for the Widebody. The two watercooled six-cylinder boxer engines can be upgraded with the TechArt power kits. They each consist of a sport air filter and newly programmed engine electronics. The result: 15 bhp extra power and optimized road performance.
Another performance option is the TechArt increase in displacement from standard 3,387 cm3 to 3,824 cm3. The increase is facilitated by a bore enlarged to 99 millimeters with the corresponding larger special pistons, and by the installation of a special crankshaft.
The engine conversion further includes sports camshafts. A modified intake manifold with special air filter system and an aluminum header provide ample combustion air. The perfect interaction of all these components including the fully stainless-steel high-performance exhaust system with high-performance manifolds is orchestrated by new mapping for the engine electronics.
With a maximum power output of 385 bhp and a peak torque of 300 lb-ft the TechArt displacement engine satisfies both highly sporty minded drivers as well as those pilots who want lots of pulling power from low engine speed.
Powered by this engine, the mid-engine sports car offers excellent performance: The sprint from 0 - 62 mph takes just 4.9 seconds, and with a top speed of 188 mph, the TechArt two-seater easily bests its production counterpart in this discipline, too.
TechArt offers individual full leather trims in all colors and designs for the Widebody. The range reaches from completing the ex-works leather trims up to a completely redesigned cockpit with special sports seats and ergonomically shaped airbag sports steering wheel.
Old Nov 30, 2006 | 11:17 AM
Beltfed's Avatar
Moderator Alumnus
I wonder if Cayman's are selling like shit?
1. I don't see that many.
2. The local dealer has like 12-13 of them lined up in front of the dealer.
Old Nov 30, 2006 | 01:55 PM
ShavedH22CL's Avatar
fear and Loathing
The widebody in white please!!!!
Old Nov 30, 2006 | 03:27 PM
TSXey's Avatar
Nick
OK with me
Old Nov 30, 2006 | 03:28 PM
TSXey's Avatar
Nick
...oops, I think that's NOT the widebody. Oh well.
Old Nov 30, 2006 | 04:34 PM
Crazy Bimmer's Avatar
oh my.
Old Nov 30, 2006 | 04:35 PM
Well their resale is pretty bad so im guessing they arent selling well.
Old Nov 30, 2006 | 05:12 PM
aesir11's Avatar
I think its mostly poor time to come to market. Not as many people pissing away money now that their homes aren't doubling in value every 15 minutes. On top of that they set the price point for them higher than the Boxster. Given the choice between a Cayman and a Boxster, I'll take the drop top.
Regardless I still see a fair amount of them cruising around my neck of the woods here in Phoenix. I just hope the market timing doesn't scare Porsche away from producing them long term, because I think they're a good addition to their line.
Old Nov 30, 2006 | 05:50 PM
Yumcha's Avatar
Whoa...never knew that!
Is there a reason why TechArt's don't sell well...?
Old Nov 30, 2006 | 07:01 PM
Was talking about a STOCK cayman.
Plus Techart stuff is $$$$
Old Dec 1, 2006 | 11:14 AM
U8INIT's Avatar
on the Gayman
Why do you think they are a waste...?
Old Dec 1, 2006 | 11:22 AM
Yumcha's Avatar
Oooo...so, a used Cayman is cheap...?
Old Dec 1, 2006 | 11:31 AM
Lord Helmet's Avatar
I'm here in spirit...
Hotness.
I saw a Silver Cayman S (I think it was an S ) one day when I was washing the Jeep. The guy was washing it there too. It was pretty slick. It sounded pretty healthy when he drove away too. I probably looked like a little kid staring at a one legged guy the whole time. I pretty sure my facial expression was
Old Dec 1, 2006 | 12:33 PM
BeemerKiller's Avatar
sex on wheels ....
agupta3224
May 23, 2017 08:30 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
