timing belt change
Old Aug 11, 2013 | 10:43 AM
marvin3210's Avatar
timing belt change
I have a 2006 TL with 156,000 kms that i bought a few weeks ago.I am going to do the timing belt change.It seems Acura Canada recommends a change at 100,000kms and in the USA they recommend 105,000 miles.Why the difference?
Old Nov 24, 2013 | 07:12 PM
2003av6's Avatar
Possible because of the colder climate, or you could be confusing miles/kilometres.
your maintenance minder system should call for it around 160,000km
I work at Acura and do this on the side for $400 cash, if interested e-mail me
kevin99_101@hotmail.com
Old Nov 18, 2014 | 08:01 PM
boomer70's Avatar
5th Gear
Hi 2003av6 .My 2006 TL that i just both has 200731KM. Does that meens that it has been done at 160 000KM, and i can i know???
Old Nov 18, 2014 | 09:16 PM
gnuts's Avatar
3.5 psi
Only way to know if it has been done was to get proof from the previous owner which you should have done, or ask the dealer to check their records.
Old Nov 20, 2014 | 05:20 AM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
^one way of knowing, even tho not 100%, is to take a look at the battery clamp bolts. In order to hold the timing belt adjuster in place while you remove the belt, you need to grind the edge of that clamp so that it can thread down a little hole next to the belt. So, if any of the two battery clamp bolts is grind/filed at the edge, you know the belt has been changed. Or at least there is a good change it was - lol.
Old Feb 17, 2015 | 05:20 PM
agray56's Avatar
My '07 TL-S has 106,000 kms and the dealer sent a letter saying the timing belt should be done at 7 years or 160,000km, quoted me $1,200 but if I booked early would give me a 25% discount lol.
I know there are kits available through US sources for all the necessary parts like this https://www.rockauto.com/catalog/mor...id=404&jpid=16 for $221 USD. Are there any good CDN parts suppliers of similiar kits?
EDIT just found the same kit on Autopartsway.ca for $410.83
Old Feb 26, 2015 | 08:31 PM
Bankz's Avatar
I went with Rockauto paid only 278 canadian for the timing belt kit.
Old Feb 28, 2015 | 11:52 AM
agray56's Avatar
Ordered mine, $177.79US + shipping to Calais
Old Mar 2, 2015 | 12:05 AM
03RL_Tiller's Avatar
6th Gear
I just got mine done on my '03 RL. The recommendation was 105000 miles, got it done at 106250 and the old belt looked identical to the new one. I should've saved the $510USD in labor to get it done. I'm sure I could have gone to 160000 miles before the belt change. Btw, at my mechanic's shop in the USA, they put a sticker on the engine bay by the rad stating when the belt was changed and at what mileage.
Make sure you get a thermostat, too with your kit. At least my mechanic told me it was necessary. May not be necessary but at least wise to change it while everything's taken apart i think.
Old Jan 28, 2016 | 12:16 PM
JasonK's Avatar
09 TL SH AWD /w TECH
If you're serious about doing your timing belt kit get the oe parts which is the gates kit. Replace the coolant and thermostat at the same time since it's being done anyways. I usually recommend doing them at 100,000k or 60,000 miles. I've seen how the tensioners wear on these cars and recommend at 100,000k. Not worth risking 5-6 grand over a 800$ job that covers you for the next 100 thousand kilometres
Old Apr 10, 2016 | 08:43 PM
HBK's Avatar
HBK
Just curious if anyone has a good mechanic around Toronto that can do this? Had a fallen out with my mechanic. Also what does it cost to do?
Old May 15, 2016 | 09:30 PM
MickeyHickey's Avatar
I had a 2008 MDX with 130,000km on it done at IGarage near HWY 7 and McCowan a few weeks ago.
Timing Belt was a kit Aisin TKH002 including pulleys, tensioner and water pump. I also did Drive belt and tensioner, upper side engine mount and two radiator hoses. I supplied all the parts including 2 gallons of Honda coolant and hose clips. I paid $350 Labour including tax. The parts were all OEM made by Aisin/Gates/Mitsuboshi procured in the states. For pricing look at Acurabernardi.com of Boston or RockAuto. I do not know of any US dealer that ships direct to Canada. There are warehouses you can use, one of them is CBI USA in Niagara Falls US. I went to a local Honda dealer that charged me $8 apiece for bolts that cost 75 cents in the US.
Old May 15, 2016 | 09:36 PM
I should add a coolant thermostat made by Aisin to the above.
vaughanml2
Nov 1, 2021 10:16 AM
redsox68
Sep 16, 2015 06:18 PM
merc009
Sep 14, 2015 06:43 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
asahrts
Sep 4, 2015 05:55 PM
