Acura: Development and Technology News
#2281
Not really its honda. They have been disappointing us for years now. If they dont we wont be sad as we are expecting crap from them. Now if they happen to wake up, actually go a planned direction, take control of what they are building and actually make a decent product then we will actually have something to be happy about. But like i said, none of us are expecting it.
#2282
1 Post
Considering the way Acura's been going, I think it's best to be pessimistic about them. If they do decide to change directions for the better and surprise us, it'll be a pleasant surprise. If not, we can say we were right about being pessimistic. Either way you look at it, being pessimistic wins!
#2283
#2284
Go Big Blue!
Maybe that's their strategy...confuse everyone and never have a clear goal. if no one knows what your goals are, they can never know if you failed.
too bad they don't realize that not having clear goals and constantly waffling on what they SAY (much less DO) is failure in itself.
Regarding the second sentence; I totally agree there also.
#2285
#2286
I've always wondered about this. Its kind of off topic, but again its not. If Acura thinks they can't compete without RWD, why not fix whats wrong with SH-AWD. Front-bias. Have an incabin control for the system.
The first setting is FWD-biased and gives rear wheels 0% of power. It can shift power between left and right wheels during hard acceleration. I'm not sure which wheel is more effective during FWD cornering... And if one of the front wheels loses traction for more than 5 seconds the system shifts some of the power to the rear wheels. Once traction is regained, sends it all back to the front. That would kind of be a safety feature incase the car is sliding off course. Then again this isn't the setting everyone drives fast in so intrusion would be minimal unless you choose to drive hard in it.
Second setting is where the power is divided between front and rear axles equally. Every wheel has equal power until it slips then that wheels power is given to the other. Say if the front left wheel is spinning, the power for that wheel would go to the front right wheel. The power is not shifted from front to back, only left to right. This setting would be good for snow, I'm guessing.
The third setting would be RWD-biased. The power would go to the rear wheels only. If one of the rear wheels loses traction, the power goes to the other. Only if both are slipping or if one is slipping for more than 15 seconds the power go to the front. Naturally, this setting would be hesitant about sending power to the front as its the "sport" setting. The power would shift to the outside wheel like SH-AWD does now. This setting you would use for track events, or if you just liked the feel of RWD.
Since Acura's slogan is advance, and the revised AWD system would advance you, the slogan would be incorporated in the setting names. The system as a whole would still be called SH-AWD, but the settings would be labeled advanceF, advanceE, advanceR. Which stands for front-biased, equally-biased, and rear-biased, respectively.
For sport models, such as the Type-S, there would be a power distrubution deactivation button. Activate it and the power will not be "axle shared." Say you are in advanceR powering through a curve and all the power is at the outside wheel. The rear wheels begin to slip, the power shifts to the front wheels to keep you on course and prevent oversteer. Well you want to slide through the next one. Press the button and when the rear wheels begin to slip through the next turn, the power will not be shifted to the front allowing you to "drift" through the curve.
It offers FWD economy, AWD security in low traction areas, and AWD security during hard cornering if wheel slippage occurs, and RWD feel.
I'm not even sure if this system is possible, its just kind of a fantasy. I'm sure there are some flaws, and some of it is overkill. It would probably weight alot, as I'm not even sure what kind of mechanical equipment you would need. But being able to chose from front-biased to rear-biased would be cool.
#2287
That system would be similar to Subaru's adjustable AWD system, which allows you to adjust the front/rear bias manually. While it sounds good to have such a robust system, it's also complicated to implement which is at least part of the reason Acura is sticking with FWD based AWD.
#2288
I'm the Firestarter
The whole reason why SH-AWD is front-biased is because Acuras are so front-heavy. The traction follows the weight distribution of the car. If they fixed the huge front overhangs and the way the engines are so far forward, the cars could look better and could have a more rear-biased AWD system like Audi. But that costs money and takes the kind of balls (i.e. investment) that Honda just doesn't seem to have lately.
#2289
2G TLX-S
SH-AWD and Quattro(-AWD) are both band-aid solutions to applying high engine power (< 290hp) to the performance-inferior FWD chassis.
Nothing beats the simple RWD chassis which can take virtually unlimited horsepowers.
This is one of the major reasons why Audi will never catch up with BMW and MB in sales volume. However, the tide will turn when Audi decides to offer RWD chassis as base models and make available Quattro as an upgrade option, exactly like BMW and MB.
If Audi can only get this far with FWD chassis, I don't see how the ex-Honda-CEO Takeo Fukui thought he could resurrect Acura into a "Tier-1" brand when he was still in charge.
#2291
2G TLX-S
Unfortunately NO !
It will be a super-major undertaking to revamp the many vehicle chassis and the large number of the entire Audi model lines. VW has it's secret agenda too, with respect of the potential of RWD Audi's threatening the upping end auto brands such as Porsche.
On the other hand, with Acura's relatively few model lines, it is much easier to get the job done, except that the current Acura brand direction is all screwed up.
#2292
2G TLX-S
It's all on the factory tuning. The latest SH-AWD TL sedan should be using the exact same AWD system as the SH-AWD RL.
But I don't know if the SH-AWD TL is a rear-biased system or not ?
#2293
Pardon me for interrupting what seems to be a fantasy discussion ungrounded in technical facts...
It's so simple! There are no substantive technical issues here; all that's needed is another knob! Lord knows there's enough of them in the TL's cabin already. Acura can probably get a fantastic volume discount at this point.
You've got your cause and effect entirely backwards. AWD systems similar to those that Audi uses on most of its cars tend to improve distribution by adding more weight to the back (though how much it would add beyond the already substantial weight of the torque-vectoring unit is unknown to me). But it's quite possible to have a rear-biased AWD system in a front-heavy car: for example, look at the Subaru Legacy GT Spec B, which used a 45/55 front-rear torque split with a 57/43 front-rear weight distribution. That's not too far off the TL SH-AWD's 59/41; some easy tweaks would get the Acura into the same ballpark. The A4 itself is 55/45 front-rear.
The real problem with the Acura is its use of a power take-off unit on the front differential, which is similar to the Haldex system that Audi brands "Quattro" on the A3 and TT. This is contrasted to the Torsen system that is used on other models which is a true limited slip center differential.
I'll note that despite the technical disadvantages of Acura's system, the actual numbers suggest that SH-AWD holds its own. The biggest problem (if you ask me) with the TL right now is just that it doesn't have enough power.
The front overhang problem would be fixed if Acura went back to mounting its engines north-south instead of east-west. It's got nothing to do with the choice of AWD system.
Ah. That explains the dominance of high-power RWD machinery like the Gallardo, the GT-R, the 911 turbo, and of course the Veyron.
#2294
I'm the Firestarter
Most importantly, the car doesn't have a huge nose like your typical FWD car so it looks like a RWD car without being one. And judging by the number of quattros I see out there, that's the typical Audi configuration they designed for, not FWD. The proof is the recent wins of the S4 against the 335 in automotive mags. If this platform can outhandle a BMW in the eyes of a critical reviewer, then clearly there's no drawback to it.
Acura's nowhere near that, the SH-AWD is an add-on to an inherently FWD platform.
Of course we should all keep in mind that for 99% of buyers, all these cars drive just fine.
#2295
I'm the Firestarter
#2296
2G TLX-S
Audi has no dedicated RWD chassis whatsoever. Otherwise the base R8 would be RWD, not the heavy-ass Quattro R8.
The base A4 is still a FWD sedan, go figures.
#2297
2G TLX-S
You're not entirely correct in your characterization of the latest Audi chassis. A typical FWD chassis from Honda/Acura has a 60/40 weight distribution. On the A4 it's 55/45, which is really close to the Mercedes C300 (something like 53/47) and probably even close to some BMW models.
My point is focus on the lack of RWD chassis for both Audi and Acura in high engine power applications, and on the fact that their AWD applications are to remedy the deficiency of FWD chassis in handling high engine power (> ~290hp).
There is no deny that all Audi platforms are FWD based. That's why the base-trim (low engine powered) A3, A4, and A6 are all FWD sedans.
In high performance trims (supercharged V6, V8, V10), Audi is forced to drive power into four wheels on it's FWD chassis, or risk making it's FWD cars to handle like a dog when high dose of hp is driving solely the two front wheels.
This is where the FWD chassis falls short of the RWD chassis. With today's auto technology, FWD cars are good up to around ~290hp. Above that, FWD cars will exhibit serious shortcomings in maintaining good handling dynamics, whereas RWD cars will have no problem handling 300+ hp. Sure one can put 300+ hp onto the front wheels, but the resulting car is only good accelerating in a straight line.
I don't think RWD is the magical ticket to success. I think it's the whole package, and some brands get closer to it than others. Audi has already outsold BMW in Europe by the way, and that's with their AWD/FWD platforms. Marketing/branding has a lot to do with BMW's success, not just that the cars are good.
#2298
2G TLX-S
Do you mean the following (no-sarcasm) real HIGH POWER RWD ones ?
- $194K RWD 997 GT2
Porsche creates the RWD GT2 by deliberately dumping the AWD system in favor of lighter weight for maximum track performance,
- 1287hp RWD SCC Ultimate Aero,
- 806hp RWD Koenigsegg CCX,
- 750hp RWD Pagani Zonda R,
- 627hp RWD infamous McLaren F1 road car,
- 624hp RWD Maserati MC12 GT1,
- 550hp RWD Ford GT,
- entire RWD Ferrari line-ups,
- and even the upcoming Japanese-origin 552hp RWD Lexus LF-A.
#2299
What dominance ?!
- $194K RWD 997 GT2
- $194K RWD 997 GT2
CTS-V
ZR-1
#2300
I'm the Firestarter
You have missed my point. My point is not on which auto maker has the best front to rear weight distribution.
The point is that 1) Audi's A4 chassis is as close to a RWD as it needs to be in order to compete with the best RWD chassi on handling, 2) in reality most buyers can't tell the difference between driving a FWD and a RWD so it doesn't affect sales that much.
Also consider that just a few years ago the maximum "acceptable" hp for a FWD car was something like 200, after that people complained about torque steer. Today there are FWD cars that push 300 hp and yet through use of various devices they have as much or less torque steer than before. It's just not THAT big a deal.
Europe is in the higher lattitude which demands AWD capability. BMW and MB are now catching up in AWD offerings in almost all available model lines. In the southern belt of North America, especially in California which is US's biggest auto market, AWD is less than popular as RWD in terms of luxury automobiles.
#2301
The Oracle of Acurazine!
from TOV
http://vtec.net/news/news-item?news_item_id=868825
Acura's "Smart Luxury" future is confirmed, and so is a sub-TSX model
Date: December 15, 2009 11:35
Submitted by: Jeff
Source: Anonymous
Credibility Rating: 9
As a followup to last week's news item about Acura's rumored adoption of the "Smart Luxury" tagline (and migration away from the previous "Tier 1" target), we have been able to confirm that this course deflection has in fact been communicated to the dealer body.
We can also confirm that Acura has told their dealer body to expect:
* a new entry-luxury model
* an "amazing flagship" model
* a line of hybrid vehicles done "the Acura way".
* NO rear-wheel-drive or V8-powered vehicles
The key drivers for this change in course are said to include the global economic crisis and upcoming 2016 federal mandates which dictate a fleet average of more than 37mpg for Honda and Acura combined. This figure represents an increase of more than 10mpg over where they currently stand.
We are told that Acura has also promised that the future model lineup will feature more differentiation (in terms of size) between models, though the pipeline's rate of introductions may slow down a bit. Acura has previously stated that the lineup would offer an MMC or FMC every 6 months for the next several years, but now they are saying an MMC or FMC "every year".
Submitted by: Jeff
Source: Anonymous
#2302
Whooolly crap look who posted.
#2303
#2305
#2306
#2307
#2308
2G TLX-S
How about comparing apple to apple, and compare the A4 with the 3??i and the C??0, and compare the S4 with the M3 and the C55-AMG ?
Much less torque steer is not sufficient. The 300hp FWD car must have ZERO torque steer, in order to full-throttle power out of a turn, especially a very tight turn. Gadgets that cut torque in order to prevent torque steer aren't very helpful here when they are in fact reducing engine power and slowing down the acceleration. All the while, a 300hp RWD car is able to enjoy pulling away from the same turn with ease at wide open throttle.
Once again, it's AWD to the rescue.
#2309
2G TLX-S
#2311
The S4 is from Audi's high performance tuning division, whereas the 335i is from BMW's regular auto division. So how valid is your point when start comparing high performance tuned cars with regular road cars ?
#2312
I agree that in reality most buyers can't tell between driving a < 280hp FWD and a < 280hp RWD cars. But putting a 290+ hp high power engine in the package, and the FWD one will be handling so bad that it will be left eating dust. Then it is AWD to the rescue for the high power 290+ hp FWD cars => Audi, Acura.
About 9 years ago, the max. hp for a still-decent-handling FWD car was 260hp (Acura CL-S). Now it is approx ~280hp. I've still yet to see a 300hp FWD car that can still handle well. Even today Audi and Acura have given up on tuning out a decent-handling 300hp FWD car by mandatory equipping AWD with anything above ~280hp.
#2315
Nope. The S4 is meant to be the middle ground between the 335i and M3. Audi always places their S models a step higher than the competition's sportiest production model but a step lower than the purpose-built performance car. They have the RS to compete with those.
#2317
Go Big Blue!
That's probably a good example of what NOT to do. Acura should not follow Subaru's lead. Granted, that Alpha Romeo style grill was poorly implemented, but they could have worked with it and made it a signature grill for Subaru with changes. I think that's what Acura should do. Move away from the TL implementation (it doesn't work) and more towards the TSX proportions. The concept is fine and it's already becoming a recognizable icon grill on the roads. When I see a TSX coming at me, it's easily recognized and seems aesthetically pleasing enough to me.
#2318
I'm the Firestarter
And again the whole point is that for buyers who want performance an AWD car can be perfectly acceptable and even beat a RWD car.
#2319
The most exciting thing about Acura lately is the controversial styling. Everyone sits around waiting to call ugly on the next design.
#2320
2G TLX-S
Not at all valid. The S4 is not fundamentally different and isn't from a "different division" than the A4. It has upgraded powertrain and brakes, yes, just like the 335 does over the 328. This new S4 is to the A4 what the 335 is to the 328, if anything it's slightly above the 335. Just look at the pricing. This is not an M3 or AMG-type car.
The 335i belongs to BMW's regular road car division, in the same way as the A4 to Audi's regular road car division. Both the 335 and the A4 can be ordered with sport suspension and bigger wheels directly from the factory. However, the 3-series still has many engine option to choose from, but the newest A4 has unfortunately lost the high power V6 option. This is a big minus point for Audi for no longer offering high power engine option for the new A4.
The S4 is more than a regular road car. It belongs to the high performance "S" division, and is equipped with high power engine, track-tuned suspension, bigger brakes, and big tires/wheels. The RS4 is another step up in performance and is equipped with even more powerful engine, even bigger brakes, and even wider tires.
In the same way, the M3 from the "M" divison and the C55-AMG from the "AMG" division are factory tuned similarly as the S4 and the RS4.
As a result, it is very obvious that even the sport-suspension-equipped 335i won't be in the same league as the S4 in the handling department. So apple-to-apple-wise, it's the S4 vs the M3/C55-AMG, and the A4 vs the 3-series/C-class.
In terms of base pricing,
S4 sedan = $52,500
335i sedan = $40,300
M3 sedan = $54,850.
So pitching the S4 against the 335i is like pitching the M3 against the A4.
If the S4 can't beat the M3 or the C55-AMG, tough luck, then the S4 is just not good enough as a special tune high performance car.
