Wire Radar detector directly to overhead lights? CL
Old Jun 29, 2005 | 12:53 PM
TheThirdMan's Avatar
Rag & Bone
Hey guys, a friend of mine spliced the overhead light socket wires on top of his rearview mirror and somehow wired it to his radar detector, you think its possible in my car to do the same thing, i'm gonna buy an extra power connector to fiddle with it. you think it can be done?
thanks for the input
Old Jun 29, 2005 | 01:41 PM
NYZGREATST's Avatar
Sig Rho's Finest
what i did was get a mini add-a-circuit from autozone and tap into the windshield wiper fuse. i also got the hardwire kit for my radar and just attached the positive wire to the adda circuit and grounded the kit to an exisiting ground bolt near the fuse box. i then just ran the wire up to the rearview mirror for the radar.
i wouldnt want to splice anything in case it ever shorts out
Old Jun 29, 2005 | 02:58 PM
I'm Batman's Avatar
Boom goes the Dynamite
I have had my V1 wired to the dome lights for years without any problems.
Old Jun 29, 2005 | 03:03 PM
Rag & Bone
well all i did was cut it open and strip a small section of wires
then i didn't want to soder* (*sp) it to the metal pieces...
see the little meat pieces next to the hole for the bulb, that are fixed to the plastic..
so i just wedged the wire between the bulb ends and the metal pieces
if you don't want to cut off the extra cord make sure to feed it over the fitting...
then put everything back and your done
now to turn it on all i do is press the button
Old Jun 29, 2005 | 03:11 PM
Rag & Bone
forgot to mention i just put a little light condom over the light to keep it from bugging me
Old Jun 29, 2005 | 09:19 PM
elduderino's Avatar
VP Electricity
Your wiring looks unsafe and prone to shorting out that would take out the DL fuse. THat fuse is also probably the radio constant.
And your coil cord coming out like that looks kinda weak. Can you get a straight cord for your RD?
Are you telling us that this thing only works when your dome light is turned on?
Old Jun 29, 2005 | 11:18 PM
Rag & Bone
technically yes but i covered the bulb to block the light
Old Jun 29, 2005 | 11:47 PM
NYZGREATST's Avatar
Sig Rho's Finest
i agree, thats kinda odd.
heres my setup, i know its hard to make it out but i hope it helps a little
Old Jun 29, 2005 | 11:48 PM
elduderino's Avatar
VP Electricity
Wouldn't the cover be a fire risk with an incandescent bulb?
Old Jun 29, 2005 | 11:49 PM
NYZGREATST's Avatar
Sig Rho's Finest
or, why not just remove the bulb all together?
Old Jun 30, 2005 | 10:36 AM
WolfpackBill's Avatar
TL no more!
I did that when I installed the hardwire kit in our '05 Ody. For my car, I ran the hardwire kit down to the cigarette lighter circuit and spliced it in.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
chrisr
Dec 4, 2015 02:17 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
sockr1
Oct 1, 2015 01:31 AM
