why does my amp turn off when i turn the volume up?
Old Jul 24, 2007 | 10:13 PM
playboyace35's Avatar
why does my amp turn off when i turn the volume up? Do i not have enough power? Do i need a capacitor, would that fix the problem? Or is it my wiring?
here is my setup
Hifonics Brutus amp 1606 - 1600 watts rms @1 ohm, 1100 @2 ohm, 550@ 4ohm.
2 12" Alumapros 500 watts rms each @4ohm
JL Cleansweep
Kicker Amp 4channel ZX.650
a/d/s 346cs 6.5 component speakers
Diamond Audio 6.5 Hi End Coaxial D661i speakers
What do you guys think?
Old Jul 24, 2007 | 10:18 PM
saltyone's Avatar
SNAFU
here is my setup
JL Cleansweep
Is it going into protection mode? If so, it could be the wiring, or the amp. Hard to say.
Old Jul 24, 2007 | 11:42 PM
so its not the power?
Old Jul 25, 2007 | 03:47 AM
btw my wires are 8 gauges
Old Jul 25, 2007 | 08:00 AM
AcuraX2's Avatar
First off, if you are running the subs at 2 ohm with 1,100 watts from your amp, I would seriously think about bigger wire than 8 awg. You really need 4 awg going to the amp with that much power.
It could be a short somewhere or a bad connection somewhere in the power or ground wires or even the speaker wires. Double check all your connections to make sure nothing is touching bare metal, except the ground of course.
Old Jul 25, 2007 | 10:52 AM
Castles_Saloon's Avatar
http://www.maxxsonics.net/manuals/hi...500D-2200D.pdf
Is a protection LED turning on? what volume level is it tripping? is the area around the amp well ventilated? If the weather has suddenly heated a lot, that lessens the gap your amp can heat up too. A lot of IC's are only good to 85C and protection circuits will shutdown prior to that temp.
maybe you need a cooling fan
Old Jul 25, 2007 | 01:07 PM
cutmasterj's Avatar
Does this happen during first use or after it's been on awhile. Maybe the input gain on the amp is set too high.
Old Jul 25, 2007 | 06:00 PM
dreem1er's Avatar
deal with it
used to happen to me in my old car with me it was that i was putting to much power to the speakers.....but either way turn all your levels down and see if it persist.....
Old Jul 25, 2007 | 09:04 PM
first use or been a while, it just happens when i turn up the volume on this one particular song with a lot of bass
i'll check
i'm running the subs at 4 ohm so its 550 watts
Old Jul 25, 2007 | 09:07 PM
but all in all, its not the power??
Old Jul 26, 2007 | 11:09 AM
cutmasterj's Avatar
Power protection, depending on the make and model, can also kick in if the voltage drops below a certain level. Also the documentation clearly indicates the usage of 4awg wire. I would suggest replacing the 8awg with 4awg wire and also replacing the ground wire from the battery to vehicle chassis and alternator positive to battery with 4awg wire as this is usually 6-10awg wire.
Old Aug 5, 2007 | 03:09 PM
okay, i checked it. The amp is not going into protection mode, it just shuts off. Btw, for most part my my wires are 4 gauge, UNTIL it reaches the distribution block. My distribution block splits 4 gauge into 2-8 gauges, and each 8 gauge go into an different amp. One goes to my midamp, and the other goes into my sub amp.
Does this mean i gotta get like a 2 gauge wire? and then get a distribution block that goes from 2-4 gauge?
and what is my other option? can i just run another 4 gauge wire from the battery to my amps individually? or will that be too much wires lol?
Old Aug 6, 2007 | 03:49 AM
vthree's Avatar
2006 ASM tsx
sigh i have this problem too. but its only happened when i switched to a jlw6v2
Old Aug 6, 2007 | 06:02 AM
AcuraX2's Avatar
I still might consider getting a multimeter and checking the voltage at the amp when it is to the point of shutting off. See if you are dropping to low in voltage.
Old Aug 6, 2007 | 07:40 AM
KaMLuNg's Avatar
for me this happened when the amp would overheat after a period of time... but if u are saying it is cutting out after initially raising it up, i am pretty sure it is a power issue... upgrade your lines, or turn your gains down and see if it still happens..
Old Aug 6, 2007 | 10:43 AM
Have you talked to the amp manufacturers support people ? Some companies are horrible and takes forever to get valuable info, but some are spot on or at least know of problems like these ahead of time and you can get quick answers.
Old Aug 7, 2007 | 12:18 AM
vthree's Avatar
2006 ASM tsx
ok mines an alpine mrv-f340...
i wanted to bridge all channels to my 1 jlw6v2.. i've been looking everywhre but still dont know if i can do this....
only thing i keep finding is to bridge one 4ch to 2..
but i want to bridge 4ch to 1? since i only have one sub
and the total power output cointinuous would be 450 or so ...
anyhow i tried it just now and when i raise it to all the way up from the start it worked fine for a while..
i think it may have to something to do with heating up???
but its weird that this only started happening after i put in the 10w6v2.. with my old blaupunk sub it worked fine...
any ideas?
Old Aug 7, 2007 | 12:43 AM
vthree's Avatar
2006 ASM tsx
solved mine..
all i did was lower the gain.. and works fine now..
Old Aug 9, 2007 | 04:46 AM
changed all the 8 gauge wires to 4 gauge, and added a capacitor, now it works like a charm
Old Aug 9, 2007 | 01:43 PM
Congrats! I'm glad your system is working properly. I'm sure your battery is thanking you for the cap.
Old Aug 16, 2007 | 11:14 AM
JoBiggs's Avatar
Great...I had the same problem and I just added a capacitor
Old Aug 16, 2007 | 12:18 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Was just reading through your thread and was gonna suggest switching to 4 awg and adding a cap, glad it's working for you now.
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Billu99tl
Sep 13, 2015 11:30 AM
IndycarFaster
Sep 11, 2015 02:52 PM
