Replacing the stock head unit
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Is it even possible without by passing the amp or getting a new system all together? I took my car to Best Buy recently to have a new stereo (Dual XD7500) installed. Unfortunately I was told that in order for the new unit to work with my Bose speakers they would have to bypass the amp and plug the speakers directly into the stereo. So without the amp my speakers wouldn't be nearly as loud. I have a 97 3.0 CL. I've been looking around the forums and have read about people replacing their head units. However they didn't say anything about bypassing the amp or having to get new speakers/amp. Are certain brands compatible with the bose speakers?
Any help would be greatly appreciated.
Loose Cannon
i think the stock head unit needs the bose amp in order to drive your speakers, but i am not sure i am just taking a guess, most aftermarket head units have powerfull enough outputs 50w x 4 to drive your stock speakers.
2013 sh-awd adv
there is also a bose eq that is connect to the bose head unit then to the speakers. when you replace the factor HU with an after market, you usually have to install a new amp and all new speakers. There are some complicated ways to get around this, but i found it easier just to replace it all. someone also told me the bose speakers sound like crap if you just connect a new amp to them. good luck
My other car is a DSM
sometimes you can get away with using the RCA outputs of your new deck to run signal to the factory amp. however, sometimes the low level output of the new deck is higher or lower than the factory deck, causing the sound to be higher or lower than it should.
if you bypass the amp and run the deck directly to the speakers, you will have better results most of the time. (again...) however, the bose speakers in your car are more than likely 2 ohm, meaning you will be drawing more power from your deck than is recommended.
bottom line, whenever you have a factory radio that is considered a premium audio system such as bose, shaker, monsoon.... youre looking at a complicated radio install. best results will be found when replacing everything, if anything at all. id recommend either keeping it all stock, or replacing it all. this is comming from someone who installs audio systems every day.
Loose Cannon
This is really easy, i wish most things would be as simple as this. Since the Bose System in the vehicle is most likely runs at 2 Ohms, and i dont want to replace my entire system just yet, i am only going to replace the head unit to get the navi and all the goodies, you can simply run the output from the new HU to the bose amp, to solve the issue of any output / input voltage compatabilities, you can simply use a line level adapter.. Take a look at this one for instance.
http://logjamelectronics.com/soundoem4a.html
there are probably more out there to match the specific bose system in your vehicle.
Does anyone have the Bose system spec's on the require line in to the stock bose amp on the 2003 acura CL S? I need to know what the bose amp wants from the head unit to be able to pick the right adapter when i swap out.
thanks
Thanks so much for the help! The only reason we were going to replace it with the Dual is because we originally bought it for my old car, but that died before we got the chance to install it. On top of that my Bose head unit refuses to take the code we've been given for it. I think we're going to take it out again and double check the serial code. Apparently Best Buy got that wrong or for some reason my stereo has a different code than it's supposed to. Is it possible for the code to be changed? Thanks again for all of the help!
@aMc, i will see what I can find as far as specs on the factory Bose system. I have one as well, and this info could be useful to us and many others.
EDIT: i will also ask this.... why o why would you buy a Dual?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Soul_Deamon
11-13-2018 04:44 PM
Joseph Stansbury
34
12-04-2015 01:57 PM
yahelou
09-06-2015 09:12 PM
