No Sticky about OEM setup?
Old Jun 8, 2004 | 01:04 AM
Floyd's Avatar
4th Gear
Hey guys. I was looking for some information about the OEM setup for my TSX and figured I had hit a goldmine when I stumbled onto this board. However, I was disapointed to see that there was no clear thread that answered my basic questions about the OEM setup. Maybe we can gather some of the data here, then compile it into an informative post that can be sticky'ed for all to benifit?
I'll begin with some of the data I was able to gather after reading through the board for the past few days, and maybe some others can answer some of my questions as well. If you have some input that you don't know is absolute fact, then indicate that with your info.
Is there a difference in the audio systems between the nav and non-nav headunits?
The HU has two sets of stereo pre-amp outs (front and rear) that run to an external amp. There has been discusion of a wiring diagram for the HU harness, though I haven't come across it yet.
The HU has an aux input that can be used for an external source. Directions for using this input can be found here: http://www.acura-tsx.com/forums/showthread.php?t=3148
The external amp, far all channels, is located under the factory HU?
It is assumed that the signal from the HU to the amp is low-level, though I haven't seen any definate info on this.
The amp has outputs for the front speakers, rear door speakers, and rear deck speakers.
The front speakers receive a full range signal. Where are the X-overs located? Is there processing in the amp, or passive X-overs on the way to the front speakers?
The front door speaker is a 6.5" Aftermarket speakers will require drilling holes for mounting as the OEM speakers are mounted with clips.
A write-up on how to remove the door panels can be found here: http://www.acura-tsx.com/forums/showthread.php?t=1989
The max mounting depth of the front woofers (measured from the surface of the metal door skin) is _____ . Is the window glass a factor when it's lowered?
The max clearance from the metal door skin to the inside of the stock speaker grilles is ______ .
If the stock grille for the dash tweeter is removed, the resulting hole is _____ inches in dia.
The rear doors get a full range signal? I don't even know what these speakers look like. Coaxial? Size? Mounting depth?
The rear deck 6x9 speakers are low-pass filtered (internal to the amp) and are for bass only. This X-over is fixed at ____ Hz?
That's all I have for now. Feel free to add to this thread if you have some usefull information.
Thanks.
Old Jun 8, 2004 | 01:46 AM
slo007's Avatar
Master in Science
HU/NAVI = Alpine
CD Player = Panasonic
The external amp is located under the OEM CD player, behind the "not an ash tray".
The signal from the HU to the amp is low-level. No one has measured the voltage level, yet.
OEM amp
Is there processing in the amp?
Yes, lot's of it.
The max mounting depth of the front woofers (measured from 1/2" away from the stock grill to the rear of the door, leaving 1/4" gap) is 2.85". Is the window glass a factor when it's lowered? Not if you cut the plastic liner behind the OEM grill.
The max clearance from the metal door skin to the inside of the stock speaker grilles depends. One can cut the plastic tabs that extrude out of the door and increase the distance by as much as 1/2" inch, if not more.
If the stock grille for the dash tweeter is removed, the resulting hole is ?? inches in dia.
The rear doors get a full range signal? Yes.
Same as front.
The rear deck 6x9 speakers are low-pass filtered (internal to the amp) and are for bass only. This X-over frequency varies by volume.
Old Jun 8, 2004 | 02:05 AM
slo007's Avatar
Master in Science
Wiring Diagram:
Old Jun 8, 2004 | 02:06 AM
slo007's Avatar
Master in Science
Hope all that info is right. The web site is not letting me edit my post.
Old Jun 8, 2004 | 08:01 AM
SSN_FT1(SS/DV)'s Avatar
Cruise Missile Lobber
Wow, this is a great idea for a sticky thread...one stop shopping for anyone wanting to upgrade You get some rep points from me!!! Not that they amount to much
Old Jun 8, 2004 | 08:25 AM
Dan Martin's Avatar
Photography Nerd
soopa, myself, and a few other members have been working on a FAQ for the TSX. We're just redoing some of the database stuff so that it is better organized but we should have it up shortly. We will have info on stock equipment as well as upgrade info.
Old Jun 8, 2004 | 08:32 AM
daniel1113's Avatar
This thread is a great idea.
slo007, you mentioned that the Nav system is made by Apline. However, does anyone have any information on the make/model or the LCD screen? Specifically, I am trying to find information regarding the wiring for the touch screen. Perhaps the Acura TSX manual has this information...?
Old Jun 8, 2004 | 03:51 PM
slo007's Avatar
Master in Science
I believe e-electro took his system apart. You might want to PM him.
I don't see why the manual would have brand names, but perhaps it might have a figure on the wiring. Best way to find out is create a new thread with a request for a scan of a manual page in regards to the LCD wiring.
However, last I checked the entire sound system is one unit, so I'm not sure it will have any info on the stuff inside.
Old Jun 8, 2004 | 06:24 PM
e_lectro's Avatar
Still here
Yeah, I have tore everything apart, and I mean everything related to the stock system. Check out the links in my sig for some pics, or look at my avitar
I had written up all of the pin outs, wire colors, etc. once... but it was other the other site that is down, and lost the document during a system crash. I was going to revive it, but kept waiting for the FAQ/How-to section to show up so I coulf up load all of the scans and documents... oh well
But if anyone has questions, I'd be glad to answer them!
Old Jun 8, 2004 | 06:41 PM
daniel1113's Avatar
Wow... you really did tear everything apart...
Here is my question:
Over the past week, I have figured out eveything I need in order to connect a media PC to the nav system, including both video and audio. However, I do not want to carry this out on my car unless I can find a way to use either the steering wheel controls or the touch screen input to control the PC (I'm not talking about controlling Windows, a start menu, etc., just a simple GUI for music and video playback).
So, when you took apart your nav system and carried out your mods, were you able to locate any specific inputs for the steering wheel controls or touch screen? Also, is there any documentation regarding either connection in the user's manual?
I hope this makes sense. Thanks a bunch.
Old Jun 8, 2004 | 06:50 PM
e_lectro's Avatar
Still here
Audio Unit Connectors:
-Back of CD unit
Code:
Cavity	Wire	Connect to
A1	YEL/GRN	Radio switch (Amp.)
A2	YEL/RED	ACC (main stereo power supply)
A3	GRN/RED	Radio remote Switch
A4	RED/WHT	(Security inout)
A5	LT GRN	Stereo Amplifier (Right rear speaker (+))
A6	BLU	Stereo Amplifier (Left rear speaker (+))
A7	BLU	Stereo Amplifier (Front passenger's door speaker (+), Right tweeter (+))
A8	RED/BLU	Stereo Amplifier (Driver's door speaker (+), Left tweeter (+))
A9	RED/BLK	Lights-on signal
A10	WHT/BLU	Constant power
A11	BRN	Radio remote switch ground
A12	BLU/RED	Navigation unit (RG GND)
A13	WHT	Navigatoin unit (RG L+)
A14	---	Not used
A15	PUR	Stereo Amplifier (Right rear speaker (-))
A16	PNK	Stereo Amplifier (Left rear speaker (-))
A17	RED	Stereo Amplifier (Front passenger's door speaker (-), Right tweeter (-))
A18	YEL	Stereo Amplifier (Driver's door speaker (-), Left tweeter (-))
A19	RED	Dash lights brightness controller
A20	BLK	Groung (G504)
-Bottom of CD unit
Code:
B1	---	Not used
B2	---	Not used
B3	BLK	Ground (BUS)
B4	---	Not used
B5	---	Not used
B6	---	Not used
B7	---	Not used
B8	---	Not used
B9	BLU/RED	BUS (+)
B10	WHT	BUS (-)
B11	---	Not used
B12	---	Not used
B13	---	Not used
B14	---	Not used
Audio-HVAC Display Panel Connector C
-Above CD unit
Code:
C1	BLK	Audio-HVAC subdisplay ground (5V)
C2	BLU/ORN	Audio-HVAC subdisplay 5V signal line
C3	---	Not used
C4	YEL/RED	Audio-HVAC subdisplay reset signal line
C5	YEL	Audio-HVAC subdisplay clock signal line
C6	BLU/RED	Audio-HVAC subdisplay data signal line
C7	BLU	Audio-HVAC subdisplay CE signal line
C8	GRY	Audio-HVAC subdisplay shielding ground
C9	RED	Audio-HVAC subdisplay LCD (BL-) signal line
C10	GRN	Audio-HVAC subdisplay LCD (BL+) signal line
Old Jun 8, 2004 | 07:03 PM
e_lectro's Avatar
Still here
LCD Connector 20P
Code:
Term#	Wire	Description
 	Color
1	WHT/RED	Continuous power source
2	YEL/RED Power source for accessory
3	BLU/RED	Data Bus (+) GA-Net
4	BLK	Shield for audio bus teminal #3,13
5	RED/WHT	Data Bus (+) GA-Net
6	---	Not used
7	---	Not used
8	WHT	Red color signal
9	RED	Green color signal
10	BLK	Ground for display unit
11	---	Not used
12	---	Not used
13	WHT	Data Bus (-) GA-Net
14	GRN/BLK	Shield for audio bus teminal #5,15
15	RED/BLU	Data Bus (-) GA-Net
16	---	Not used
17	BLU	Ground for color signal
18	YEL	Blue color signal
19	BRN	Composite video (vert/horz) synching signal
20	GRY	Sheild for terminal #8,9,17,18,19
Old Jun 8, 2004 | 07:25 PM
elduderino's Avatar
VP Electricity
I believe that the steering wheel controls have internal resistors associated with each button, and you would need a voltage comparator circuit to determine which button was pressed. The aftermarket interfaces I've seen (PAC) imitate aftermarket IR remotes - don't know if they would interface with your media PC.
Old Jun 8, 2004 | 07:26 PM
e_lectro's Avatar
Still here
Trunk DVD Connectors
-Connector A (20P)
Code:
1	WHT	Red color signal
2	RED	Green color signal
3	GRY	Shield for terminal 31,2,11,12,13
4	---	Not used
5	RED/BLK	ILL(+)
6	---	Not used
7	---	Not used
8	WHT	CAN-H (CAN high) F-CAN bus communication
9	GRN/BLK	Shield for display bus terminal #10,20
10	RED/WHT	DISP BUS (+) (Display bus positive)
11	YEL	[color=blue]Blue[color] color signal
12	BRN	Composite video (vert/horz) synching signal
13	BLU	Ground for color signal
14	---	Not used
15	---	Not used
16	---	Not used
17	---	Not used
18	RED	CAN-L (CAN low) F-CAN bus communication
19	---	Not used
20	RED/BLU	DISP BUS (-) (Display bus negative)
-Connector B (14P)
Code:
1	---	Not used
2	---	Not used
3	---	Not used
4	---	Not used
5	WHT/GRN	RG L (+) (Route guidance voice left positive)
6	BLU	MIC SIG (+) (Mic ouput signal positive)
7	---	Not used
8	---	Not used
9	---	Not used
10	GRY	STRG SW (Steering wheel switch output)
11	LT GRN	SH RG (Shield route guidance) #5,12
12	GRN	GND RG (Route guidance voice groung)
13	LT BLU	SH MIC (Shield mic) #4,14
14	PNK	GND MIC (Ground for Mic signal)
-Connector C (8P)
Code:
1	WHT/RED	Battery power
2	YEL/RED	ACC power
3	---	Not used
4	BLK	Ground for navigation unit
5	GRN	BACK LT (Back light) Reverse signal
6	BLU/WHT	VSP (Vehicle speed pulse)
7	GRN/RED	DIAG P (Diagnostic positive)
8	GRN/YEL	DIAG N (Diagnostic negative)
-Connector E (2P)
Code:
1	---	GPS antenna signal
2	---	GPS antenna ground
Old Jun 8, 2004 | 07:36 PM
e_lectro's Avatar
Still here
Speaker Wire Colors:
LEFT REAR SPEAKER
Code:
+ PNK*
- BLU/YEL*
RIGHT REAR SPEAKER
Code:
+ RED*
- BRN*
DRIVER'S DOOR SPEAKER
Code:
+ GRN/BLK
- LT GREEN
LEFT TWEETER
Code:
+ BLU/ORN
- GRY/BLU
FRONT PASSENGER'S DOOR SPEAKER
Code:
+ GRN/YEL
- GRY*
RIGHT TWEETER
Code:
+ BLK/RED
- PNK/BLK
LEFT REAR DOOR SPEAKER
Code:
+ BLU/RED*
- BLU/ORN*
RIGHT REAR DOOR SPEAKER
Code:
+ BLU/RED
- BLU/ORN
* Wire at speaker is different color than wire at amplifier. Wire at speaker given.
Old Jun 8, 2004 | 07:46 PM
e_lectro's Avatar
Still here
This is correct, the switch system is a two wire circuit, with each button press resulting in a different resistance. This is done so that there are as few wires that need to pass from the moving steering wheel to the rest of the car. Could you imagine trying to stuff 20 wires (10 switches) from the steering wheel to the colum and not have them bind or break?
Here is the info for the audio buttons, perhaps you can make your own adapter:
Resistance is measured between pins 3 and 4 on the back of the remote switch unit:
Code:
Position         Resistance
OFF              About 10 kOhm
MODE             About 4 kOhm
CH (+)           About 2 kOhm
CH (-)           About 800 Ohm
VOL UP           About 370 Ohm
VOL DOWN         About 100 Ohm
Old Jun 9, 2004 | 12:55 AM
Floyd's Avatar
4th Gear
Now were talkin!
Great info coming in guys. And thanks to e_lectro for all his input.
I won't spend any time cleaning any of this up if there is an "officail" FAQ coming soon. We can just use this thread for reference til then.
Any one know who manufactures the connectors for the harnesses for Honda? I have found Digi-Key to be a priceless resource for those types of parts. From connectors to flat ribbon cables, tact switches, you name it.
Old Jun 9, 2004 | 08:12 AM
e_lectro's Avatar
Still here
People have been looking for that information sence the first TL Navi-DVD mod. I think someone over at acuta-tl.com found out once, but they would not sell any single connector in a lot less than 10,000
Old Jun 9, 2004 | 09:06 AM
daniel1113's Avatar
Thanks for the great information, e_lectro. All of those charts will definitely come in handy.
Now that I look at the controls included on the steering wheel, as well as the resistance based input, I don't think I want to go that route. I don't think I will have enough control over the computer, plus I will need to be able to control those basic radio runctions when using the computer, anyway.
However, I will continue to look into using the touch screen. Thanks again.
Jul 16, 2017 07:33 AM
ROWDY621
Sep 30, 2015 03:20 PM
dirleton
Sep 25, 2015 12:25 AM
Hines57
Sep 24, 2015 01:58 PM
