replacing stock headunit
Old Jun 3, 2004 | 09:45 PM
umcp's Avatar
wow! i'm confused as a mofo!
i thought all i needed was a harness to install an aftermarket headunit in a 2nd gen cl.
i soldered my headunit's harness (panasonic) to the honda/acura 98+ harness i bought and the unit turns on but no sound comes out.
what am i doing wrong?
thanks
Old Jun 3, 2004 | 09:54 PM
vsokolov's Avatar
if you've done everything correctly, than amplifier inside head unit maybe fried
Old Jun 7, 2004 | 10:30 AM
G-UNIT's Avatar
Poppin them thangs
hook up the remote turn on wires with the amplifier wire....(blue wires)
Old Jun 7, 2004 | 12:24 PM
umcp's Avatar
i figured out which wire was the remote wire in the car (yellow white) but the sound coming out of the speakers i horrible and there is a lot of background noise and static.
is that a symptom of anything? crossed wires... etc
thanks.
Old Jun 7, 2004 | 12:26 PM
G-UNIT's Avatar
Poppin them thangs
i thought the remote turn on was blue...from the harness?
Old Jun 7, 2004 | 03:12 PM
umcp's Avatar
the diagram on the harness says its blue but it didn't work.
so i started searching and tapping wires. ended up being a yellow/white wire.
so i connected the blue wire from my headunit to that one.
it works but there's a lot of static/noise.
Old Jun 8, 2004 | 05:58 AM
G-UNIT's Avatar
Poppin them thangs
did u ground the HU directly to the chassis?
maybe thats why u got static/noise...
Old Jun 8, 2004 | 03:59 PM
umcp's Avatar
i tried both grounding from chassis and grounding to harness.
sounded the same both ways.
thanks g-unit for trying to help.
Old Jun 8, 2004 | 07:14 PM
Hobo's Avatar
Flap.
1. get a voltmeter
2. check all the grounds, id ground directly to chassis on bare metal.
3. i would make sure all your connections are sound? did you solder? or use butt connectors?
Old Jun 9, 2004 | 12:27 AM
umcp's Avatar
i checked everything.
i soldered harness to harness.
what i ended up doing was rewire my rear speakersto bypass the amp. it sounded regular no static or background noise. i turned the radio on with only the back speakers connected.
i'm gonna reconnect my fronts through the amp and see if they sound like crap. if they do i'm gonna rewire.
thanks for all the help.
Old Jun 9, 2004 | 06:57 AM
G-UNIT's Avatar
Poppin them thangs
you shouldnt have to rewire your rears to bypass the stock amp...well, i didnt...
u sure its not the deck? was the deck brand new or used? If new, bring it back and have them check it out....
always ground to the chassis homey...
Old Jun 9, 2004 | 09:44 AM
umcp's Avatar
the deck is brand new. i bought it online from a dealer in ny. is it very bad to ground it on the ground wire in the harness?
thanks.
Old Jun 9, 2004 | 10:14 AM
G-UNIT's Avatar
Poppin them thangs
I cant really answer that, but i know that you can hear interference if you dont, such as your car "whining" when u hit the gas....or a buzzing sound...
Soul_Deamon
Nov 13, 2018 04:44 PM
jblessing
Aug 8, 2018 09:43 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
yahelou
Sep 6, 2015 09:12 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
