TL: HU help 2002 TL
Old Nov 30, 2009 | 02:07 PM
2002sliverTL's Avatar
5th Gear
HU help 2002 TL
My OEM HU will not load or eject CDs. I tried taking the battery cable off to reset, but the problem came back. I need help deciding on weather its worth getting a replacement OEM Head unit, used, and an IPOD/XM hook up or getting a new HU with these features. If I stay with the OEM what IPOD/XM connector should I get? If it makes better sense, or dollars, to update the HU then what are some suggestions and what Bose connectors are recommended to keep factory speakers/sub?
Old Nov 30, 2009 | 10:45 PM
Jonesi's Avatar
If you are fine with the current system I see no reason to update to a aftermarket headunit. I'd just purchase a auxillary input and go MP3 rather then CD and make it easier on yourself. The stock radios in the TL and CL are known to have issues..
Old Dec 1, 2009 | 01:38 AM
5th Gear
Does the '02 6 CD HU have an auxiliary port or would I have to get a FM modulator?
Old Dec 1, 2009 | 08:37 AM
Jonesi's Avatar
There's a auxillary port that the auxilary adapters use. No FM modulator but you do have do get access behind the headunit.
TypeS860
Jan 10, 2026 11:11 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
02tljj
Sep 11, 2015 12:37 PM
ellisd03tls
Sep 8, 2015 04:17 PM
